Home » Eclipse Projects » Riena » As my Widget may become a Ridget?
| Re: As my Widget may become a Ridget? [message #18465 is a reply to message #18455] |
Fri, 02 January 2009 09:10   |
Jose Carlos de Missias Messages: 41 Registered: July 2009 |
Member |
Christian Campo wrote:
Hi Jose,
unfortunatelly we dont yet have a cookbook what you need to do to write
your own ridget. But I try help you little bit.
Yes a ridget must implement IRidget. However there a number of Abstract
classes that already implement that interface
minus a few methods. So maybe you like to pick one of these dependending
on what you like to do.
There is AbstractRidget, AbstractSWTRidget or even AbstractValueRidget
(for textentry fields). These abstract classes
already contain some code. Then you need to add that new Ridget to a
mapping table for which we currently have no API
:-(. So you need to import that project into your workspace and manuelly
edit that class DefaultSwtControlRidgetMapper.
> I am sure that code in initDefaultMappings is easy enough to understand
without explanation.
> So these are the basics. However I vaguely remember that you wanted an
editable table cell in the past (september). We
> (Elias) are currently looking into that and that is a little more tricky.
Because up until now the View creates the
> widgets and the control programs against the ridgets to control the widgets.
With Table Cells it is trickier because of
> the dynamic nature of tables. Rows are added at runtime and you need to be
able to create Ridgets and Widgets from the
> controller. As I said Elias is currently investigating how we can do that.
> That feature will like not end up in Release 1.0 (which we hope to do end of
January) but could be ready in time after
> that when we release 1.1. with the Galileo release train. We have to see how
it goes.
> Does that help ?
> - christian
> Jose Carlos de Missias schrieb:
>> Hi to all,
>> Precise manipulate a specific widget in my SubModuleControllers, however
>> the environment of Riena only accepts Ridget. How to make my widget a
>> Ridget? I must implement IRidget?
>> tanks!
Hi Christian,
Their explanation helped me a lot to extend my knowledge about the
environment RIENA, which I am loving work and happy have chosen "RIENA"
technology to concretize my project.
You this true, in the past in September 2008, I asked on editable table
cell, and this Widget which I would like to create a wrapper to give
Ridget characteristics is the AgileGrid (www.agilemore.com), a implement
of table control based on the Eclipse SWT, I have familiarised enough and
maintained a synergy very good with Sihong Zhu, creator and leader of the
project.
My project is a tool of BI, I and my two partners we have reached the
conclusion that it is a characteristic indispensable useability for the
project that entries registrational were preferentially through Grid
instead of forms.
I will follow their tips and I will keep you and all of my advances.
I wish you, much success, peace and harmony, and that
2009 be a year full of dreams implemented.
happy new year !!!
Always Grateful,
José Carlos de Missias
| Re: As my Widget may become a Ridget? [message #18474 is a reply to message #18465] |
Fri, 02 January 2009 09:47   |
Originally posted by: ekkehard.gentz-software.de
....think we also have to create custom ridgets in the future,
so an API would be great
and also there should be a place to describe custom ridgets
in the Riena wiki with download link (if Open Source)
ekke
> Hi Jose,
> classes that already implement that interface minus a few methods. So
> maybe you like to pick one of these dependending on what you like to do.
> (for textentry fields). These abstract classes already contain some
> code. Then you need to add that new Ridget to a mapping table for which
> we currently have no API :-(. So you need to import that project into
> your workspace and manuelly edit that class DefaultSwtControlRidgetMapper.
>> widgets.
>> to be
>> that.
>> end of
>> see how
> it goes.
>> Does that help ?
>> - christian
>>> Hi to all,
>>> however the environment of Riena only accepts Ridget. How to make my
>>> widget a Ridget? I must implement IRidget?
>>> tanks!
> Hi Christian,
> and maintained a synergy very good with Sihong Zhu, creator and leader
> of the project.
> instead of forms.
> happy new year !!!
> Always Grateful,
| Re: As my Widget may become a Ridget? [message #18481 is a reply to message #18474] |
Fri, 02 January 2009 11:41   |
Member |
> ekke
>> Hi Jose,
>>> widgets.
>>> to be
>>> that.
>>> end of
>>> see how
>> it goes.
>>> Does that help ?
>>> - christian
>>>> Hi to all,
>>>> tanks!
>> Hi Christian,
>> of the project.
>> instead of forms.
>> happy new year !!!
>> Always Grateful,
I agree with Ekke in all its consideration
| Re: As my Widget may become a Ridget? [message #18497 is a reply to message #18481] |
Mon, 05 January 2009 04:29   |
Christian Campo Messages: 578 Registered: July 2009 |
>> ekke
>>> Hi Jose,
>>> write your own ridget. But I try help you little bit.
>>> Abstract classes that already implement that interface minus a few
>>> methods. So maybe you like to pick one of these dependending on what
>>> you like to do.
>>> AbstractValueRidget (for textentry fields). These abstract classes
>>> mapping table for which we currently have no API :-(. So you need to
>>> import that project into your workspace and manuelly edit that class
>>>> tricky.
>>>> widgets.
>>>> to be
>>>> that.
>>>> do end of
>>>> see how
>>> it goes.
>>>> Does that help ?
>>>> - christian
>>>>> Hi to all,
>>>>> my widget a Ridget? I must implement IRidget?
>>>>> tanks!
>>> Hi Christian,
>>> "RIENA" technology to concretize my project.
