I get the below error when i validate a WSDL file -
"The 'NewWSDLFile' port type specified for the 'NewWSDLFileSOAP' binding
is undefined. Check the 'NewWSDLFile' port type name and ensure it is
defined."
Initially i thought this could be because i dont have a xsd for the policy
i defined in operation tag, so i also added a reference to the policy XSD
but still the problem is not resolved.
But if if remove the policy tag in the operation tag then it works fine
and no error is reported.
WTP 3.0 does not support extensibility elements for operations.
Your scenario is similar to the one reported in https://bugs.eclipse.org/bugs/show_bug.cgi?id=235821 and is caused by a
discrepancy between the WSDL schema and the JWSDL/WSDL4J version used by the
WSDL validator.
"Keshavrao " <keshavrao.veerapaneni@sap.com> wrote in message
news:38e9ae12b0010e890a5ee02514293acf$1@www.eclipse.org...
> defined."
> you can download the policy XSD from -
> http://schemas.xmlsoap.org/ws/2004/09/policy/ws-policy.xsd
> <?xml version="1.0" encoding="UTF-8" standalone="no"?>
> <wsdl:definitions xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/"
> xmlns:tns="http://www.example.org/NewWSDLFile/"
> xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema" name="NewWSDLFile"
> targetNamespace="http://www.example.org/NewWSDLFile/"
> xmlns:wsp="http://schemas.xmlsoap.org/ws/2004/09/policy policy.xsd">
> <wsdl:types>
> <xsd:schema targetNamespace="http://www.example.org/NewWSDLFile/">
> <xsd:element name="NewOperation">
> <xsd:complexType>
> <xsd:sequence>
> <xsd:element name="in" type="xsd:string" />
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> <xsd:element name="NewOperationResponse">
> <xsd:complexType>
> <xsd:sequence>
> <xsd:element name="out" type="xsd:string" />
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
> </wsdl:types>
> <wsdl:message name="NewOperationRequest">
> <wsdl:part element="tns:NewOperation" name="parameters" />
> </wsdl:message>
> <wsdl:message name="NewOperationResponse">
> <wsdl:part element="tns:NewOperationResponse" name="parameters" />
> </wsdl:message>
> <wsdl:portType name="NewWSDLFile">
> <wsdl:operation name="NewOperation">
> <wsp:Policy>
> <wsp:PolicyReference URI="http://example.uri" />
> </wsp:Policy>
> <wsdl:input message="tns:NewOperationRequest" />
> <wsdl:output message="tns:NewOperationResponse" />
> </wsdl:operation>
> </wsdl:portType>
> <wsdl:binding name="NewWSDLFileSOAP" type="tns:NewWSDLFile">
> <soap:binding style="document"
> transport="http://schemas.xmlsoap.org/soap/http" />
> <soap:operation
> soapAction="http://www.example.org/NewWSDLFile/NewOperation" />
> <wsdl:input>
> <soap:body use="literal" />
> </wsdl:input>
> <wsdl:output>
> </wsdl:output>
> </wsdl:operation>
> </wsdl:binding>
> <wsdl:service name="NewWSDLFile">
> <wsdl:port binding="tns:NewWSDLFileSOAP" name="NewWSDLFileSOAP">
> <soap:address location="http://www.example.org/" />
> </wsdl:port>
> </wsdl:service>
> </wsdl:definitions>
> Thanks and regards,
> Keshav Veerapaneni.
