Home » Eclipse Projects » Web Tools Project (WTP) » Web project does not start
| Web project does not start [message #214326] |
Tue, 27 May 2008 06:44  |
Originally posted by: jarkko.miettinen.iki.fi
I have a following problem:
We have a project where we are using JSPs. I am using Tomcat as a web
container for this project and I have problems getting this project
running. What I've done is following:
Check out the project from SVN using new->SVN->checkout project from SVN.
Then I create the project as Web->Dynamic web project.
In our source structure that I check out from SVN we have src/main and
src/tests which I "use as source folders" to bring them to top level and
to get the packages right and webapps/equipment under which the WEB-INF
and META-INF lie. Then built classes (with ant) go in
webapps/equipment/WEB-INF/classes.
Context.xml lies in webapps/equipment/META-INF and web.xml in
webapps/equipment/WEB-INF.
Problem is that after I add this project to my tomcat server using Eclipse
tools (Servers view and add/remove projects) I do not get any program
started.
I've once successfully gotten this to work but I do not know what I've
done differently at that time.
I understand that this is kind of decoherent explanation but I do not know
that on what points should I give more details.
Apache starting output:
May 27, 2008 10:03:13 AM org.apache.catalina.core.AprLifecycleListener
lifecycleEvent
INFO: The Apache Tomcat Native library which allows optimal performance in
production environments was not found on the java.library.path:
/usr/lib/jvm/ia32-java-1.5.0-sun-1.5.0.13/jre/lib/i386/serve r:/usr/lib/jvm/ia32-java-1.5.0-sun-1.5.0.13/jre/lib/i386:/us r/lib/jvm/ia32-java-1.5.0-sun-1.5.0.13/jre/../lib/i386:/usr/ lib/jvm/java-6-sun-1.6.0.03/jre/lib/amd64/server:/usr/lib/jv m/java-6-sun-1.6.0.03/jre/lib/amd64:/usr/lib/jvm/java-6-sun- 1.6.0.03/jre/../lib/amd64:/usr/lib/firefox
May 27, 2008 10:03:13 AM org.apache.coyote.http11.Http11BaseProtocol init
INFO: Initializing Coyote HTTP/1.1 on http-8180
May 27, 2008 10:03:13 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 953 ms
May 27, 2008 10:03:13 AM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
May 27, 2008 10:03:13 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5
May 27, 2008 10:03:13 AM org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
May 27, 2008 10:03:14 AM org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8180
May 27, 2008 10:03:14 AM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
May 27, 2008 10:03:14 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/46 config=null
May 27, 2008 10:03:14 AM org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
May 27, 2008 10:03:15 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 1400 ms
Eclipse configuration details:
*** Date: Tue May 27 13:44:39 EEST 2008
*** Platform Details:
*** System properties:
ant.home=/usr/share/ant
ant.library.dir=/usr/share/ant/lib
eclipse.buildId=M20070212-1330
eclipse.commands=-os
linux
-ws
gtk
-arch
x86_64
-launcher
/usr/lib/eclipse/eclipse
-name
Eclipse
-showsplash
600
-exitdata
20003a
-vm /usr/lib64/jvm/ia32-java-1.5.0-sun/bin/java
-install
/usr/lib/eclipse
-vm
/usr/lib/jvm/java-1.5.0-sun/bin/java
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1211884413736
eclipse.vm=/usr/lib/jvm/java-1.5.0-sun/bin/java
eclipse.vmargs=-Djava.library.path=/usr/lib/jni
-Dgnu.gcj.precompiled.db.path=/var/lib/gcj-4.2/classmap.db
-Dgnu.gcj.runtime.VMClassLoader.library_control=never
-Dosgi.locking=none
-jar
/usr/lib/eclipse/startup.jar
eof=eof
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/usr/lib/eclipse/startup.jar
java.class.version=49.0
java.endorsed.dirs=/usr/lib/jvm/java-1.5.0-sun-1.5.0.13/jre/ lib/endorsed
java.ext.dirs=/usr/lib/jvm/java-1.5.0-sun-1.5.0.13/jre/lib/e xt
java.home=/usr/lib/jvm/java-1.5.0-sun-1.5.0.13/jre
java.io.tmpdir=/tmp
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_13-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_13
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_13-b05
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.22-14-generic
org.osgi.framework.processor=amd64
