Home » Eclipse Projects » Web Tools Project (WTP) » Using EclipseTest Framework for WTP
Using EclipseTest Framework for WTP [message #231160] Sun, 10 May 2009 21:27 Go to next message
Peter Liu is currently offline Peter Liu
Hi.
Could someone give me some PRACTICAL pointers on using Eclipse Test
Framework (ETF) for WTP?
I'm aware of the 2007 article on ETF
( http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.test/te stframework.html?content-type=text%2Fhtml&revision=HEAD)
and a recent blog posting about ETF
( http://rcpquickstart.com/2008/08/01/creating-a-test-environm ent-for-the-eclipse-testing-framework/
Thanks.
Re: Using EclipseTest Framework for WTP [message #231194 is a reply to message #231160] Mon, 11 May 2009 21:33 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
Peter Liu wrote:
> Hi.
Perhaps you could indicate what it is you're trying to do, and where
you're getting stuck?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Using EclipseTest Framework for WTP [message #231255 is a reply to message #231194] Tue, 12 May 2009 11:18 Go to previous message
Hi, Nitin.
What I want to do is to run AUTOMATED testing on WTP.
I know how to do manual testing by using the PDE's Run As
"JUnit plug-in test." I will appreciate it very much if you may
give me some practical pointers. Thanks.
Peter.
Previous Topic:Hot deploy in Ganymede
Next Topic:Problem during replacing element from one schema to another schema using DOM
Current Time: Sun May 19 20:34:00 EDT 2013
Powered by FUDForum. Page generated in 0.01767 seconds
