| jsNature causing problem markers [message #226927] |
Wed, 21 January 2009 09:42  |
Michael Giroux Messages: 78 Registered: July 2009 Location: Phoenix, AZ |
Member |
The project that I'm working on contains a folder named 'js' containing
various javascript sources. When I add jsNature to the .project, I am
getting several problem markers due to unresolved symbols.
The project runs without errors in a browser, but the design time Eclipse
environment is flagging all sorts of errors.
I have included my 'js' folder as a library folder, but I'm still getting
several error markers. The errors are not consistent within a file
either. For example, I have a source with two functions:
function a() {
var x = commentForm.getElement('id'); // <-- no errors here
return x;
function b() {
if (!isEmpty(commentForm.getElement('id')) return true; // <--
commentForm undefined here
return false;
In function a(), the reference to commentForm does not raise an error.
In function b(), the reference to commentForm as an argument to the
isEmpty method produces a problem marker indicating commentForm cannot be
resolved.
So far, I don't see a pattern to when a references causes a validation
error and when it doesn't.
Any pointers to docs that might get me back on track will be appreciated.
Michael
| Re: jsNature causing problem markers [message #226934 is a reply to message #226927] |
Wed, 21 January 2009 10:17  |
Member |
Another example:
var counter = document.createElement('div');
textField.relatedElement = counter.getElementsByTagName('span')[0];
For the above, I'm getting a problem marker:
The function getElementsByTagName(String) is undefined for the type
___counter3
It appears that jsNature is enforcing stricter syntax than the browser is.
How should the above be coded to avoid the problem marker?
Michael
FUDForum. Page generated in 0.04651 seconds
