| GEF PrintAction [message #230466] |
Mon, 12 February 2007 18:53  |
Kathiravan Messages: 33 Registered: July 2009 |
Member |
I added a printaction to the ViewPart by calling the makeActions()
method inside the createControl Method.
private void makeActions() {
printAction = new PrintAction(getSite().getPart());
I can see the print action added to the viewpart. But it is always
disabled. How do i enable it?
Thanks in advance,
Kathir.
| Re: GEF PrintAction [message #230577 is a reply to message #230466] |
Tue, 13 February 2007 07:43   |
Originally posted by: jakub.jurkiewicz.gmail.com
Maybe try the method public void setEnabled(boolean enabled) that comes
from org.eclipse.jface.action.IAction interface (and PrintAction
implements this interface).
Let me know if it helps.
regards
Jakub Jurkiewicz
> Thanks in advance,
> Regards
> Kathir.
| Re: GEF PrintAction [message #230601 is a reply to message #230466] |
Tue, 13 February 2007 16:55  |
Originally posted by: none.unknown.com
Well, obviously, just creating the action is not enough. You need to
register it as the handler for the global action. The GraphicalEditor does
a lot of things for you automatically, so in there all you need to do is
create the action and add it to the action registry. But in a view of your
own, you'd have to set up everything yourself. I suggest that you
understand how actions work in Eclipse before you try to fix this problem.
Note that this topic is not related to GEF and falls under the domain of
platform.
"kathir" <kathir@gmail.com> wrote in message
news:eqqulj$as9$1@utils.eclipse.org...
>I added a printaction to the ViewPart by calling the makeActions() method
> Thanks in advance,
> Regards
> Kathir.
FUDForum. Page generated in 0.33161 seconds
