Home » Eclipse Projects » Web Tools Project (WTP) » Encountered an NullPointException with StructuredModelManager
Encountered an NullPointException with StructuredModelManager [message #230471] Thu, 16 April 2009 18:16 Go to next message
Frank Du is currently offline Frank Du
Member
Dear, All,
Again, we are reading/writing in-memory objects. A disk file will be
parsed into model, and the SSE editor will display a small portion of the
model.
I implemented the IStorageEditorInput and IStorage for the objects. Then
added required plug-ins to the launch settings. But I kept encountering
NullPointException when trying to open a file. The debug showed that in
the following lines, model is a null value.
Do we need to register a model? If yes, how to register a model?
//org.eclipse.wst.sse.ui.internal.StorageModelProvider
// first parameter must be unique
model = StructuredModelManager.getModelManager().getModelForEdit(id,
contents, null);
model.setBaseLocation(calculateBaseLocation(input));
Supplementary:
If the program starts with all the plug-ins, the problem is gone. It seems
that some plug-in contributes models for the issue. Is there a way to
figure out the plug-in?
Thank you so much!
Have a nice day!
Frank
Re: Encountered an NullPointException with StructuredModelManager [message #230494 is a reply to message #230471] Fri, 17 April 2009 21:02 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
Frank Du wrote:
> Dear, All,
> the model.
> contents, null);
> Supplementary:
> seems that some plug-in contributes models for the issue. Is there a way
> to figure out the plug-in?
> Thank you so much!
It depends on what kind of input you're using, i.e. is it XML, HTML,
CSS, etc.? You'll need to have the language-specific UI and Core
plug-ins present as well as org.eclipse.wst.sse.ui and
org.eclipse.wst.sse.core. It also helps if the ID you're passing in
looks like an expected filename for your supported content type.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:Validation of XPaths in xsd?
Next Topic:Publishing static website to HTTP server fails
Current Time: Tue May 21 14:00:11 EDT 2013
Powered by FUDForum. Page generated in 0.02366 seconds
