| Re: WSDL XSD and XML Catalog [message #229870 is a reply to message #229641] |
Mon, 30 March 2009 16:26  |
Lawrence Mandel Messages: 486 Registered: July 2009 |
First off, the fact that you're getting different behaviour from the XML
editor and WSDL validator makes me think there's at least a problem with
the consistency of these tools.
There is one issue that sticks out to me in your example. As I recall, a
schemaLocation is treated by the tools as a reference to a system
location. In your catalog entry you've specified the location as a
publicId, which corresponds with a namespace. Try changing the catalog
entry to use a systemId instead and see if the WSDL validator can locate
the schema in this case.
Lawrence
FUDForum. Page generated in 0.01514 seconds
