| Can't launch servlet [message #221326] |
Fri, 12 September 2008 16:59  |
Thomas Lawless Messages: 3 Registered: July 2009 |
Junior Member |
I'm having a problem launching a servlet into a web browser (internal or
external) using the Run as > Run on Server context menu. I checked the
eclipse log file and found there is a null pointer exception. I have
pasted the entry from the log file below. Has anyone else seen this issue?
eclipse 3.4
Linux OS (CentOS 5.2)
WebSphere Community Edition (Server)
Entry in eclipse log file:
!SESSION 2008-09-12 16:33:49.877
eclipse.buildId=I20080617-2000
java.fullversion=J2RE 1.5.0 IBM J9 2.3 Linux x86-32 j9vmxi3223ifx-20080811
(JIT enabled)
J9VM - 20080809_21892_lHdSMr
JIT - 20080620_1845_r8
GC - 200806_19
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.ui 2 0 2008-09-12 16:34:01.498
!MESSAGE Warnings while parsing the key bindings from the
'org.eclipse.ui.commands' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2008-09-12 16:34:01.498
!MESSAGE Cannot bind to an undefined command:
plug-in='org.eclipse.tm.terminal', id='org.eclipse.tm.terminal.command1'
!SUBENTRY 1 org.eclipse.ui 2 0 2008-09-12 16:34:01.499
!ENTRY org.eclipse.wst.server.ui 4 0 2008-09-12 16:35:03.171
!MESSAGE Error opening browser
!STACK 0
org.eclipse.wst.server.ui.internal.WebLaunchableClient.launc h(WebLaunchableClient.java:39)
at org.eclipse.wst.server.core.internal.Client.launch(Client.ja va:114)
org.eclipse.wst.server.ui.internal.LaunchClientJob$1.run(Lau nchClientJob.java:79)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3378)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3036)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:79)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:618)
| Re: Can't launch servlet [message #222362 is a reply to message #221326] |
Mon, 29 September 2008 10:50  |
Angel Vera Messages: 63 Registered: July 2009 |
Member |
It looks like your browser had problems opening.
What browser are you using? I will try to configure a different browser
using: Preferences > General > Web Browser
Angel
tglawles@us.ibm.com (Thomas Lawless) wrote in
news:69c8026b17b48f83a8a45f8183c66eaa$1@www.eclipse.org:
> or external) using the Run as > Run on Server context menu. I checked
> the eclipse log file and found there is a null pointer exception. I
> have pasted the entry from the log file below. Has anyone else seen
> this issue?
> eclipse 3.4
> j9vmxi3223ifx-20080811 (JIT enabled)
> GC - 200806_19
> id='org.eclipse.tm.terminal.command1' !SUBENTRY 1 org.eclipse.ui 2 0
> 2008-09-12 16:34:01.498 !MESSAGE Cannot bind to an undefined command:
> 2008-09-12 16:34:01.499 !MESSAGE Cannot bind to an undefined command:
> !STACK 0
> java.lang.NullPointerException
> at
(WebLaunch
> ableClient.java:39)
> at
(Client.java:114
> ) at
(LaunchClientJo
> b.java:79)
> at
(Synchronizer.java
> :133)
> at
(Display.java:3378
> ) at
(Display.java:3036)
> at
(Workbench.java:2382
> ) at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
> at
> at
(Realm.java
> :288)
> at
(Workbench.java:
> 488)
> at
(PlatformUI.java:14
> 9) at
(IDEApplica
> tion.java:113)
> at
(EclipseAppHandle.
> java:193)
> at
a
> at
(Ecli
> at
(EclipseStarter.java
> :382)
> at
> :179)
> at
(NativeMethodAccessorImpl.ja
> va:79)
> at
(DelegatingMethodAccesso
> rImpl.java:43)
> at
Angel Vera
WTP Server Tools Developer
FUDForum. Page generated in 0.01586 seconds
