Home » Eclipse Projects » Web Tools Project (WTP) » Dependent projects not deploying
Dependent projects not deploying [message #227143] Fri, 23 January 2009 18:34 Go to next message
rektide is currently offline rektide
Greetings all;
I have a small army of dependent projects checked in Java EE Modules /
listed in my Web App Libraries in the Build Path, but none of them get
deployed (to Tomcat 6.0.14): my WEB-INF/lib and WEB-INF/classes only
retain the classes in my main project. Each of these dependent projects
has a ton of class and other files in their output folder, yet none of
them make it into the deploy. I'm using the latest from WTP 3.0.3
software updates repo.
Presently I'm looking for the deployed contents in:
~/workspaces/wtp/.metadata/.plugins/org.eclipse.wst.server.c ore/tmp0/wtpwebapps/myWebProject/WEB-INF/classes
What do I need to do to get my Web App Libraries deploying? What
debugging information can I look at to see how this is failing?
-rektide
Re: Dependent projects not deploying [message #227215 is a reply to message #227143] Mon, 26 January 2009 09:13 Go to previous message
Larry Isaacs is currently offline Larry Isaacs
rektide wrote:
> Greetings all;
> -rektide
Are you able to duplicate this behavior in a new workspace with some
simple projects? If so, post the steps you used so we can attempt to
duplicate. If not, we will need to figure out what is unique about your
original workspace.
Larry
Previous Topic:sharing resources between dynamic web projects
Next Topic:Problem in developing WebApplication
Current Time: Mon May 20 12:21:14 EDT 2013
Powered by FUDForum. Page generated in 0.01886 seconds
