Home » Language IDEs » ServerTools (WTP) » Array cannot be resolved error for Linked WebContent
Array cannot be resolved error for Linked WebContent [message #220303] Sun, 07 September 2008 12:15 Go to next message
TN is currently offline TNFriend
I got a error message at the first line of each jsp file:
"The type Array cannot be resolved. It is indirectly referenced from
required library files"
The WebContent in my project is a Linked Folder. Is it the reason? How
to avoid the problem?
The JRE has been set correctly in the build path, and I've tried to
create a simplest Dynamic Web Project(WebContent isn't linked folder)
and a simplest jsp file, no error there.
Re: Array cannot be resolved error for Linked WebContent [message #220311 is a reply to message #220303] Sun, 07 September 2008 18:27 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
TN wrote:
Have you examined
http://java.syntaxerrors.info/index.php?title=Cannot_resolve _type ?
Re: Array cannot be resolved error for Linked WebContent [message #220342 is a reply to message #220303] Mon, 08 September 2008 05:28 Go to previous message
Originally posted by: dennis_gao.21cn.com
just a test heh
"TN" <taurusning@gmail.com> 写入消息 news:ga0gmo$ffp$1@build.eclipse.org...
Previous Topic:How to switch quickly the EJB relating local interface of a bean?
Next Topic:error adding wtp to clean update java eclipse ganymede
Current Time: Sat Jul 22 09:07:18 GMT 2017
Powered by FUDForum. Page generated in 0.07632 seconds
