| Re: Unwanted XML warnings [message #223346] |
Sat, 01 November 2008 09:29  |
Ed Merks Messages: 24550 Registered: July 2009 |
Qu0ll,
It sounds likely to be related to web tools (I assume you have the JEE
tools installed) so I've added that newsgroup to the "to" list of the
reply...
Qu0ll wrote:
> I have a number of XML files in many Java projects. For some strange
> reason, in some of those projects, Eclipse puts the warning emblem on
> the XML file icon and displays the warning "No grammar constraints
> (DTD or XML schema) detected for the document" inside the file when it
> is edited. How do I get rid of this warning and why does it only
> happen in some projects even though the XML files are identical? I
> have configured Eclipse with the "Indicate when no grammar specified =
> Ignore" option in the XML options but it still appears.
| Re: Unwanted XML warnings [message #223362 is a reply to message #223346] |
Sat, 01 November 2008 18:10   |
Originally posted by: dcarver.starstandard.org
> Qu0ll,
If you have any of those projects setup with Projet specific validations
that could affect it as well. If you know that you never want those XML
files validated you can set up Exclusion filters for those particular
directories or projects as well. Check the Project Properties and then
the Validation option, or the Validaton option in the preferences for
setting up particular Exclusion filters.
| Re: Unwanted XML warnings [message #223400 is a reply to message #223362] |
Mon, 03 November 2008 18:51   |
Originally posted by: Qu0llSixFour.gmail.com
"David Carver" <dcarver@starstandard.org> wrote in message
news:geik3v$q0u$1@build.eclipse.org...
>> Qu0ll,
>>> the XML file icon and displays the warning "No grammar constraints (DTD
>>> or XML schema) detected for the document" inside the file when it is
>>> edited. How do I get rid of this warning and why does it only happen in
>>> some projects even though the XML files are identical? I have
Thanks - setting up exclusions works just great :-)
And loving it,
-Qu0ll (Rare, not extinct)
_________________________________________________
Qu0llSixFour@gmail.com
[Replace the "SixFour" with numbers to email me]
| Re: Unwanted XML warnings [message #223623 is a reply to message #223524] |
Fri, 07 November 2008 00:39   |
"Gabriel Indik" <gindik@ca.ibm.com> wrote in message
news:821c3bb7b3fa290c62daf13a58da101e$1@www.eclipse.org...
> Note that you may still want to ensure that all your XML documents are
> free of errors, so they shouldnt be excluded in the validation settings.
> If the "No grammar constraints (DTD or XML schema)" error message is to be
> ignored, this can be set in the "XML" -> "XML Files" -> "Validating files"
> preferences section. By default a warning is shown when no grammar is
> specified, this can be changed to instead indicate an error or be ignored.
That's just the point - if you read my original post you will see that I
have already set that preferences option to "Ignore" but it is still
complaining about the absence of a grammar. The only way I could get it to
shut up was adding an exclusion.
And loving it,
| Re: Unwanted XML warnings [message #223655 is a reply to message #223647] |
Fri, 07 November 2008 15:38  |
Gabriel Indik Messages: 16 Registered: July 2009 |
Junior Member |
> After changing the "Indicate when no grammar is specified" to Ignore,
> try Validating the project by right clicking on it, and then selecting
> Validate.
Precisely, just like Nick pointed out, you would need to validate the
project again. This is because the warnings must have been created prior
to changing the setting to "ignore". I opened bug 254647 to address this
issue, prompting the user that a rebuild is needed for this particular
settings change to take effect.
FUDForum. Page generated in 0.07440 seconds
