Home » Eclipse Projects » Web Tools Project (WTP) » Trying to incorporate WST XML editor into RCP application and open for a disk file
Trying to incorporate WST XML editor into RCP application and open for a disk file [message #227546] Thu, 05 February 2009 18:42 Go to next message
Lawrence G is currently offline Lawrence G
Hello--looking around for a simple code sample of invoking the WST XML
editor from an RCP application that has added in the WTP plug-ins. Can
anyone point me at a code sample that opens up the WST XML Editor given
a particular file on the disk? I've trolled around the web for several
days now, and have most of the information around incorporating the
editor, but it's seeing an actual example which could get me across the
finish line.
Many thanks...Lawrence
Re: Trying to incorporate WST XML editor into RCP application and open for a disk file [message #227573 is a reply to message #227546] Mon, 09 February 2009 13:17 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
> finish line.
It shouldn't be significantly different from opening any other
editor on a file on disk. You'll probably want to dig through how
org.eclipse.ui.ide.IDE.openEditor(IWorkbenchPage, URI, String,
boolean) [from the org.eclipse.ui.ide plug-in] is implemented,
assuming you can't call it directly.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:Publish deletes read-only files
Next Topic:API for new servers
Current Time: Sat May 25 12:52:39 EDT 2013
Powered by FUDForum. Page generated in 0.01546 seconds
