| Ganymede JEE doesn't seem to recognise JSP 2.1 Tag attributes [message #219137] |
Sat, 09 August 2008 16:36  |
Originally posted by: sascha.baumeister.gmail.com
I get warnings when using some <jsp:directive.attribute> attributes in
tag-file definitions.
The attributes in question have been defined in JSP 2.1, and weren't part
of JSP 2.0. For example, this is the case for "deferredValue" and
"deferredValueType". The tags are running properly, of course.
Is the JSP EL validator still based on the JSP 2.0 version, or do I miss a
setting somewhere in Eclipse? :)
Sascha Baumeister
Software architect and former JSP spec lead
| Re: Ganymede JEE doesn't seem to recognise JSP 2.1 Tag attributes [message #219156 is a reply to message #219137] |
Sun, 10 August 2008 16:51  |
Nitin Dahyabhai Messages: 1847 Registered: July 2009 |
> part of JSP 2.0. For example, this is the case for "deferredValue" and
> a setting somewhere in Eclipse? :)
You're correct, the JSP support in Ganymede is still at the JSP 2.0
level (in fact there are a couple of pieces missing due to time and
other limitations). There's no setting you're missing for 2.1.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
FUDForum. Page generated in 0.01645 seconds
