| Unhandled event loop exception --> java.lang.NullPointerException [message #218318] |
Thu, 22 June 2006 10:40  |
Originally posted by: kja.eswar.gmail.com
Hi all,
I'm just trying to run through the GEF shapes example, and I'm blocked on a strange behavior. I just imported the src into a new plug in project which I have created. I am just trying to run it and I get the following error.
Reason:
In the .log file, I find the exception shown at the end of this messasge. I'm running Eclipse 3.1 . Can someone give me a hint? I'm totally lost!
Thanks in advance,
Eswar
PLUGIN.XML
<?eclipse version="3.0"?>
extensions="shapes"
icon="shapes.gif"
default="true"
class="org.eclipse.gef.examples.shapes.ShapesEditor"
contributorClass=" org.eclipse.gef.examples.shapes.ShapesEditorActionBarContrib utor "
id="GEF Shapes Editor">
parentCategory="org.eclipse.ui.Examples"
id="org.eclipse.gef.examples"/>
icon="shapes.gif"
category="org.eclipse.ui.Examples/org.eclipse.gef.examples"
class="org.eclipse.gef.examples.shapes.ShapesCreationWizard "
id="org.eclipse.gef.examples.shapes.ShapesCreationWizard">
LOG ENTRY
!SESSION 2006-06-22 19:42:03.562 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.4.2_06
Framework arguments: -product org.eclipse.sdk.ide -pdelaunch
Command-line arguments: -product org.eclipse.sdk.ide -data D:\eclipse\TestProjects\runtime-EclipseApplication -dev file:D:/eclipse/TestProjects/TestEditor/.metadata/.plugins/o rg.eclipse.pde.core/Eclipse Application/dev.properties -pdelaunch -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2006-06-22 19:42:33.218
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-06-22 19:42:33.375
!MESSAGE java.lang.NullPointerException
!STACK 0
at org.eclipse.ui.internal.ide.dialogs.CreateLinkedResourceGrou p.createStatus(CreateLinkedResourceGroup.java:232)
at org.eclipse.ui.internal.ide.dialogs.CreateLinkedResourceGrou p.validateLinkLocation(CreateLinkedResourceGroup.java:411)
at org.eclipse.ui.dialogs.WizardNewFileCreationPage.validateLin kedResource(WizardNewFileCreationPage.java:530)
at org.eclipse.ui.dialogs.WizardNewFileCreationPage.validatePag e(WizardNewFileCreationPage.java:567)
at org.eclipse.gef.examples.shapes.ShapesCreationWizard$Creatio nPage.validatePage(ShapesCreationWizard.java:155)
at org.eclipse.ui.dialogs.WizardNewFileCreationPage.handleEvent (WizardNewFileCreationPage.java:460)
at org.eclipse.ui.internal.ide.misc.ResourceAndContainerGroup.h andleEvent(ResourceAndContainerGroup.java:250)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:848)
at org.eclipse.swt.widgets.Text.wmCommandChild(Text.java:2061)
at org.eclipse.swt.widgets.Control.WM_COMMAND(Control.java:3164 )
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3041 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:158 0)
at org.eclipse.swt.widgets.Text.callWindowProc(Text.java:131)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3123 )
at org.eclipse.swt.widgets.Text.windowProc(Text.java:1777)
at org.eclipse.swt.internal.win32.OS.SetWindowTextW(Native Method)
at org.eclipse.swt.internal.win32.OS.SetWindowText(OS.java:2355 )
at org.eclipse.swt.widgets.Text.setText(Text.java:1593)
at org.eclipse.ui.internal.ide.misc.ResourceAndContainerGroup.s etResource(ResourceAndContainerGroup.java:293)
at org.eclipse.ui.dialogs.WizardNewFileCreationPage.setFileName (WizardNewFileCreationPage.java:516)
at org.eclipse.gef.examples.shapes.ShapesCreationWizard$Creatio nPage.createControl(ShapesCreationWizard.java:91)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.ja va:179)
at org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:611)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog .java:965)
at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1016)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1013)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.jav a:1003)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1001)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:753)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at org.eclipse.ui.actions.NewExampleAction.run(NewExampleAction .java:120)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
| Re: Unhandled event loop exception --> java.lang.NullPointerException [message #218482 is a reply to message #218428] |
Mon, 26 June 2006 09:56   |
Originally posted by: eclipse.chris-lott.org
The "unhandled event loop exception" is the standard message that I see
when my plugin code messes up. I suspect the platform is just fine, and
the shapes example has an issue. I recommend starting a runtime workspace
with the plugin in debug mode, setting a Java exception breakpoint on
NullPointerException, and repeating what you have done to reveal the
failure. This should show you exactly where the shapes example is doing
something it should not. It may also help if you specify in your message
here exactly what version of the shapes example you are using. Hope this
helps.
chris...
| Re: Unhandled event loop exception --> java.lang.NullPointerException [message #218753 is a reply to message #218482] |
Thu, 29 June 2006 04:32  |
Chris,
I agree with you. The platform is just fine. What I was doing is that I had created a new project and imported the whole source code, resolved all the classpath issues and then I was running it. This was when I was getting the error.
However I found a simple way of importing the code, however I did not find it documented anywhere in the documentation except for one of the forums. For importing the code of plugins, I imported using Import->As Source Project. After this the code ran absolutely fine..
Chris, thanks for your inputs, otherwise too.
Eswar
FUDForum. Page generated in 0.01725 seconds
