Home » Eclipse Projects » DSDP - Target Management » Failure to create ServerSocket
Failure to create ServerSocket [message #22823] Thu, 15 May 2008 12:08 Go to next message
Asai is currently offline Asai
Greetings,
I had restarted my server, and when I went to start ./daemon.pl & I get
this message Failure to create ServerSocket.
Any insights?
Re: Failure to create ServerSocket [message #22868 is a reply to message #22823] Thu, 15 May 2008 18:33 Go to previous messageGo to next message
David McKnight is currently offline David McKnight
I'm guessing that the daemon is still running on the original port. If you
need to start a new daemon on a different port you can specifiy that port as
the first arg to daemon.pl.
"Asai" <asai@globalchangemusic.org> wrote in message
news:g0hn62$sh7$1@build.eclipse.org...
> Greetings,
> Any insights?
Re: Failure to create ServerSocket [message #22910 is a reply to message #22868] Thu, 15 May 2008 18:41 Go to previous message
Ok. Problem solved. Thanks, mucho.
>> Greetings,
>> Any insights?
Re: Failure to create ServerSocket [message #574634 is a reply to message #22823] Thu, 15 May 2008 18:33 Go to previous message
> Greetings,
> Any insights?
Re: Failure to create ServerSocket [message #574651 is a reply to message #22868] Thu, 15 May 2008 18:41 Go to previous message
>> Greetings,
>> Any insights?
Previous Topic:Failure to create ServerSocket
Next Topic:Remote Indexing
Current Time: Fri May 24 09:57:29 EDT 2013
Powered by FUDForum. Page generated in 0.01662 seconds
