Home » Eclipse Projects » Web Tools Project (WTP) » jpa: change path to persistence.xml
jpa: change path to persistence.xml [message #222707] Sat, 18 October 2008 16:24 Go to next message
Denis Kostousov is currently offline Denis Kostousov
Member
How is it to move persistence.xml to another place in my project?
I have a ejb project with jpa facet enabled. The file persistence.xml is lying in the src/META-INF by default. I create
folders src/main/resource, mark it as the source folder and move the META-INF from src to src/main/resources. Then try
to build the project. The build process fails. The view Problems have a message "No persistence.xml file found in
project". How I can change paths to persistence.xml and META-INF?
Denis Kostousov
email: denis.kostousovATgmailDOTcom
jabber: denis.kostousovATgmailDOTcom
fingerprint: D32B A253 F678 9EF1 1079 4F5A 52E1 8EEA FAF9 E1F1
Re: change path to persistence.xml [message #222744 is a reply to message #222707] Mon, 20 October 2008 05:24 Go to previous message
Kaloyan Raev is currently offline Kaloyan Raev
I am not sure what do you try to achieve, but you can try playing with the
..settings/org.eclipse.wst.common.component file.
Greetings,
Kaloyan
"Denis Kostousov" <denis.kostousov@gmail.com> wrote in message
news:gddglj$2ja$1@build.eclipse.org...
> lying in the src/META-INF by default. I create folders src/main/resource,
> src/main/resources. Then try to build the project. The build process
> Denis Kostousov
Previous Topic:Servlet Version Conflict
Next Topic:Re: AXIS2 and Europa
Current Time: Wed May 22 14:09:28 EDT 2013
Powered by FUDForum. Page generated in 0.08549 seconds
