Home » Eclipse Projects » Web Tools Project (WTP) » Docbook XML Transformation JAXPSAXProcessorInvoker XPath error
Docbook XML Transformation JAXPSAXProcessorInvoker XPath error [message #226758] Thu, 15 January 2009 13:41 Go to next message
Eric Bresie is currently offline Eric Bresie
Member
I working on some XML / XSL Transformation based on an older article (see
http://www.vogella.de/articles/DocBook/article.html ) which talks
""DocBook and XSLT conversion with Eclipse and Apache Ant - Tutorial".
Rather than use the ant based transformation, I decided to try using an
XSL Run Configuration.
I created a General Project.
Created a src and output folders
I am using the example from the article which looks like the following:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!DOCTYPE article PUBLIC "-//OASIS//DTD DocBook XML V4.5//EN"
"../docbook-xml-4.5/docbookx.dtd">
<article>
<articleinfo>
<title>DocBook Intro</title>
<author>
<firstname>Firstname</firstname>
<surname>Lastname</surname>
</author>
</articleinfo>
<sect1 label="1.0">
<title>An introduction to DocBook</title>
<para>
This is text.
</para>
</sect1>
</article>
* Slightly modified for my purposes; I tried with and without the last tag
which I suspect may be incorrect)
Copied the docbook XSL and XML folders/files
In the configuration, I set for the XML Input File, using Workspace... to
select the file.
On a side note, when I selected it, it put
${workspace_loc:/DocbookProject/src/ExampleArticle.xml}
Is this correct or should it have inserted something like:
${workspace_loc}/DocbookProject/src/ExampleArticle.xml
Transformation Pipeline: selected the html\docbook.xsl which I want to
transform the Docbook XML file into a basic HTML file.
Processor: to be JRE Instance Default.
Output File..Location to be
${workspace_loc}/DocbookProject/output/ExampleArticle.out.xm l
JRE: to be 1.6.0_11.
Now when I run the XSL tranformation, there are a number of WARN items
(which I don't believe are of significance) and a couple of ERRORs. See
below.
Isn't test="* or $generate.index != 0" a valid test expression?
Is this a bug? Is this a problem with my XML? My XSL?
Any help is appreciated..
Eric
Environment:
Eclipse 3.4.1
(M20080911-1700)
Web Standard Tools SDK:
Version: 3.0.3.v200809250443-7D-8l8XkDnRhz-ylP58ABwz-FP3f
Build id: 20080918035538
Web Standard Tools:
Version: 3.0.3.v200809250443-7A-8i8Qqcz0FaVgjXSD6brFQN64Z
WTP XSL Tools
Version: 0.5.0.v200808041223-6872EC3wSUIU7eJGVdY_1
Build id: 20080820002020
12:37:33,957 INFO [main] Main -
javax.xml.transform.TransformerFactory=null
12:37:33,988 INFO [main] Main - java.endorsed.dirs=C:\Program
Files\Java\jdk1.6.0_11\jre\lib\endorsed
12:37:34,066 INFO [main] Main - launchFile:
E:\workspace\.metadata\.plugins\org.eclipse.wst.xsl.launchin g\launch\launch.xml
12:37:39,921 WARN [main] JAXPSAXProcessorInvoker -
file:/E:/workspace/DocbookProject/docbook-xsl-1.74.0/html/au toidx.xsl:
line 476: Attribute 'href' outside of element.
line 514: Attribute 'href' outside of element.
line 537: Attribute 'href' outside of element.
file:/E:/workspace/DocbookProject/docbook-xsl-1.74.0/html/ca llout.xsl:
line 105: Attribute 'href' outside of element.
file:/E:/workspace/DocbookProject/docbook-xsl-1.74.0/html/xr ef.xsl: line
177: Attribute 'href' outside of element.
968: Attribute 'href' outside of element.
file:/E:/workspace/DocbookProject/docbook-xsl-1.74.0/html/in line.xsl: line
97: Attribute 'href' outside of element.
138: Attribute 'href' outside of element.
12:37:39,952 WARN [main] JAXPSAXProcessorInvoker -
148: Attribute 'target' outside of element.
175: Attribute 'href' outside of element.
701: Attribute 'href' outside of element.
922: Attribute 'href' outside of element.
1047: Attribute 'href' outside of element.
