Home » Eclipse Projects » Web Tools Project (WTP) » Missing DocumentProvider by using XML editor plugin
Missing DocumentProvider by using XML editor plugin [message #222605] Wed, 08 October 2008 12:22 Go to next message
Eclipse User
Originally posted by: stefanxxx.gmx.de
I want to use the xml editor from eclipse.wst in my own project. Therefore I
added all eclipse.wst plugins, but opening an xml file causes an error about
a missing document provider. Unfortunately I cannot find documentation about
it. Where do I have to set the DocumentProvider and is there an example
implementation?
Thanks a lot
Stefan
[Updated on: Mon, 25 July 2011 11:12] by Moderator
Report message to a moderator
Re: Missing DocumentProvider by using XML editor plugin [message #222625 is a reply to message #222605] Fri, 10 October 2008 16:40 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
> Therefore I added all eclipse.wst plugins, but opening an xml file
> causes an error about a missing document provider. Unfortunately I
> cannot find documentation about it. Where do I have to set the
> DocumentProvider and is there an example implementation?
A stack trace with the exact error message and failure point would
be very useful. Were you using a common implementation of
IEditorInput or one of your own?
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Missing DocumentProvider by using XML editor plugin [message #222629 is a reply to message #222625] Sun, 12 October 2008 17:03 Go to previous message
Eclipse User
"Nitin Dahyabhai" <nitind@us.ibm.com> schrieb im Newsbeitrag
news:gcoeke$igk$1@build.eclipse.org...
>> Therefore I added all eclipse.wst plugins, but opening an xml file causes
>> an error about a missing document provider. Unfortunately I cannot find
>> documentation about it. Where do I have to set the DocumentProvider and
> A stack trace with the exact error message and failure point would be very
> useful. Were you using a common implementation of IEditorInput or one of
> your own?
I added the eclipse.wst.xml.ui plugin and all required plugins. I think the
next step is to implement a DocumentProvider but I don“t know if there is
already an implementation or if I have to do it myself. If I now try to open
an xml file the following error comes up:
!ENTRY org.eclipse.wst.xml.ui 4 4 2008-10-12 22:44:53.642
!MESSAGE Text editor does not have a document provider
!STACK 1
org.eclipse.ui.PartInitException: Text editor does not have a document
provider
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3058)
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3071)
org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredT extEditor.java:2546)
org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:213)
org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:187)
org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.addSourcePage(XMLMultiPageEditorPart.java:410)
org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.createPages(XMLMultiPageEditorPart.java:580)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:310)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:30 6)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 08)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:779)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:678)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:639)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2817)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2729)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2635)
datamodel.diagram.application.DiagramEditorActionBarAdvisor. openEditor(DiagramEditorActionBarAdvisor.java:294)
datamodel.diagram.application.DiagramEditorActionBarAdvisor. access$0(DiagramEditorActionBarAdvisor.java:277)
datamodel.diagram.application.DiagramEditorActionBarAdvisor$ OpenAction.run(DiagramEditorActionBarAdvisor.java:359)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
datamodel.diagram.application.DatamodelApplication.run(Datam odelApplication.java:18)
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hodWithException(EclipseAppContainer.java:574)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:195)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: org.eclipse.core.runtime.CoreException: Text editor does not have
a document provider
org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:3988)
org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:190)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1325)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor .java:165)
org.eclipse.wst.sse.ui.StructuredTextEditor.doSetInput(Struc turedTextEditor.java:1954)
org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3026)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:458)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:366)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2487)
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3044)
... 74 more
[Updated on: Mon, 25 July 2011 11:13] by Moderator
Previous Topic:XSD Validation
Next Topic:EJB Project and Entity
Current Time: Wed May 22 19:22:10 EDT 2013
Powered by FUDForum. Page generated in 0.01506 seconds
