Home » Eclipse Projects » Web Tools Project (WTP) » An internal error occurred during: "J2EEComponentMappingUpdateJob"
An internal error occurred during: "J2EEComponentMappingUpdateJob" [message #228123] Fri, 20 February 2009 14:05
Raju Balabhadruni is currently offline Raju Balabhadruni
I am trying to export a web project from Serena Dimentions plugin... it is
giving below error message... but I am able to export all files to local
system but eclipse is not recognizing as web project. However, when I
export the same project using Dimention client and then export it to
eclipse it is working fine. I assume, wst plug-in either not able to
read/doesn't able to access required configuration file for this
project... However other web projects are working fine. Any help would be
greatly appreciated.
!SESSION 2009-02-20 10:51:10.482
eclipse.buildId=M20080911-1700
java.version=1.6.0_07
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY com.serena.eclipse.dimensions.team.core 1 -100 2009-02-20
10:52:58.433
!MESSAGE Recomputing folder status
10:52:59.064
!MESSAGE Discovering moved resources
!ENTRY org.eclipse.core.jobs 4 2 2009-02-20 10:54:03.554
!MESSAGE An internal error occurred during:
"J2EEComponentMappingUpdateJob".
!STACK 0
org.eclipse.wst.common.componentcore.internal.impl.ResourceT reeRoot.getDeployResourceTreeRoot(ResourceTreeRoot.java:124)
org.eclipse.wst.common.componentcore.internal.resources.Virt ualResource.removeLink(VirtualResource.java:301)
org.eclipse.jst.j2ee.refactor.listeners.J2EEElementChangedLi stener$1.runInWorkspace(J2EEElementChangedListener.java:157)
org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
!ENTRY org.eclipse.wst.common.frameworks 4 0 2009-02-20 11:00:56.532
!MESSAGE Exception thrown.
!STACK 0
org.eclipse.wst.common.componentcore.internal.resources.Virt ualComponent.setMetaProperty(VirtualComponent.java:182)
org.eclipse.wst.common.componentcore.internal.util.Component Utilities.setServerContextRoot(ComponentUtilities.java:314)
org.eclipse.wst.web.internal.operation.WebProjectPropertiesU pdateOperation.execute(WebProjectPropertiesUpdateOperation.j ava:43)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl$1.run(DataModelPausibleOperationImpl .java:376)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.runOperation(DataModelPausibleOperat ionImpl.java:401)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.runOperation(DataModelPausibleOperat ionImpl.java:352)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.doExecute(DataModelPausibleOperation Impl.java:242)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.executeImpl(DataModelPausibleOperati onImpl.java:214)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.cacheThreadAndContinue(DataModelPaus ibleOperationImpl.java:89)
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elPausibleOperationImpl.execute(DataModelPausibleOperationIm pl.java:202)
org.eclipse.jst.j2ee.internal.ui.J2EEPropertiesPage.performO k(J2EEPropertiesPage.java:171)
org.eclipse.jface.preference.PreferenceDialog$13.run(Prefere nceDialog.java:931)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
org.eclipse.jface.preference.PreferenceDialog.okPressed(Pref erenceDialog.java:911)
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.okP ressed(FilteredPreferenceDialog.java:440)
org.eclipse.jface.preference.PreferenceDialog.buttonPressed( PreferenceDialog.java:233)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDial ogAction.java:157)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
!ENTRY org.eclipse.jdt.ui 4 10001 2009-02-20 11:03:43.365
!MESSAGE Internal Error
!STACK 1
Java Model Exception: Java Model Status [Cannot retrieve the attached
javadoc for String [in String.class [in java.lang [in C:\Program
Files\Java\jre1.6.0_07\lib\rt.jar]]]java.net.ConnectExceptio n: Connection
refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient (Unknown
Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unk nown
Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(U nknown
Source)
org.eclipse.jdt.internal.core.JavaElement.getURLContents(Jav aElement.java:751)
org.eclipse.jdt.internal.core.BinaryType.getJavadocContents( BinaryType.java:1059)
org.eclipse.jdt.internal.core.BinaryType.getAttachedJavadoc( BinaryType.java:971)
org.eclipse.jdt.internal.ui.text.javadoc.JavadocContentAcces s2.getHTMLContent(JavadocContentAccess2.java:98)
org.eclipse.jdt.internal.ui.text.java.ProposalInfo.extractJa vadoc(ProposalInfo.java:96)
org.eclipse.jdt.internal.ui.text.java.ProposalInfo.computeIn fo(ProposalInfo.java:76)
org.eclipse.jdt.internal.ui.text.java.ProposalInfo.getInfo(P roposalInfo.java:59)
org.eclipse.jdt.internal.ui.text.java.AbstractJavaCompletion Proposal.getAdditionalProposalInfo(AbstractJavaCompletionPro posal.java:510)
org.eclipse.jdt.internal.ui.text.java.AbstractJavaCompletion Proposal.getAdditionalProposalInfo(AbstractJavaCompletionPro posal.java:501)
org.eclipse.jdt.internal.ui.text.java.LazyJavaCompletionProp osal.getAdditionalProposalInfo(LazyJavaCompletionProposal.ja va:252)
org.eclipse.jst.jsp.ui.internal.contentassist.JSPCompletionP roposal.getAdditionalProposalInfo(JSPCompletionProposal.java :61)
org.eclipse.jface.text.contentassist.AdditionalInfoControlle r$6.run(AdditionalInfoController.java:165)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
org.eclipse.jdt.internal.core.JavaElement.getURLContents(Jav aElement.java:796)
!SUBENTRY 1 org.eclipse.jdt.core 4 1008 2009-02-20 11:03:43.365
!MESSAGE Cannot retrieve the attached javadoc for String [in String.class
refused: connect
Source)
Source)
Source)
Previous Topic:How to add actions to vertical ruler?
Next Topic:Custom Outline View for HTML files
Current Time: Tue May 21 23:38:53 EDT 2013
Powered by FUDForum. Page generated in 0.01524 seconds
