Home » Eclipse Projects » Web Tools Project (WTP) » How to add new features MANUALLY?
How to add new features MANUALLY? [message #222666] Thu, 16 October 2008 14:43 Go to next message
Eclipse User
Originally posted by: mstev.ozone.com
Ok I could use the menu help-Software Updates->Find and install...
to add/update new features to an Eclipse installation.
However is there a way to add/update features manually?
Assume I have downloaded a *.zip file with a new feature.
Can I simply extract it to the Eclipse directory tree?
Is the new feature automatically recognized by a running Eclipse
or do I have to re-boot Eclipse?
Do I have (in addition to the copy operation) "register" somewhere the new/update feature
or does Eclipse recognize the add/update feature automatically?
Do I have to extract only the "plugin" sub-folder or the "features" sub-folder as well?
Pia
Re: How to add new features MANUALLY? [message #222672 is a reply to message #222666] Thu, 16 October 2008 18:04 Go to previous messageGo to next message
Eclipse User
> Pia
Yes you can extract the zip file in the eclipse directory structure.
Once extracted, eclipse doesn't recognize the feature automatically, you
need to reboot it.
Now thats the only thing to do about it.
You need to extract both the directories, plugin and features.
The way I do this, is something like this. I don't want to mess with my
eclipse installation. so i created a directory on C:\MyEclipsePlugins
(or anywhere) and extract my plugin there. Now to link the plugin to the
eclipse installation is via a link file.
So my directory structure looks something like this:
C:\Eclipse3.3
\links
myplugins.lnk
The "links" directory is not created by default, you need to create it.
Now the "myplugins.lnk" looks something like this (it would be just a
single line)
c:\MyEclipsePlugins\<your plugin name>
Advantage obviously is u can used this plugin in multiple eclipse
installations at the same time.
Atul
Re: How to add new features MANUALLY? [message #222678 is a reply to message #222666] Thu, 16 October 2008 18:09 Go to previous messageGo to next message
Eclipse User
> Pia
need to reboot it.
C:\Eclipse3.3
\links
myplugins.lnk
single line)
Atul
Re: How to add new features MANUALLY? [message #222683 is a reply to message #222666] Fri, 17 October 2008 03:38 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
Yes, if you use 3.4 or newer you put it into the dropins folder,
otherwise into the plugins folder.
You have to restart and best is to use the -clean and -debug command
line options.
No.
It will work without the features folder but if you have one it's best
to put it there as well.
Dani
> Pia
Re: How to add new features MANUALLY? [message #222691 is a reply to message #222666] Fri, 17 October 2008 03:59 Go to previous messageGo to next message
Pia Stevens wrote:
Please don't cross post.
Dani
> Pia
Re: How to add new features MANUALLY? [message #222696 is a reply to message #222666] Fri, 17 October 2008 09:27 Go to previous messageGo to next message
Christian Opitz is currently offline Christian Opitz
Hi Pia,
My favorite answer: It depends ;-) Usually it should work though.
You should reboot Eclipse.
sub-folder as well?
If you have both you should extract both and copy them to the Eclipse
installation folder. If you only have a feature file (you said that you
downloaded a feature) this of course needs to go to the feature directory.
HTH,
Christian
Re: How to add new features MANUALLY? [message #222923 is a reply to message #222666] Tue, 21 October 2008 18:30 Go to previous message
Eclipse Webmaster is currently offline Eclipse Webmaster
You were kindly asked to not cross-post to so many lists recently, yet
you continue. Please stop cross-posting, or you will be banned from our
news server.
Denis
> Pia
Previous Topic:How do I include external files in dynamic web project?
Next Topic:deploy to tomcat failure
Current Time: Sun May 19 03:13:18 EDT 2013
Powered by FUDForum. Page generated in 0.07922 seconds