>>> table cell, and this Widget which I would like to create a wrapper to
>>> give Ridget characteristics is the AgileGrid (www.agilemore.com), a
>>> implement of table control based on the Eclipse SWT, I have
>>> familiarised enough and maintained a synergy very good with Sihong
>>> Zhu, creator and leader of the project.
>>> the project that entries registrational were preferentially through
>>> Grid instead of forms.
>>> happy new year !!!
>>> Always Grateful,
Cool and good that you love Riena. It is really a lot of motivation for us !!!
The way to get something from us or request something is really Bugzilla. So I think having Custom Ridgets and
have an open API for that is a very good point and we will do it sooner or later. It would be good if either of you
interested in this, would open a Bugzilla.
The newsgroup is for discussion, we dont derive our task list from it but we look at the bugzilla entries.
regards
christian
| Re: As my Widget may become a Ridget? [message #18515 is a reply to message #18497] |
Mon, 05 January 2009 04:43   |
>>> ekke
>>>> Hi Jose,
>>>> you like to do.
>>>>> understand
>>>>> tricky.
>>>>> widgets.
>>>>> need to be
>>>>> do that.
>>>>> do end of
>>>>> to see how
>>>> it goes.
>>>>> Does that help ?
>>>>> - christian
>>>>>> Hi to all,
>>>>>> tanks!
>>>> Hi Christian,
>>>> to give Ridget characteristics is the AgileGrid (www.agilemore.com),
>>>> a implement of table control based on the Eclipse SWT, I have
>>>> the conclusion that it is a characteristic indispensable useability
>>>> for the project that entries registrational were preferentially
>>>> through Grid instead of forms.
>>>> happy new year !!!
>>>> Always Grateful,
> us !!!
> regards
> christian
Bugzilla 259937 opened
ekke
| Re: As my Widget may become a Ridget? [message #577531 is a reply to message #17735] |
Fri, 02 January 2009 07:19  |
Hi Jose,
unfortunatelly we dont yet have a cookbook what you need to do to write your own ridget. But I try help you little bit.
Yes a ridget must implement IRidget. However there a number of Abstract classes that already implement that interface
minus a few methods. So maybe you like to pick one of these dependending on what you like to do.
There is AbstractRidget, AbstractSWTRidget or even AbstractValueRidget (for textentry fields). These abstract classes
already contain some code. Then you need to add that new Ridget to a mapping table for which we currently have no API
:-(. So you need to import that project into your workspace and manuelly edit that class DefaultSwtControlRidgetMapper.
I am sure that code in initDefaultMappings is easy enough to understand without explanation.
So these are the basics. However I vaguely remember that you wanted an editable table cell in the past (september). We
(Elias) are currently looking into that and that is a little more tricky. Because up until now the View creates the
widgets and the control programs against the ridgets to control the widgets. With Table Cells it is trickier because of
the dynamic nature of tables. Rows are added at runtime and you need to be able to create Ridgets and Widgets from the
That feature will like not end up in Release 1.0 (which we hope to do end of January) but could be ready in time after
that when we release 1.1. with the Galileo release train. We have to see how it goes.
Does that help ?
- christian
> Hi to all,
> tanks!
| Re: As my Widget may become a Ridget? [message #577553 is a reply to message #18455] |
Member |
Hi Jose,
it goes.
> Does that help ?
> - christian
>> Hi to all,
>> tanks!
Hi Christian,
project.
instead of forms.
happy new year !!!
Always Grateful,
| Re: As my Widget may become a Ridget? [message #577578 is a reply to message #18465] |
ekke
> Hi Jose,
>> widgets.
>> to be
>> that.
>> end of
>> see how
> it goes.
>> Does that help ?
>> - christian
>>> Hi to all,
>>> tanks!
> Hi Christian,
> of the project.
> instead of forms.
> happy new year !!!
> Always Grateful,
| Re: As my Widget may become a Ridget? [message #577596 is a reply to message #18474] |
Member |
> ekke
>> Hi Jose,
>>> widgets.
>>> to be
>>> that.
>>> end of
>>> see how
>> it goes.
>>> Does that help ?
>>> - christian
>>>> Hi to all,
>>>> tanks!
>> Hi Christian,
>> of the project.
>> instead of forms.
>> happy new year !!!
>> Always Grateful,
| Re: As my Widget may become a Ridget? [message #577637 is a reply to message #18481] |
>> ekke
>>> Hi Jose,
>>> you like to do.
>>>> tricky.
>>>> widgets.
>>>> to be
>>>> that.
>>>> do end of
>>>> see how
>>> it goes.
>>>> Does that help ?
>>>> - christian
>>>>> Hi to all,
>>>>> tanks!
>>> Hi Christian,
>>> happy new year !!!
>>> Always Grateful,
regards
christian
| Re: As my Widget may become a Ridget? [message #577674 is a reply to message #18497] |
>>> ekke
>>>> Hi Jose,
>>>> you like to do.
>>>>> understand
>>>>> tricky.
>>>>> widgets.
>>>>> need to be
>>>>> do that.
>>>>> do end of
>>>>> to see how
>>>> it goes.
>>>>> Does that help ?
>>>>> - christian
>>>>>> Hi to all,
>>>>>> tanks!
>>>> Hi Christian,
>>>> happy new year !!!
>>>> Always Grateful,
> us !!!
> regards
> christian
ekke
Current Time: Thu May 23 15:26:30 EDT 2013
Powered by FUDForum. Page generated in 0.02299 seconds
