Home » Eclipse Projects » Web Tools Project (WTP) » Can not install WTP 3.0.2, version problem
Can not install WTP 3.0.2, version problem [message #223977] Tue, 18 November 2008 15:36 Go to next message
Rich Scott is currently offline Rich Scott
Member
I've been trying to install WTP3.0.2/Web Developer Tools SDK into my
Ganymede SR1 environment. The update process fails due to an unsatisfied
version of org.eclipse.emf.codegen.
From the following message, it appears that something requires an exact
match for version 2.2.1.v200609210005 which can not be found. The same
error occurs for 3.0.3
Cannot find a solution satisfying the following requirements
Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.emf.codegen/[2.2.1.v20 0609210005,2.2.1.v200609210005]].
I an using the http://download.eclipse.org/webtools/updates/ update site.
Any ideas on how to proceed?
Rich
Re: Can not install WTP 3.0.2, version problem [message #224037 is a reply to message #223977] Wed, 19 November 2008 12:51 Go to previous messageGo to next message
Eclipse User
Originally posted by: david_williams.linux.vnet.ibm.com
The first idea would be to try again. There were some problems with the
update site introduced last weekend, and fixed only late last night.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=255455
Re: Can not install WTP 3.0.2, version problem [message #224058 is a reply to message #224037] Thu, 20 November 2008 10:48 Go to previous message
Member
David,
Thanks for the information. You are correct, the problem has been resolved
and I am now able to install install WTP3.0.2/Web Developer Tools from the
update site.
Rich
Previous Topic:New to JSP +
Next Topic:why is org.eclipse.tomcat removed?
Current Time: Sat May 25 14:08:04 EDT 2013
Powered by FUDForum. Page generated in 0.06814 seconds
