Home » Eclipse Projects » Web Tools Project (WTP) » Eclipse Ganymede : undefined command: plug-in='org.eclipse.tm.terminal'
Eclipse Ganymede : undefined command: plug-in='org.eclipse.tm.terminal' [message #229100] Tue, 17 March 2009 09:28 Go to next message
Celinio Fernandes is currently offline Celinio Fernandes
Using Eclipse Ganymede 3.4,
i am trying to start JBoss 5, without any project in it.
I get an error message stating that Server Jboss was unable to start
within 999 seconds.
I checked the log file in eclipse .metadate\.log\.log and i get the
following messages :
# !ENTRY org.eclipse.ui 2 0 2009-03-17 07:33:34.877
# !MESSAGE Warnings while parsing the key bindings from the
'org.eclipse.ui.commands' extension poin
t
# !SUBENTRY 1 org.eclipse.ui 2 0 2009-03-17 07:33:34.877
# !MESSAGE Cannot bind to an undefined command:
plug-in='org.eclipse.tm.terminal', id='org.eclipse.t
m.terminal.command1'
# !ENTRY org.eclipse.wst.server.core 4 0 2009-03-17 07:51:35.883
# !MESSAGE Server JBoss v5.0 CR1 was unable to start within 999 seconds.
If the server requires more
time, try increasing the timeout in the server editor.
Does anyone know where the problem comes from ? It worked before, and I do
not think i have done anything wrong with my eclipse configuration.
I found a similar problem here
https://bugs.eclipse.org/bugs/show_bug.cgi?id=237425
but there is no obvious solution.
Thanks for helping.
Re: Eclipse Ganymede : undefined command: plug-in='org.eclipse.tm.terminal' [message #229117 is a reply to message #229100] Tue, 17 March 2009 11:26 Go to previous message
sorry for the triple posting.
Someone knows what might the solution to my Eclipse Ganymede problem ?
Thanks.
Previous Topic:Eclipse Ganymede : undefined command: plug-in='org.eclipse.tm.terminal'
Next Topic:XSL Graduation/Move Review
Current Time: Mon May 20 01:20:35 EDT 2013
Powered by FUDForum. Page generated in 0.02157 seconds
