| Which tools I need for quick and easy Web application creating? [message #224770] |
Mon, 08 December 2008 12:18  |
Originally posted by: pascal.po.t-com.hr
Can you help me with the tools which I need for a quick and easy web
applications creating. I try iceFaces but still don't have a nice
insert/edit table for database data, while I try MS Visual studio express
edition and you got that with the few clicks.
| Re: Which tools I need for quick and easy Web application creating? [message #224777 is a reply to message #224770] |
Mon, 08 December 2008 12:44   |
"Mario" <pascal@po.t-com.hr> wrote in message
news:ghjksi$73h$1@build.eclipse.org...
Don't correct me wrong, I like Eclipse, java alltogether on Ubuntu, but I
must said that when I saw the inuitive of Visual studio, C# and
everythingYouNeedIsHere I regret why I need a lots of time just to find some
usufull component which came in NETframework, by default.
| Re: Which tools I need for quick and easy Web application creating? [message #224830 is a reply to message #224777] |
Mon, 08 December 2008 21:24   |
Russell Bateman Messages: 2711 Registered: July 2009 Location: Provo, Utah, USA |
Mario,
Reading your question I immediately said to myself that I was going to
be very interested in hearing the responses to it. And I still am.
I'll just say that if you don't mind limiting yourself to a single,
expensive platform with few choices for your customers, then by all
means use C#/.NET, and especially if you're the only one that's ever
going to use it.
I am attracted by the "open" aspect of Java, though I don't also believe
that is a reason to suffer. I do hope that my community will continue to
improve things.
Russ Bateman
| Re: Which tools I need for quick and easy Web application creating? [message #224856 is a reply to message #224830] |
Tue, 09 December 2008 12:12  |
"Windofkeltia" <russ@windofkeltia.com> wrote in message
news:ghkl16$ku4$1@build.eclipse.org...
>>> express edition and you got that with the few clicks.
>> some usufull component which came in NETframework, by default.
> Mario,
> Reading your question I immediately said to myself that I was going to be
> expensive platform with few choices for your customers, then by all means
> use C#/.NET, and especially if you're the only one that's ever going to
> use it.
> improve things.
I'm also attracted with the "open", linux stability, Eclipse stability, but
you must understand that I, as beginner, wish to be constructive with the
critics. I would like it to someone make a tutorial or Eclipse
everythingYouNeedIsHere version for students and hobist. That is stilling
Microsoft idea, like MS was stilled Java and created C#.
Few years ago, when I wrote my first standalone application, I think that it
will be a lots of java standalone applications on linux, you must admit that
it is not a case if you use Ubuntu for example.
p.s.
Concreete problem:
I tried iceFaces and Apache Trinidad looking for a DataTable for my Web
application through I can insert/edit/delete my Derby database data. I tried
to google: DataTable & jspx & ..... still nothing. Could you please show me
the easiest way to handle that.
FUDForum. Page generated in 0.01701 seconds
