Home » Eclipse Projects » IMP » IDE crash because of lpg executable?
| IDE crash because of lpg executable? [message #21898] |
Fri, 27 June 2008 19:14  |
Originally posted by: hamoun.gh.gmail.com
Hello All
Thank you for your recent helps. I am working with IMP under Eclipse
3.3.1 and 3.4 now. Since I installed it my IDE crashes randomly and I
have been working with this IDE around one year, I never experienced
this. I wondering if anyone experienced the same or knows how to deal
with it. I have attached the log. I guess I have to set some permission
to execute the lpg exe file?
Thank you,
Hamoun
| Re: IDE crash because of lpg executable? [message #21944 is a reply to message #21898] |
Fri, 27 June 2008 20:11   |
--------------080503080809090600060805
hamoun ganbari wrote:
> Hello All
> Thank you,
> Hamoun
sorry forgot the attachment
name="hs_err_pid672.log"
Content-Disposition: inline;
filename="hs_err_pid672.log"
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=3D0x7c911e58, pid=3D672,=
tid=3D2120
# Java VM: Java HotSpot(TM) Client VM (10.0-b19 mixed mode, sharing windo=
ws-x86)
# Problematic frame:
# C
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x00ab5c00): JavaThread "main"
siginfo: ExceptionCode=3D0xc0000005, reading address 0xb42b2a2c
Registers:
EAX=3D0x2c68e008, EBX=3D0x00ab0000, ECX=3D0xb42b2a2c, EDX=3D0x25000000
ESP=3D0x0012d89c, EBP=3D0x0012d8a8, ESI=3D0x2c68e000, EDI=3D0x2c6a9000
EIP=3D0x7c911e58, EFLAGS=3D0x00010246
Top of Stack: (sp=3D0x0012d89c)
0x0012d89c: 00ab0000 00000002 00ab0007 0012d8e0
0x0012d8ac: 7c918251 b42b2a2c 2c6a9000 0012d8d4
0x0012d8bc: 00000000 000003d7 00000000 00ab0000
0x0012d8cc: 0012d807 0012dca4 00000400 2c590000
0x0012d8dc: 00000000 0012db10 7c911c76 05ab0000
0x0012d8ec: 00001eb8 04f32278 00001eac 00000000
0x0012d8fc: 012e0247 0012dcd0 00000000 00000047
0x0012d90c: 000f050a 09419048 6d88b99c 00001f80=20
Instructions: (pc=3D0x7c911e58)
0x7c911e48: 85 97 7a 03 00 8b 4e 0c 8d 46 08 8b 10 89 4d 08
0x7c911e58: 8b 09 3b 4a 04 89 55 0c 0f 85 9d 00 00 00 3b c8=20
Stack: , sp=3D0x0012d89c, free space=3D1014k
Native frames: (J=3Dcompiled Java code, j=3Dinterpreted, Vv=3DVM code, C=3D=
native code)
C
C
C
C
C
J java.util.zip.Inflater.inflateBytes(
0x2c59cc00 JavaThread "Timer-0"
0x055bd800 JavaThread "Worker-9"
0x055bc800 JavaThread "Worker-8"
0x055a8400 JavaThread "Worker-7"
0x05538800 JavaThread "Worker-6"
0x0552a400 JavaThread "Worker-5"
0x05526800 JavaThread "Worker-4"
0x03be1000 JavaThread "Worker-3"
0x03b7b800 JavaThread "Worker-2"
0x04ec9800 JavaThread "Worker-1"
0x039ba400 JavaThread "org.eclipse.jdt.internal.ui.text.JavaReconciler"=
daemon
0x04e26400 JavaThread "Java indexing" daemon
0x03b0d000 JavaThread "Worker-0"
