Home » Eclipse Projects » Web Tools Project (WTP) » Importing war
Importing war [message #231141] Fri, 08 May 2009 07:31 Go to next message
breako  is currently offline breako
Member
I import a war into my workspace. In my war I have some .properties files
inthe build/classes directory.
Eclipse puts them into JavaResources:/src.
Why?
This is causing me problems. When I start the war, it gives out about not
being able to find one of the .properties files?
Any help greatly appreciated.
Re: Importing war [message #231204 is a reply to message #231141] Mon, 11 May 2009 21:36 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
breako wrote:
> files inthe build/classes directory. Eclipse puts them into
> JavaResources:/src.
> Why?
> not being able to find one of the .properties files?
"Java Resources" is an organizational node specific to the UI in the
Project Explorer, it's not literally the name of a directory on
disk. The Navigator view will show the actual layout of your files,
which might help you find out why the file's not being found at runtime.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Importing war [message #231454 is a reply to message #231204] Sun, 17 May 2009 06:38 Go to previous message
Member
Thanks for that Nitin. If we could just forget about the issue of the
file not being found and I could just ask you a question on the
organisational structure.
When I import a war, Eclipse creates the directories /src/ and
/WebContent/ under my project and puts .properties files in /src/ and JSPs
in /WebContent/.
I can see this in the navigator view and in my windows explorer.
I am wondering is there anyway I change how eclipse decides to put what
files where when unpacking a war?
Thanks.
Previous Topic:Problem with WTP Editor and validation
Next Topic:Building Working Set
Current Time: Tue May 21 03:55:16 EDT 2013
Powered by FUDForum. Page generated in 0.02064 seconds
