| Figure.validate() crashes [message #218027] |
Fri, 16 June 2006 18:27  |
Paul E. Keyser Messages: 878 Registered: July 2009 |
R3.1.2, WinXP
Sometimes I get this call-stack after disposing the canvas containing my figure; anyone know why? is
it a Figure bug, or is there some action I should be taking?
thanks,
Paul
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at org.eclipse.swt.SWT.error(SWT.java:2836)
at org.eclipse.swt.widgets.Widget.error(Widget.java:395)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:297)
at org.eclipse.swt.widgets.Scrollable.getVerticalBar(Scrollable .java:187)
at org.eclipse.draw2d.FigureCanvas$2.propertyChange(FigureCanva s.java:72)
at java.beans.PropertyChangeSupport.firePropertyChange(Unknown Source)
at org.eclipse.draw2d.DefaultRangeModel.firePropertyChange(Defa ultRangeModel.java:60)
at org.eclipse.draw2d.DefaultRangeModel.setAll(DefaultRangeMode l.java:118)
at org.eclipse.draw2d.Viewport.readjustScrollBars(Viewport.java :203)
at org.eclipse.draw2d.Viewport.validate(Viewport.java:364)
at org.eclipse.draw2d.Figure.validate(Figure.java:1738)
at org.eclipse.draw2d.DeferredUpdateManager.validateFigures(Def erredUpdateManager.java:271)
at org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:143)
at org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(D eferredUpdateManager.java:40)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3102)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2761)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
| Re: Figure.validate() crashes [message #218047 is a reply to message #218027] |
Sun, 18 June 2006 20:29   |
When the canvas is disposed, the updatemanager is supposed to be disposed
too. I thought that this typically happens for free, but maybe not in all
cases.
"Paul Keyser" <rolarenfan@earthlink.net> wrote in message
news:e6vb8p$f1n$1@utils.eclipse.org...
> R3.1.2, WinXP
> figure; anyone know why? is it a Figure bug, or is there some action I
> should be taking?
> thanks,
> Paul
> at
> at
> at
> at
> at
> at
| Re: Figure.validate() crashes [message #218077 is a reply to message #218027] |
Mon, 19 June 2006 11:13   |
Originally posted by: lamont_gilbert.rigidsoftware.com
Your not alone. I started getting these lately as well. Not sure if its
the same stack trace as I haven't investigated. But I am getting the
exception.
CL
Paul Keyser wrote:
> R3.1.2, WinXP
> should be taking?
> thanks,
> Paul
> at
> at org.eclipse.draw2d.Viewport.readjustScrollBars(Viewport.java :203) at
> org.eclipse.draw2d.Viewport.validate(Viewport.java:364) at
> org.eclipse.draw2d.Figure.validate(Figure.java:1738) at
> at
> at
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5) at
> at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3102) at
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2761) at
> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699) at
> org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663) at
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into the
sheepfold{}, but climbeth up some other *way, the same is a thief and a
robber."
| Re: Figure.validate() crashes [message #218091 is a reply to message #218077] |
Mon, 19 June 2006 13:48   |
Note that the above method returns without doing anything if the manager has
been disposed. You should always dispose the manager when the canvas is
disposed, since painting and layout occur asynchronously.
| Re: Figure.validate() crashes [message #218099 is a reply to message #218091] |
Mon, 19 June 2006 14:13   |
> has been disposed. You should always dispose the manager when the canvas
> is disposed, since painting and layout occur asynchronously.
Only manager I created is a DeferredTreeContentManager but it does not
dispose. I didnt make any changes to the figure layer. Im just using a
TreeViewer. Its not GEF related. Again, I'm not sure where the exception
is being thrown so it could be something different.
Respectfully,
CL Gilbert
robber."
FUDForum. Page generated in 0.01669 seconds
