| Error in launching application on Tomcat 5.5 [message #232084] |
Wed, 03 June 2009 04:50  |
Angelo Fabio Mulone Messages: 6 Registered: July 2009 |
Junior Member |
I use Eclipse 3.4.1 Ganymede and I have a problem in starting tomcat (also
I do not assign a project to tomcat 5.5 server).
The console log tells me this:
3-giu-2009 10.43.11 org.apache.catalina.core.AprLifecycleListener
lifecycleEvent
INFO: The Apache Tomcat Native library which allows optimal performance in
production environments was not found on the java.library.path: C:\Program
Files\Java\jdk1.5.0_16\jre\bin;.;C:\WINDOWS\system32;C:\WIND OWS;C:/Program
Files/Java/jre6/bin/client;C:/Program
Files/Java/jre6/bin;C:\oracle\product\10.2.0\client_1\bin;C: \WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\cyg win\bin;C:\axis2-1.4.1\bin;C:\apache-ant-1.7.1\bin;C:\gwt-wi ndows-1.5.3\gwt-windows-1.5.3;C:\j2sdk1.4.2_19\bin;C:\Progra m
Files\Microsoft SQL Server\80\Tools\Binn\;C:\Program Files\Microsoft SQL
Server\90\Tools\binn\;C:\Program Files\Microsoft SQL
Server\90\DTS\Binn\;C:\Program Files\Microsoft SQL
Server\90\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files\Microsoft
Visual Studio 8\Common7\IDE\PrivateAssemblies\;C:\Program Files\cvsnt;
3-giu-2009 10.43.11 org.apache.coyote.http11.Http11BaseProtocol init
INFO: Initializing Coyote HTTP/1.1 on http-8090
3-giu-2009 10.43.11 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 797 ms
3-giu-2009 10.43.11 org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
3-giu-2009 10.43.11 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5.27
3-giu-2009 10.43.11 org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
log4j:WARN No appenders could be found for logger
(org.apache.catalina.startup.TldConfig).
log4j:WARN Please initialize the log4j system properly.
3-giu-2009 10.43.13 org.apache.catalina.core.StandardContext start
GRAVE: Error listenerStart
GRAVE: Context [/TPS_WEB_USER] startup failed due to previous errors
3-giu-2009 10.43.14 org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8090
3-giu-2009 10.43.14 org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
3-giu-2009 10.43.14 org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/31 config=null
3-giu-2009 10.43.14 org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
3-giu-2009 10.43.14 org.apache.catalina.startup.Catalina start
INFO: Server startup in 3312 ms
When I try to open http://localhost:8090/TPS_WEB_USER/ I receive this
error:
HTTP Status 404 -
type Status report
message
description The requested resource () is not available.
TPS_WEB_USER is the project I try to run.
How can I solve?
In the console I do not see any errors, why?
Thanks, bye bye.
| Re: Error in launching application on Tomcat 5.5 [message #232635 is a reply to message #232619] |
Wed, 17 June 2009 10:32  |
Larry Isaacs Messages: 1261 Registered: July 2009 |
Angelo Fabio Mulone wrote:
> Another information.
> If I click on "Switch location" on the server properties and the I try
> to run the server I receive this other message:
> 17-giu-2009 9.43.58 org.apache.catalina.core.AprLifecycleListener
> lifecycleEvent
> in production environments was not found on the java.library.path:
> C:\Program
> Files\Java\jdk1.5.0_16\jre\bin;.;C:\WINDOWS\system32;C:\WINDOWS;C:/Program
> Files/Java/jre6/bin;C:\oracle\product\10.2.0\client_1\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\cygwin\bin;C:\axis2-1.4.1\bin;C:\apache-ant-1.7.1\bin;C:\gwt-windows-1.5.3\gwt-windows-1.5.3;C:\Program
> Files\Java\jdk1.5.0_16\bin;C:\Program Files\Microsoft SQL
> 17-giu-2009 9.43.59 org.apache.coyote.http11.Http11BaseProtocol init
> INFO: Initializing Coyote HTTP/1.1 on http-8080
> 17-giu-2009 9.43.59 org.apache.catalina.startup.Catalina load
> INFO: Initialization processed in 735 ms
> 17-giu-2009 9.43.59 org.apache.catalina.core.StandardService start
> 17-giu-2009 9.43.59 org.apache.catalina.core.StandardEngine start
> 17-giu-2009 9.43.59 org.apache.catalina.core.StandardHost start
> 17-giu-2009 9.43.59 org.apache.catalina.core.StandardContext resourcesStart
> GRAVE: Error starting static Resources
> java.lang.IllegalArgumentException: Document base
> C:\wrokspace2\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\wtpwebapps\TPS_WEB_USER
> does not exist or is not a readable directory
> at
> org.apache.naming.resources.FileDirContext.setDocBase(FileDirContext.java:141)
> at
> org.apache.catalina.core.StandardContext.resourcesStart(StandardContext.java:3855)
> at
> org.apache.catalina.core.StandardContext.start(StandardContext.java:4024)
> at
> org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1014)
> at org.apache.catalina.core.StandardHost.start(StandardHost.java:736)
> at
> at
> org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
> at
> org.apache.catalina.core.StandardService.start(StandardService.java:448)
> at
> org.apache.catalina.core.StandardServer.start(StandardServer.java:700)
> at org.apache.catalina.startup.Catalina.start(Catalina.java:552)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:585)
> at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:295)
> at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:433)
> 17-giu-2009 9.43.59 org.apache.catalina.core.StandardContext start
> GRAVE: Error in resourceStart()
> GRAVE: Error getConfigured
> 17-giu-2009 9.43.59 org.apache.catalina.core.StandardContext stop
> INFO: Container
> org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/TPS_WEB_USER]
> has not been started
> 17-giu-2009 9.43.59 org.apache.coyote.http11.Http11BaseProtocol start
> INFO: Starting Coyote HTTP/1.1 on http-8080
> 17-giu-2009 9.43.59 org.apache.jk.common.ChannelSocket init
> 17-giu-2009 9.43.59 org.apache.jk.server.JkMain start
> 17-giu-2009 9.43.59 org.apache.catalina.storeconfig.StoreLoader load
> 17-giu-2009 9.44.00 org.apache.catalina.startup.Catalina start
> INFO: Server startup in 1109 ms
> What does it mean?
> Thanks, bye bye.
This Switch Location operation moves the XML that defines the server
between its normal location in
"<workspace_root>/.metadata/.plugins/org.eclipse.wst.server.core/servers.xml "
(not related to Tomcat server.xml) to a file found in the Servers
project in your workspace. Once upon a time long ago, there was a use
case for manually modifying this XML. I'm not aware of any reason to
use this operation today.
There does appear to be a bug in that following the switch, publishing
fails to publish any modules. To correct the behavior, restart Eclipse
or remove all the modules from the server, publish the server, an add
the modules back.
Note that this issue is unrelated to your earlier problem and I would
recommend executing Switch Location again to move the XML back to its
normal location.
Larry
FUDForum. Page generated in 0.02094 seconds
