Home » Eclipse Projects » Web Tools Project (WTP) » casting error while connecting to oracle database
casting error while connecting to oracle database [message #219268] Wed, 13 August 2008 15:53 Go to next message
Lata Lokhande is currently offline Lata Lokhande
I am trying to connect to the oracle 9i database. I am using
oracle.jdbc.xa.client.OracleXADataSource class and classes12-9i.jar file.
for test connection, getting error "cannot be cast to java.sql.Driver"
When I am creating new connection from Data Source Explorer, I selected
"SQL-Model-JDBC Connection" option from the New Connection Profile Wizard.
(I am not sure what to select here.)
I am using
WTP 2.0
WebLogic server 8.1
Oracle 9i.
Any help is appreciated.
Lata
Below is the error
java.lang.ClassCastException: oracle.jdbc.xa.client.OracleXADataSource
org.eclipse.datatools.connectivity.db.generic.JDBCConnection .createConnection(JDBCConnection.java:86)
org.eclipse.datatools.connectivity.DriverConnectionBase.inte rnalCreateConnection(DriverConnectionBase.java:104)
org.eclipse.datatools.connectivity.DriverConnectionBase.open (DriverConnectionBase.java:53)
org.eclipse.datatools.connectivity.db.generic.JDBCConnection Factory.createConnection(JDBCConnectionFactory.java:52)
org.eclipse.datatools.connectivity.internal.ConnectionFactor yProvider.createConnection(ConnectionFactoryProvider.java:77 )
org.eclipse.datatools.connectivity.internal.ConnectionProfil e.createConnection(ConnectionProfile.java:354)
at org.eclipse.datatools.connectivity.ui.PingJob.run(PingJob.ja va:57)
Re: casting error while connecting to oracle database [message #220364 is a reply to message #219268] Mon, 08 September 2008 04:17 Go to previous message
Kaloyan Raev is currently offline Kaloyan Raev
This looks to be a problem in the Data Tools Platform (DTP) project. WTP
uses DTP for database connectivity.
You should report your problem in DTP's newsgroups:
http://www.eclipse.org/newsportal/thread.php?group=eclipse.d tp
Greetings,
Kaloyan
"Lata" <llokhande@ups.com> wrote in message
news:e47b0f99d3e67abef2c69dfd5f6943fd$1@www.eclipse.org...
> I am using WTP 2.0
> WebLogic server 8.1
> Oracle 9i.
> Lata
> Below is the error
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Previous Topic:Survey about label decorations (with decoration icons)
Next Topic:How to install updated server adapters
Current Time: Thu May 23 18:50:22 EDT 2013
Powered by FUDForum. Page generated in 0.08109 seconds
