Home » Eclipse Projects » GEF » No more handles Exception - Please need help
No more handles Exception - Please need help [message #223280] Fri, 22 September 2006 08:34 Go to next message
Originally posted by: shruthi.cn.in.bosch.com
Hello Everybody,
I have developed a application using GEF(Graphical Editing framework)
plugins. My application has two graphical viewers which displays some
draw2d figures, swt images. When i run my application, and work with it
for sometime, i get the "No more handles" exception. Please help me on
what is going wrong by seeing the exception.
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:3400)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at org.eclipse.swt.SWT.error(SWT.java:3268)
at org.eclipse.swt.widgets.Display.internal_new_GC(Display.java :2165)
at org.eclipse.swt.graphics.Device.getDepth(Device.java:401)
at org.eclipse.swt.custom.CBanner.onPaint(CBanner.java:315)
at org.eclipse.swt.custom.CBanner$1.handleEvent(CBanner.java:11 7)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:937)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:12 85)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3299 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4025 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:19 23)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2966)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Best Regards
Shruthi
Re: No more handles Exception - Please need help [message #223291 is a reply to message #223280] Fri, 22 September 2006 11:54 Go to previous message
Sebu Thomas is currently offline Sebu ThomasFriend
shruthi wrote:
> Hello Everybody,
> at
> at
> at
> at
> at
> at
> at
> at
> Best Regards
> Shruthi
Seems like you are not disposing your images. SWT resources need you to
dispose of them.
Previous Topic:[announce] GEF 3.2.1 Maintenance Release Build available
Next Topic:Difference in Behavior between Drag and Drop [using TemplateTransferDropTargetListener] and Click an
Current Time: Sat Jul 22 08:50:37 GMT 2017
Powered by FUDForum. Page generated in 0.09235 seconds
