Home » Eclipse Projects » Web Tools Project (WTP) » how to change the filesystem location of a wtp server?
how to change the filesystem location of a wtp server? [message #223146] Sun, 26 October 2008 11:42 Go to next message
Eclipse User
Originally posted by: bmf1972.fastmail.fm
Hi all,
I have a server application that launches a Windows shell script and it
fails because the paths are too long.
Another case is when I need to open/delete/move/copy files under the WTP
server managed by Eclipse.
On Windows XP there is a problem when paths are longer than 250
characters and the WTP server path on my workstation is already 102
characters long. Hence, I am looking for how to make Eclipse manage its
WTP server under an alternative filesystem location.
Is this possible?
Thanks in advance,
Adrian.
P.S. I know about https://bugs.eclipse.org/bugs/show_bug.cgi?id=119588
and I am not complaining about deployment problems.
Re: how to change the filesystem location of a wtp server? [message #223177 is a reply to message #223146] Tue, 28 October 2008 07:22 Go to previous message
Eclipse User
Found it. I will answer my own question.
1. Remove all published modules and republish
2. In the Server Locations section specify the desired Deploy Path
Adrian Herscu wrote:
> Hi all,
> Is this possible?
> Thanks in advance,
> Adrian.
Previous Topic:Doubt about the right project to place the JPA facet and persistence.xml file
Next Topic:obtain webtools sourcecode - HOW ? cvs does not work ?
Current Time: Tue May 21 23:06:20 EDT 2013
Powered by FUDForum. Page generated in 0.01657 seconds
