Home » Eclipse Projects » Web Tools Project (WTP) » source code location for WTP plugins?
source code location for WTP plugins? [message #231567] Tue, 19 May 2009 06:31 Go to next message
Eclipse User
Originally posted by: mike.xmos.com
I'm having trouble finding the source code for the WTP plugins e.g.
org.eclipse.wst.sse.ui - basically I've installed WTP and I'm importing
that plugin as a source project but there doesn't seem to be any source?
Mike
Re: source code location for WTP plugins? [message #231588 is a reply to message #231567] Tue, 19 May 2009 09:29 Go to previous message
Larry Isaacs is currently offline Larry Isaacs
Mike Wrighton wrote:
> Mike
Execute Help -> Software Updates. On the Installed Software tab, scroll
down to find Web Developer Tools. If you don't see Web Developer Tools
SDK next to it, then you likely don't have WTP source installed. On the
available Software tab, you may need to click Manage Sites and enable
the site for "http://download.eclipse.org/webtools/updates". Under this
site you will find "Web Developer Tools SDK" (installs all of Web
Standard Tools source) and "Eclipse XML Editors and Tools SDK" (a subset
I believe will likely serve your purposes). HTH.
Larry
Previous Topic:Add classpath entry
Next Topic:XML editor deployment...
Current Time: Wed May 22 17:03:37 EDT 2013
Powered by FUDForum. Page generated in 0.01686 seconds