1178: Attribute 'href' outside of element.
1279: Attribute 'href' outside of element.
1316: Attribute 'href' outside of element.
file:/E:/workspace/DocbookProject/docbook-xsl-1.74.0/html/gl ossary.xsl:
line 253: Attribute 'href' outside of element.
line 315: Attribute 'href' outside of element.
file:/E:/workspace/DocbookProject/docbook-xsl-1.74.0/html/an notations.xsl:
line 117: Attribute 'onClick' outside of element.
12:37:39,952 ERROR [main] JAXPSAXProcessorInvoker - Syntax error in '* or
$generate.index != 0'.
file:/E:/workspace/DocbookProject/docbook-xsl-1.74.0/html/au totoc.xsl:
line 373: Error parsing XPath expression '* or $generate.index != 0'.
line 373: Required attribute 'test' is missing.
line 492: Error parsing XPath expression '* or $generate.index != 0'.
line 492: Required attribute 'test' is missing.
12:37:39,998 ERROR [main] JAXPSAXProcessorInvoker - Could not compile
stylesheet
javax.xml.transform.TransformerConfigurationException: Could not compile
stylesheet
com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFact oryImpl.newTemplates(TransformerFactoryImpl.java:825)
com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFact oryImpl.newTransformer(TransformerFactoryImpl.java:614)
com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFact oryImpl.newTransformerHandler(TransformerFactoryImpl.java:90 0)
org.eclipse.wst.xsl.invoker.JAXPSAXProcessorInvoker.addStyle sheet(JAXPSAXProcessorInvoker.java:132)
org.eclipse.wst.xsl.invoker.JAXPSAXProcessorInvoker.addStyle sheet(JAXPSAXProcessorInvoker.java:123)
org.eclipse.wst.xsl.invoker.config.PipelineDefinition.config ure(PipelineDefinition.java:163)
at org.eclipse.wst.xsl.invoker.Main.main(Main.java:71)
12:37:40,029 FATAL [main] Main - Error with stylesheet:
file:/E:/workspace/DocbookProject/docbook-xsl-1.74.0/html/do cbook.xsl
org.eclipse.wst.xsl.invoker.ConfigurationException: Error with stylesheet:
org.eclipse.wst.xsl.invoker.config.PipelineDefinition.config ure(PipelineDefinition.java:167)
Re: Docbook XML Transformation JAXPSAXProcessorInvoker XPath error [message #226766 is a reply to message #226758] Thu, 15 January 2009 13:44 Go to previous messageGo to next message
Member
Correction:
Originally the last tag in the example was an "</xi:include>". I removed
for posting purposes. I did not omit the last "</article>" tag.
Eric
Re: Docbook XML Transformation JAXPSAXProcessorInvoker XPath error [message #226775 is a reply to message #226758] Thu, 15 January 2009 14:41 Go to previous message
Eclipse User
Originally posted by: dcarver.starstandard.org
Hi Eric. I'm a committer on XSL Tools, and use Docbook with it quite
frequently. I'll try and answer your questions below.
> (see http://www.vogella.de/articles/DocBook/article.html ) which talks
> <article>
> <articleinfo>
> <author>
> </author>
> </articleinfo>
> <sect1 label="1.0">
> <para> This is text.
> </para>
> </sect1>
> </article>
> tag which I suspect may be incorrect)
> to select the file.
The above is correct. The later will work as well, but the one it puts
there is correct.
The Docbook Stylsheets are known to have problems with the Default JRE
because it compiles them using XSLTC. I recommend specifically using
the Xalan processor and not the default JRE processor.
> below.
Try running it with Xalan as the processor in Interpretive mode.
Also, if any of the articles have XInclude in them, then you need to
pre-process them with them first. One of the items we need to do is
add this pre-processing as an option for the pipeline.
Since you are using XSL Tools it does include an XInclude ant task, that
can be used to pre-process the xml files. You can see how to use it here:
http://wiki.eclipse.org/Authoring_Eclipse_Help_Using_DocBook
Any other questions please post them to the group and I'll see if I can
answer them.
Dave
Previous Topic:Re: Bug life cycle ?
Next Topic:Eclipse and Glassfish
Current Time: Sat May 25 08:56:14 EDT 2013
Powered by FUDForum. Page generated in 0.01660 seconds