0x039de800 JavaThread "Start Level Event Dispatcher" daemon
0x039c4800 JavaThread "Framework Event Dispatcher" daemon
0x039c5800 JavaThread "State Data Manager" daemon
0x00e1e400 JavaThread "Low Memory Detector" daemon
0x00e1bc00 JavaThread "CompilerThread0" daemon
0x00e17400 JavaThread "Attach Listener" daemon
0x00e16400 JavaThread "Signal Dispatcher" daemon
0x00e0e800 JavaThread "Finalizer" daemon
0x00e0d800 JavaThread "Reference Handler" daemon
=3D>0x00ab5c00 JavaThread "main"
Other Threads:
0x00e0c400 VMThread
0x00e28000 WatcherThread
VM state:synchronizing (normal execution)
VM Mutex/Monitor currently owned by a thread: ()
CodeCache_lock - owner thread: 0x00e1bc00
Threads_lock - owner thread: 0x00e0c400
Heap_lock - owner thread: 0x055bd800
Compile_lock - owner thread: 0x00e1bc00
[0x00ab57c0/0x000001a8] MethodCompileQueue_lock - owner thread: 0x00e1bc0=
0
Heap
def new generation total 5632K, used 5056K [0x06990000, 0x06fa0000, 0x=
090f0000)
eden space 5056K, 100% used [0x06990000, 0x06e80000, 0x06e80000)
from space 576K, 0% used [0x06f10000, 0x06f10000, 0x06fa0000)
to space 576K, 0% used [0x06e80000, 0x06e80000, 0x06f10000)
tenured generation total 73308K, used 39957K [0x090f0000, 0x0d887000, =
0x26990000)
the space 73308K, 54% used [0x090f0000, 0x0b7f54e8, 0x0b7f5600, 0x0d8=
87000)
compacting perm gen total 43008K, used 42944K [0x26990000, 0x29390000, =
0x2a990000)
the space 43008K, 99% used [0x26990000, 0x29380048, 0x29380200, 0x293=
90000)
ro space 8192K, 62% used [0x2a990000, 0x2ae92a28, 0x2ae92c00, 0x2b19=
0000)
rw space 12288K, 52% used [0x2b190000, 0x2b7d86b8, 0x2b7d8800, 0x2bd=
90000)
Dynamic libraries:
0x00400000 - 0x0040e000 E:\mf\running\eclipse-rcp-europa-fall-win32\ecli=
pse\eclipse.exe
0x7c900000 - 0x7c9b0000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c8f5000 C:\WINDOWS\system32\kernel32.dll
0x7e410000 - 0x7e4a0000 C:\WINDOWS\system32\USER32.dll
0x77f10000 - 0x77f57000 C:\WINDOWS\system32\GDI32.dll
0x5d090000 - 0x5d12a000 C:\WINDOWS\system32\COMCTL32.dll
0x77dd0000 - 0x77e6b000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e70000 - 0x77f02000 C:\WINDOWS\system32\RPCRT4.dll
0x77fe0000 - 0x77ff1000 C:\WINDOWS\system32\Secur32.dll
0x77c10000 - 0x77c68000 C:\WINDOWS\system32\MSVCRT.dll
0x76390000 - 0x763ad000 C:\WINDOWS\system32\IMM32.DLL
0x629c0000 - 0x629c9000 C:\WINDOWS\system32\LPK.DLL
0x74d90000 - 0x74dfb000 C:\WINDOWS\system32\USP10.dll
0x72000000 - 0x72012000 E:\mf\running\eclipse-rcp-europa-fall-win32\ecli=
pse\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.0 .1.R33x_v2007=
0828\eclipse_1020.dll
0x77c00000 - 0x77c08000 C:\WINDOWS\system32\VERSION.dll
0x5ad70000 - 0x5ada8000 C:\WINDOWS\system32\uxtheme.dll
