Home » Eclipse Projects » GEF » GEF, EMF, and platform undo/redo/command
GEF, EMF, and platform undo/redo/command [message #230878] Wed, 21 February 2007 21:37 Go to next message
Eclipse User
Originally posted by: mspivak.outerbay.com
What is the currently recommended way to implement undo/redo and command
stacks using GEF with EMF models in an RCP app? There are old
discussions on this topic. Is there anything more current?
Is the preferred approach to use platform commands? Any pointers to docs
or samples?
Unfortunately GMF is not an option for my project.
Thx,
Max
Re: GEF, EMF, and platform undo/redo/command [message #230917 is a reply to message #230878] Thu, 22 February 2007 10:59 Go to previous messageGo to next message
Eclipse User
Originally posted by: none.ibm.com
You don't need to use the platform operation support unless you have
contexts which overlap.
"Max Spivak" <mspivak@outerbay.com> wrote in message
news:erivkl$crp$1@utils.eclipse.org...
> stacks using GEF with EMF models in an RCP app? There are old discussions
> or samples?
> Thx,
> Max
Re: GEF, EMF, and platform undo/redo/command [message #230939 is a reply to message #230917] Thu, 22 February 2007 16:38 Go to previous message
Eclipse User
>> or samples?
>> Thx,
>> Max
What do you mean by contexts which overlap? Do you mean like when I open
my one view that is editing a part which resides in another view, and that
modificaitno of the one view, affects the other view. But not vice versa?
CL
Previous Topic:Help with connections
Next Topic:ConnectionAnchor for Triangle-Figure
Current Time: Sun May 19 16:58:48 EDT 2013
Powered by FUDForum. Page generated in 0.01620 seconds
