| Deploy Servlet Web App to JBoss [message #221717] |
Mon, 22 September 2008 12:36  |
John Bailo Messages: 34 Registered: July 2009 |
Member |
I've developed a jsp page and servlet for JBoss using Eclipse and the
JBoss runtime.
I use many external .jars in my project and I have it working in the
debugger.
Now I want to deploy to a server on another machine.
If I export to a .war file, I notice that it does not carry the .classpath
files that are in my \.workspace copies of the project.
How should I use Eclipse so I can:
1. Automatically deploy to a remote JBoss server?
2. Have it carry all the project references with deployment...preferrably
all in the .war file so it's a complete package.
| Re: Deploy Servlet Web App to JBoss [message #221740 is a reply to message #221726] |
Tue, 23 September 2008 03:48   |
Kaloyan Raev Messages: 177 Registered: July 2009 Location: Sofia, Bulgaria |
Hi John,
The .classpath file is a system file for Eclipse project. It is not part of
the Java EE specification and even if you have it in the exported .war file
the application server will not process it.
If you need to refer to external JARs, you should use the Java EE
Dependencies property page rather than adding them directly in the Java
Build Path of the project.
I haven't tried configuring a remote JBoss server in WTP, but the following
may work. First, you need to configure a JBoss server runtime. You have to
point to the JBoss runtime libraries in the wizard. You need to somehow made
accessible the folder with JBoss installation on your remote system. Then
you can create a JBoss server instance. There in the wizard you have Host
field where you can specify the host of you remote system.
Greetings, Kaloyan
"John Bailo" <John.Bailo@Bowne.com> wrote in message
news:d5c03ed91bbf35d8f81f3d672a963002$1@www.eclipse.org...
> Well, this is weird. I exported my war to a jar. I copyied my external
> directory of jars to the \deploy folder of JBoss.
> And somehow my application works and can call the external jars.
> However, if I look in my .war file, there is no .classpath file, and there
> is no classpath defined in the Manifest.
> How can JBoss possibly know where to find the external jars??
| Re: Deploy Servlet Web App to JBoss [message #221747 is a reply to message #221717] |
Tue, 23 September 2008 06:05  |
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi John,
the easiest way to deploy external jars to the server is to copy them to
WEB-INF/lib in your project (important: call "Refresh" in the project explorer
afterwards).
For the remote deployment: some time ago I modified the default WTP JBoss plugin
to perform a JSR88 deployment. This should also work for remote servers by just
specifying the remote IP in the server properties (as Kaloyan suggests, but his
suggestion will not work with the default plugin).
You can find the plugin and a short installation instruction here:
http://www.informatik.fh-wiesbaden.de/~knauf/public/ (section "WTP 3.0: JBoss
JSR88 deployment").
Could you give me some feedback whether it works or not?
Unfortunately, JSR deployment is not persistent in JBoss, so you will have to do
deploy on each server restart.
Best regards
Wolfgang
> deployment...preferrably all in the .war file so it's a complete package.
FUDForum. Page generated in 0.02563 seconds