0x74720000 - 0x7476b000 C:\WINDOWS\system32\MSCTF.dll
0x755c0000 - 0x755ee000 C:\WINDOWS\system32\msctfime.ime
0x774e0000 - 0x7761d000 C:\WINDOWS\system32\ole32.dll
0x77f60000 - 0x77fd6000 C:\WINDOWS\system32\SHLWAPI.dll
0x773d0000 - 0x774d3000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-C=
ontrols_6595b64144ccf1df_6.0.2600.2982_x-ww_ac3f9c03\comctl3 2.dll
0x6d7c0000 - 0x6da10000 C:\Program Files\Java\jre1.6.0_05\bin\client\jvm=
=2Edll
0x76b40000 - 0x76b6d000 C:\WINDOWS\system32\WINMM.dll
0x7c340000 - 0x7c396000 C:\WINDOWS\system32\MSVCR71.dll
0x6d270000 - 0x6d278000 C:\Program Files\Java\jre1.6.0_05\bin\hpi.dll
0x76bf0000 - 0x76bfb000 C:\WINDOWS\system32\PSAPI.DLL
0x6d770000 - 0x6d77c000 C:\Program Files\Java\jre1.6.0_05\bin\verify.dll=
0x6d310000 - 0x6d32f000 C:\Program Files\Java\jre1.6.0_05\bin\java.dll
0x6d7b0000 - 0x6d7bf000 C:\Program Files\Java\jre1.6.0_05\bin\zip.dll
0x6d570000 - 0x6d583000 C:\Program Files\Java\jre1.6.0_05\bin\net.dll
0x71ab0000 - 0x71ac7000 C:\WINDOWS\system32\WS2_32.dll
0x71aa0000 - 0x71aa8000 C:\WINDOWS\system32\WS2HELP.dll
0x6d590000 - 0x6d599000 C:\Program Files\Java\jre1.6.0_05\bin\nio.dll
0x04100000 - 0x0414f000 E:\mf\running\eclipse-rcp-europa-fall-win32\ecli=
pse\configuration\org.eclipse.osgi\bundles\147\1\.cp\swt-win 32-3346.dll
0x763b0000 - 0x763f9000 C:\WINDOWS\system32\comdlg32.dll
0x7c9c0000 - 0x7d1d7000 C:\WINDOWS\system32\SHELL32.dll
0x77120000 - 0x771ab000 C:\WINDOWS\system32\OLEAUT32.dll
0x78050000 - 0x78120000 C:\WINDOWS\system32\WININET.dll
0x04160000 - 0x04169000 C:\WINDOWS\system32\Normaliz.dll
0x78000000 - 0x78045000 C:\WINDOWS\system32\iertutil.dll
0x040e0000 - 0x040e8000 E:\mf\running\eclipse-rcp-europa-fall-win32\ecli=
pse\configuration\org.eclipse.osgi\bundles\35\1\.cp\os\win32 \x86\localfil=
e_1_0_0.dll
0x74c80000 - 0x74cac000 C:\WINDOWS\system32\oleacc.dll
0x76080000 - 0x760e5000 C:\WINDOWS\system32\MSVCP60.dll
0x04940000 - 0x04954000 E:\mf\running\eclipse-rcp-europa-fall-win32\ecli=
pse\configuration\org.eclipse.osgi\bundles\147\1\.cp\swt-gdi p-win32-3346.=
dll
0x4ec50000 - 0x4edf3000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_=
6595b64144ccf1df_1.0.2600.2180_x-ww_522f9f82\gdiplus.dll
0x05640000 - 0x05905000 C:\WINDOWS\system32\xpsp2res.dll
0x76fd0000 - 0x7704f000 C:\WINDOWS\system32\CLBCATQ.DLL
0x77050000 - 0x77115000 C:\WINDOWS\system32\COMRes.dll
0x75cf0000 - 0x75d81000 C:\WINDOWS\system32\mlang.dll
0x76380000 - 0x76385000 C:\WINDOWS\system32\msimg32.dll
VM Arguments:
jvm_args: -Dosgi.requiredJavaVersion=3D1.5 -Xms40m -Xmx512m=20
java_command: <unknown>
Launcher Type: generic
Environment Variables:
JAVA_HOME=3DE:\Sun\SDK\jdk
CLASSPATH=3D.;C:\Program Files\Java\jre1.6.0_02\lib\ext\QTJava.zip
