Home » Eclipse Projects » Web Tools Project (WTP) » Classpath problem with Utility JAR Project
Classpath problem with Utility JAR Project [message #232218] Sun, 07 June 2009 09:38
Ralf Zahn is currently offline Ralf Zahn
Member
I have one EAR project containing a web module and some utility projects
that the web module refers to.
In the past, I have renamed all projects and added the PDE nature to them
to have OSGi bundles.
Since then, I have the problem, that one of the utility projects is put
into the classloader with the path
<ear project>/<utility project name>.jar
instead of
<utility project path>/bin
This has the effect that the classes of this module are not found. Another
utility module works fine, but only one is wrong.
How can I fix this? Is there a possibility to refresh the WST settings in
the workspace?
Previous Topic:XML schema association
Next Topic:User libraries not copied
Current Time: Sat May 25 22:22:05 EDT 2013
Powered by FUDForum. Page generated in 0.01446 seconds
