Home » Eclipse Projects » Web Tools Project (WTP) » Convert javax.wsdl.Definition to wst.Definition
Convert javax.wsdl.Definition to wst.Definition [message #218399] Mon, 28 July 2008 10:31 Go to next message
Eclipse User
Originally posted by: gregory.vanseghbroeck.intec.ugent.be
Hi everybody,
Is there a way to create a wst.Definition from a DOM.Element or from a
javax.wsdl.Definition object?
Thanks in advance,
Gregory
Re: Convert javax.wsdl.Definition to wst.Definition [message #218418 is a reply to message #218399] Mon, 28 July 2008 12:57 Go to previous message
Eclipse User
Originally posted by: valentinbaciu.hotmail.com
Hi Gregory,
The recommended way to get a org.eclipse.wst.wsdl.Definition is by loading a
WSDL document with a WSDL resource.
See this unit test helper class for examples
org.eclipse.wst.wsdl.tests.util.DefinitionLoader.
For constructing a Definition given a DOM you could try something like this:
Definition definition = WSDLFactory.eINSTANCE.createDefinition();
definition.setElement(element);
but there are some other things that need set up to get everything working
properly.
You could look at
org.eclipse.wst.wsdl.internal.impl.DefinitionImpl.createDefi nition(Node,
String, boolean) for an example.
The implementation of org.eclipse.wst.wsdl.util.WSDLResourceImpl should
also be interesting to read.
In general searching the org.eclipse.wst.wsdl and org.eclipse.wst.wsdl.tests
should always yield some interesting examples.
Regards, Valentin
"Gregory Van Segbroeck" <gregory.vanseghbroeck@intec.ugent.be> wrote in
message news:4c40d5063e8c7433b7fd39d11035641c$1@www.eclipse.org...
> Hi everybody,
> Thanks in advance,
> Gregory
Previous Topic:Possible bug in XML formatter
Next Topic:Force Eclipse to Publish?
Current Time: Sat May 18 21:53:28 EDT 2013
Powered by FUDForum. Page generated in 0.03772 seconds
