Home » Eclipse Projects » Web Tools Project (WTP) » Newbie: Security Filter Not Functioning
Newbie: Security Filter Not Functioning [message #223809] Thu, 13 November 2008 12:53 Go to next message
Jonathan O'Donovan is currently offline Jonathan O'Donovan
Hi All,
I am having a problem with the Tomcat security filter when deploying using
Web Tools Platform. I am running the following
Eclipse Ganymede V3.4.1
Web Tools : 1.1.20x
Tomcat 4.1
JSDK 1.6
I have added the project to the server with no problems and can
execute/step through servlets on the server. If I disable the security
filter by commenting
it out of web.xml the site functions the same as a non Eclipse deploy.
However, if I include the security config, it does not appear to be
functioning and I cannot log into my site (the security filter controls
this) when running/debugging within Eclipse.
The security filter is set up in web.xml as follows :
<filter>
<filter-name>Security Filter</filter-name>
<filter-class>org.securityfilter.filter.SecurityFilter</filter-class >
<init-param>
<param-name>config</param-name>
<param-value>/WEB-INF/securityfilter-config.xml</param-value >
<description>Configuration file location (this is the default
value)</description>
</init-param>
<init-param>
<param-name>validate</param-name>
<param-value>true</param-value>
<description>Validate config file if set to true</description>
</init-param>
<init-param>
<param-name>loginSubmitPattern</param-name>
<param-value>/sflogin</param-value>
<description>This is the action used by the login form (in place of the
standard "j_security_check")</description>
</init-param>
</filter>
<!-- map all requests to the SecurityFilter, control what it does with
configuration settings -->
<filter-mapping>
<url-pattern>/*</url-pattern>
</filter-mapping>
<security-role>
<role-name>administrator</role-name>
</security-role>
<security-role>
<role-name>user</role-name>
</security-role>
The security filter config file is as follows :
<securityfilter-config>
<security-constraint>
<display-name>The Customer area of the XXX web site.</display-name>
<web-resource-collection>
<web-resource-name>UserArea</web-resource-name>
<url-pattern>/servUserArea</url-pattern>
</web-resource-collection>
<auth-constraint>
</auth-constraint>
</security-constraint>
<display-name>Administration of the XX Web site.</display-name>
<web-resource-name>AdminArea</web-resource-name>
<url-pattern>/servAdminArea</url-pattern>
<auth-constraint>
</auth-constraint>
<login-config>
<auth-method>FORM</auth-method>
<form-login-config>
<form-login-page>/servPublicArea?view=login</form-login-page >
<form-error-page>/servPublicArea?view=loginerror</form-error-page >
<form-default-page>/servUserArea?view=usermain</form-default-page >
</form-login-config>
</login-config>
<!-- start with a Catalina realm adapter to wrap the Catalina realm
defined below -->
<realm className="org.securityfilter.realm.catalina.CatalinaRealmAdapter "
<realm className="org.apache.catalina.realm.JDBCRealm">
<realm-param name="connectionName" value="client"/>
<realm-param name="connectionPassword" value="XXX"/>
<realm-param name="connectionURL" value="XXX"/>
<realm-param name="driverName" value="oracle.jdbc.driver.OracleDriver"/>
<realm-param name="userCredCol" value="password"/>
<realm-param name="userNameCol" value="username"/>
<realm-param name="userTable" value="auth_users"/>
<realm-param name="roleNameCol" value="role_name"/>
<realm-param name="userRoleTable" value="tomcat_roles"/>
<realm-param name="debug" value="1"/>
</realm>
</securityfilter-config>
The site works fine when I set it up on a normal Tomcat installation (ie
without Eclipse/WTP) so I know there is no problem connecting to the
database realm.
I am wondering if anyone can point me in the right direction here. Any
suggestions would be helpful.
Many thanks in advance,
Jonathanin use is 6.0 and I am running Eclipse Ganymede
Re: Newbie: Security Filter Not Functioning [message #223819 is a reply to message #223809] Thu, 13 November 2008 13:28 Go to previous message
Larry Isaacs is currently offline Larry Isaacs
For details about the Tomcat support in WTP, see
http://wiki.eclipse.org/WTP_Tomcat_FAQ.
Obviously there is something different between the Tomcat server running
externally and the one running inside Eclipse. By default, a primary
difference between such external and Eclipse Tomcats is that the
external Tomcat is running with catalina.base and catalina.home set to
the same value. For the Eclipse Tomcat, catalina.home is set the same
as in the external Tomcat, but catalina.base is set to a different
location. There isn't enough info to tell if this could be causing your
problem.
Also, if I recall correctly, by default not all log output from Tomcat
4.1 would appear in the Console view. You might check of the "log"
directory in the instance location[1] for the Eclipse Tomcat for
additional log output that might provide a clue.
Larry
[1]
http://wiki.eclipse.org/WTP_Tomcat_FAQ#If_my_Tomcat_server_i s_using_a_separate_instance.2C_how_do_I_find_the_location_of _this_separate_instance.3F
Jonathan O'Donovan wrote:
> Hi All,
> using Web Tools Platform. I am running the following
> Web Tools : 1.1.20x Tomcat 4.1
> JSDK 1.6
> <filter>
> <init-param>
> default value)</description>
> </init-param>
> <init-param>
> </init-param>
> <init-param>
> place of the standard "j_security_check")</description>
> </init-param>
> </filter>
> with configuration settings -->
> <filter-mapping>
> </filter-mapping>
> <security-role>
> </security-role>
> <security-role>
> </security-role>
> <auth-constraint>
> </auth-constraint>
> <auth-constraint>
> </auth-constraint>
> <login-config>
> <form-login-config>
> </login-config>
> defined below -->
> <realm
> className="org.securityfilter.realm.catalina.CatalinaRealmAdapter " />
> </realm>
> database realm.
Previous Topic:Special
Next Topic:[Adopter] Another project facets question
Current Time: Tue May 21 17:27:30 EDT 2013
Powered by FUDForum. Page generated in 0.05444 seconds
