| SwtApplication vs AbstractApplication [message #22989] |
Tue, 17 March 2009 07:04  |
Velganesh Subramanian Messages: 59 Registered: July 2009 |
Member |
I followed the steps mentioned in http://wiki.eclipse.org/Riena_Navigation
to get started with Riena UI. When I dervied my Application class from
AbstractApplication, I couldn't launch the application window. After
exploring org.eclipse.riena.example.client, I switched the parent to
SwtApplication and I could see the window. What is the essential
difference between these two?
Is the name 'NavigationNodeId' apt? 'id' generally refers a String and
this, to me, is off the track. But there is already 'NavigationNode'. I am
void of suggestions.
| Re: SwtApplication vs AbstractApplication [message #23031 is a reply to message #22989] |
Tue, 17 March 2009 12:16   |
Christian Campo Messages: 578 Registered: July 2009 |
> http://wiki.eclipse.org/Riena_Navigation to get started with Riena UI.
> When I dervied my Application class from AbstractApplication, I couldn't
> launch the application window. After exploring
> am void of suggestions.
Hi the first answer is really simple. Ridgets and the some of the concepts in Riena are toolkit independant (independant
of SWT). AbstractApplication is a such a toolkit independant thing. You should not use it but rather use SwtApplication.
I am not sure I understand the second question. The navigation model is constructed like a tree. "Application" is the
root element, below is SubApplication, ModuleGroup, Module, SubModule. Each of them are implementations or subclasses of
NavigationNode. They also all have an Id. The Id is necessary so that you can navigation to another node. If you
navigate from "a" to "b", Riena will do everything that is necessary to get you there i.e. expand and close modules,
switch SubApplications. So you use the Id if you formulate a target for navigation. A concrete implementation of such a
point in the Navigation model is a subclass of NavigationNode.
Is that the answer to your question ???
If not please try again. And I try to help you
christian
| Re: SwtApplication vs AbstractApplication [message #23072 is a reply to message #23031] |
Wed, 18 March 2009 00:11  |
Member |
Thanks for your explanation, Christian. You are partially correct in the
answers.
1. The article suggests that I need to derive my Application from
AbstractApplication. I did and I couldn't launch the window. Since you say
that we shouldn't use AbstractApplication, wiki should be changed.
2. I was bothered about the name for the class 'NavigationNodeId'. I tried
to say that the word 'id' means a String. But here we have a class since
NavigationNodeId has two parts. I would rather make ModuleGroupNode,
ModuleNode and SubModuleNode take two String objects explicitly (typeId
and instanceId).
Are you also working on adding javadoc? WorkareaManager has overloaded
registerDefinition method. Only the example plugin helped me in
understanding their usage.
You are using FormLayout in SubModuleView.createPartControl. I faced some
problems when I tried to use GridLayout for my composite. I will try again
and post my questions.
| Re: SwtApplication vs AbstractApplication [message #581281 is a reply to message #22989] |
christian
| Re: SwtApplication vs AbstractApplication [message #581300 is a reply to message #23031] |
Member |
answers.
and instanceId).
FUDForum. Page generated in 0.02072 seconds
