Home » Eclipse Projects » Web Tools Project (WTP) » Registering own IDocumentProvider for JavaScriptEditor
Registering own IDocumentProvider for JavaScriptEditor [message #229384] Mon, 23 March 2009 02:36 Go to next message
Andrew Arapov is currently offline Andrew Arapov
Hi!
I'm trying to register my own IDocumentProvider, which extends
StorageDocumentProvider.
My steps are:
1. I have my own IStorageEditorInput, which provides editing some string
without openning IFile
============================================================ ==================public
class SimpleEditorInput implements IStorageEditorInput {
private String inputString;
public SimpleEditorInput(String inputString) {
this.inputString = inputString;
public IStorage getStorage() throws CoreException {
return new IStorage() {
public InputStream getContents() throws CoreException {
return IOUtils.toInputStream(inputString);
public IPath getFullPath() {
return null;
public String getName() {
return SimpleEditorInput.this.getName();
public boolean isReadOnly() {
return false;
public Object getAdapter(Class adapter) {
return null;
public boolean exists() {
return true;
public ImageDescriptor getImageDescriptor() {
return ImageDescriptor.getMissingImageDescriptor();
return "JSEditor";
public IPersistableElement getPersistable() {
return null;
public String getToolTipText() {
return "JSEditor Tool Tip Text";
return null;
public void setInputString(String inputString) {
2. Next, I'm opennig JavaScriptEditor:
window.getActivePage().openEditor(new
SimpleEditorInput(TEST_JS_1),"org.eclipse.wst.jsdt.ui.CompilationUnitEditor ");
3. The problem is, that I'd like to process SAVE action. But default
provider for my EditorInput is StorageDocumentProvider, which
doSaveDocument method is empty:
protected void doSaveDocument(IProgressMonitor monitor, Object element,
IDocument document, boolean overwrite) throws CoreException {
So, I'm trying to register my own DocumentProvider:
public class StringStorageDocumentProvider extends StorageDocumentProvider
... here do something ...
by placing in my plugin.xml this block:
<extension
point="org.eclipse.ui.editors.documentProviders">
<provider
class="test.jseditor.StringStorageDocumentProvider"
inputTypes="test.jseditor.SimpleEditorInput"
id="test.jseditor.StringStorageDocumentProvider">
</provider>
</extension>
It works fine, when I'm using "org.eclipse.ui.DefaultTextEditor" - my
StringStorageDocumentProvider is generated in this case.
But when I'm using JavaScript editor
(org.eclipse.wst.jsdt.ui.CompilationUnitEditor) problem is still appears.
What do you think about this? May be it is bug/fault of JSDT plugin or
special restriction?
Re: Registering own IDocumentProvider for JavaScriptEditor [message #229488 is a reply to message #229384] Wed, 25 March 2009 05:53 Go to previous messageGo to next message
Andrew Arapov wrote:
> Hi!
> My steps are:
> return null;
> return false;
> return null;
> return true;
> return "JSEditor";
> return null;
> return null;
> @Override
> <extension
> <provider
> </provider>
> </extension>
up
Re: Registering own IDocumentProvider for JavaScriptEditor [message #229493 is a reply to message #229384] Wed, 25 March 2009 05:54 Go to previous messageGo to next message
up
Re: Registering own IDocumentProvider for JavaScriptEditor [message #229569 is a reply to message #229384] Wed, 25 March 2009 13:48 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
It's intentional, just as it is with the Java editor. The JSDT
CompilationUnitEditor is hard-wired to use its own document
provider, CompilationUnitDocumentProvider, to make sure that the
partitioning setup in the IDocument is correct, as well as perform
some additional setup for handling as-you-type validation results.
As a workaround, you could open a file outside of the workspace, but
you'll need to open a feature request to get this changed...and if
you have suggestions on exactly how to change it, please let us know.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Registering own IDocumentProvider for JavaScriptEditor [message #229799 is a reply to message #229569] Mon, 30 March 2009 03:29 Go to previous message
Hi! Thank you for reply.
I would like to suggest you simple create some external wrapper for
saveDocument method.
May be it could be something like:
if (saveWrapper == null) return;
saveWrapper.doSave(...);
I think it could be configured in plugin.xml...
Previous Topic:Early testers wanted for M6 update site and all-in-one packages
Next Topic:How to change the code in jar file
Current Time: Sat May 25 06:17:32 EDT 2013
Powered by FUDForum. Page generated in 0.01693 seconds
