| J2EE documentation [message #231292] |
Wed, 13 May 2009 14:13  |
Anna Messages: 24 Registered: July 2009 |
Junior Member |
I'm trying to use shift+F2 to look up HttpServletResponse class, and
Eclipse sends me the error message, saying that some jar file is not found.
All my jar files are in place. As a proof - the servlets are successfully
built.
shift+F2 works for all Java SE classes, but not for J2EE ones.
It looks like Eclipse can't find the URL to go to .
Please help!
Thanks in advance,
Anna
| Re: J2EE documentation [message #231385 is a reply to message #231379] |
Fri, 15 May 2009 10:44  |
Larry Isaacs Messages: 1261 Registered: July 2009 |
Anna wrote:
> Hi Larry!
> Thank you very much for your reply.
> I'm using GlassFish v2 Java EE 5.
> Is there anything specific for this server?
> Would you please include as much details as possible, I'm a novice, it's
> my very first web project.
> Thank you very much,
> Anna
I know almost nothing about the GlassFish server support. The process
described for Tomcat may be applicable for GlassFish, but I don't know
where to tell you to find servlet API Javadoc in a GlassFish install.
You could also ask on a GlassFish support forum and see if you can get a
response from someone more knowledgeable.
Larry
FUDForum. Page generated in 0.01766 seconds