PATH=3DC:\Program Files\Java\jre1.6.0_05\bin\client;C:\Program Files\Java=
\jre1.6.0_05\bin;C:\Program Files\ActiveState Komodo IDE 4.2\;C:\Perl\sit=
e\bin;C:\Perl\bin;C:\Program Files\Windows Resource Kits\Tools\;C:\WINDOW=
S\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\QuickTime=
\QTSystem\;C:\Program Files\Microsoft SQL Server\80\Tools\Binn\;C:\Progra=
m Files\Microsoft SQL Server\90\DTS\Binn\;C:\Program Files\Microsoft SQL =
Server\90\Tools\binn\;C:\Program Files\Microsoft SQL Server\90\Tools\Binn=
\VSShell\Common7\IDE\;C:\Program Files\Microsoft Visual Studio 8\Common7\=
IDE\PrivateAssemblies\;C:\Program Files\Common Files\Teleca Shared;C:\Pro=
gram Files\Windows Imaging\;C:\WINDOWS\system32\WindowsPowerShell\v1.0;"C=
:\Program Files\Graphviz2.17\Bin";C:\Python25\Scripts;C:\Python25;C:\mf\r=
unning\pugs;E:\Program Files\Microsoft Visual Studio 9.0\VC\bin;C:\Progra=
m Files\MiKTeX 2.7\miktex\bin;C:\Program Files\GnuWin32\bin;C:\Program Fi=
les\Apache Software Foundation\apache-maven-2.0.8\bin;JAVA_HOME\bin;E:\Su=
n\SDK\jdk\bin;C:\mf\running;E:\mf\running\apache-ant-1.7.0-b in\apache-ant=
-1.7.0\bin;E:\Sun\SDK\bin;C:\Program Files\CVSNT\;C:\mf\runningE:\mf\runn=
ing\apache-ant-1.7.0-bin\apache-ant-1.7.0\bin;
USERNAME=3Dhamoun
OS=3DWindows_NT
PROCESSOR_IDENTIFIER=3Dx86 Family 6 Model 15 Stepping 6, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 2
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepp=
ing 6, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 1046648k(370132k free), swap 4090824k(3364064k =
free)
vm_info: Java HotSpot(TM) Client VM (10.0-b19) for windows-x86 JRE (1.6.0=
_05-b13), built on Feb 22 2008 01:16:53 by "java_re" with MS VC++ 7.1
time: Fri Jun 27 18:07:09 2008
elapsed time: 14 seconds
--------------080503080809090600060805--
| Re: IDE crash because of lpg executable? [message #23418 is a reply to message #21944] |
Fri, 01 August 2008 11:26  |
Ed Willink Messages: 3185 Registered: July 2009 |
The wierd hot spot failures are vaguely reminiscent of trouble I had with 1.6.0 pre 03.
Your 05 cannot be the same that you have used for a year.
Try changing JRE and hope that the problem vanishes.
Ed Willink
| Re: IDE crash because of lpg executable? [message #571768 is a reply to message #21898] |
> Hello All
> Thank you,
> Hamoun
tid=3D2120
ws-x86)
# C
Registers:
native code)
C
C
C
C
C
daemon
Other Threads:
0x00e0c400 VMThread
0
Heap
090f0000)
0x26990000)
87000)
0x2a990000)
90000)
0000)
90000)
Dynamic libraries:
pse\eclipse.exe
=2Edll
e_1_0_0.dll
dll
VM Arguments:
USERNAME=3Dhamoun
OS=3DWindows_NT
free)
Current Time: Sun May 26 03:58:59 EDT 2013
Powered by FUDForum. Page generated in 0.07483 seconds
