Home » Eclipse Projects » Web Tools Project (WTP) » How to create a web service client (!) jar archive from Eclipse?
How to create a web service client (!) jar archive from Eclipse? [message #223217] Tue, 28 October 2008 15:46 Go to next message
Eclipse User
Originally posted by: p.oho.hotmail.com
Assume I developed in Eclipse a java web service client (! not the web service itself).
I can start and test this web service client by clicking in Eclipse on
"Run as Java application".
But assume I want to create now a jar file from all the current client classes.
Is there a menu which does the job for me?
Or do I have to write an Ant script?
Peter
Re: How to create a web service client (!) jar archive from Eclipse? [message #223225 is a reply to message #223217] Tue, 28 October 2008 17:11 Go to previous message
Konstantin Komissarchik is currently offline Konstantin Komissarchik
I would recommend putting your webservice client classes in a utility
project. You can then reference the utility project from your web app.
When you need to export a client jar for someone, you can use the jar
export wizard.
- Konstantin
Previous Topic:Problem setting up web application
Next Topic:Possibility to save *.xsd / *.wsdl files in respect to metamodel ?
Current Time: Mon May 20 00:58:07 EDT 2013
Powered by FUDForum. Page generated in 0.01494 seconds
