Home » Eclipse Projects » Web Tools Project (WTP) » Change path / location of ejb-jar.xml deployment descriptor
Change path / location of ejb-jar.xml deployment descriptor [message #221055] Tue, 09 September 2008 05:49
Kris Missing name is currently offline Kris Missing name
Member
I have changed the location of the META-INF/ejb-jar.xml in an ejb
project. Since I had some trouble after the change I moved it back to
<myproject>/ejbModule. So the path is now again
<myproject>/ejbModule/META-INF/ejb-jar.xml.
Even after that when double clicking on the first node "Deployment
Descriptor: <myproject>" it says:
Resource /<myproject>/src/META-INF/ejb-jar.xml does not exist.
Where is this information saved? I tried to find it on file level, but
was not successful. How can I set the path to the ejb-jar.xml to get the
"ejb-jar.xml editor" working again?
Kris
Previous Topic:How to install updated server adapters
Next Topic:error adding wtp to clean update java eclipse ganymede
Current Time: Thu May 23 05:44:54 EDT 2013
Powered by FUDForum. Page generated in 0.01682 seconds