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=amd64
os.name=Linux
osgi.arch=x86_64
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=/home/jmiettin/.eclipse/org.eclipse.platfor m_3.2.0/configuration/org.eclipse.osgi/bundles
osgi.configuration.area=file:/home/jmiettin/.eclipse/org.ecl ipse.platform_3.2.0/configuration/
osgi.framework=file:/usr/lib/eclipse/plugins/org.eclipse.osg i_3.2.2.R32x_v20070118.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.2.R32x_v20070118
osgi.install.area=file:/usr/lib/eclipse/
osgi.instance.area=file:/home/jmiettin/workspace/
osgi.instance.area.default=file:/home/jmiettin/workspace/
osgi.locking=none
osgi.logfile=/home/jmiettin/workspace/.metadata/.log
osgi.manifest.cache=/home/jmiettin/.eclipse/org.eclipse.plat form_3.2.0/configuration/org.eclipse.osgi/manifests
osgi.nl=en_US
osgi.os=linux
osgi.sharedConfiguration.area=file:/usr/lib/eclipse/configur ation/
osgi.splashLocation=/usr/lib/eclipse/plugins/org.eclipse.pla tform_3.2.2.r322_v20070117b/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/usr/lib/eclipse/plugins
osgi.ws=gtk
path.separator=:
sun.arch.data.model=64
sun.boot.class.path=/usr/lib/jvm/java-1.5.0-sun-1.5.0.13/jre /lib/rt.jar:/usr/lib/jvm/java-1.5.0-sun-1.5.0.13/jre/lib/i18 n.jar:/usr/lib/jvm/java-1.5.0-sun-1.5.0.13/jre/lib/sunrsasig n.jar:/usr/lib/jvm/java-1.5.0-sun-1.5.0.13/jre/lib/jsse.jar: /usr/lib/jvm/java-1.5.0-sun-1.5.0.13/jre/lib/jce.jar:/usr/li b/jvm/java-1.5.0-sun-1.5.0.13/jre/lib/charsets.jar:/usr/lib/ jvm/java-1.5.0-sun-1.5.0.13/jre/classes
sun.boot.library.path=/usr/lib/jvm/java-1.5.0-sun-1.5.0.13/j re/lib/amd64
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=gnome
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot 64-Bit Server Compiler
sun.os.patch.level=unknown
user.country=US
user.dir=/home/jmiettin
user.home=/home/jmiettin
user.language=en
user.name=jmiettin
user.timezone=Europe/Mariehamn
*** Features:
org.apache.batik (1.6.0.v20060613-1220-0842282835-3442) "Apache Batik"
org.apache.batik.pdf (1.6.0.v20060613-1220-0842282835-3442) "Apache Batik
Pdf"
org.eclipse.emf (2.2.2.v200702131851) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.2.1.v200702131851) "EMF Service Data Objects
(SDO)"
org.eclipse.gef (3.2.2.v20070208) "Graphical Editing Framework"
org.eclipse.jdt (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse Java
Development Tools"
org.eclipse.jdt.source (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse
Java Development Tools SDK"
org.eclipse.jem (1.2.1.v20060815_M----6zXJJzKIRGVU) "Java EMF Model"
org.eclipse.jst (1.5.4.v200704150219-kW-NuyxHh4-w7-n) "J2EE Standard Tools
(JST)"
org.eclipse.pde (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse
Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.2.2.r322_v20070119-CXMbUe9K_WF26uA) "Eclipse
Platform"
org.eclipse.platform.source (3.2.2.r322_v20070119-CXMbUe9K_WF26uA)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.2.r322_v20070104-iwP0VLKnfFC923K) "Eclipse RCP"
org.eclipse.rcp.source (3.2.2.r322_v20070104-iwP0VLKnfFC923K) "Eclipse RCP
org.eclipse.sdk (3.2.2.r322_v20070104-OIsEN15kfLend_i) "Eclipse Project
SDK"
org.eclipse.tptp.platform.analysis (4.2.4.v200701141614--3YIAAaBIFODXIT)
"TPTP Analysis"
org.eclipse.tptp.platform.analysis.codereview.java
(4.2.3.v200701141614--1G955H668B6GAA) "Java Code Review Plug-in"
org.eclipse.tptp.platform.analysis.engine
(4.2.0.v200606131519--1G955G5G7A7E7M) "TPTP Analysis Engine"
org.eclipse.tptp.platform.core (4.2.4.v200701141614--Cq0bcucUsLmduh) "TPTP
Platform"
org.eclipse.tptp.platform.core.doc.user
(4.2.0.v200606121835--1G955G5G7A7E7M) "TPTP Platform Project Documentation"
org.eclipse.tptp.platform.doc.user (4.2.1.v200611301029-8AcKKFcGfHZMbEo)
org.eclipse.tptp.platform.examples (4.2.0.v200606121835--0842282835373A)
"TPTP Platform Examples"
org.eclipse.tptp.platform.lta (4.2.1.v200607310100--1G955G5J696I7F) "TPTP
Log and Trace Analyzer"
org.eclipse.tptp.platform.probekit (4.2.1.v200607310100--3YIAAYAaIICMCS)
"TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user
(4.2.0.v200606121835--0842282835373A) "Probekit User Documentation"
org.eclipse.tptp.platform.report (4.1.101.v200607310100--2PD88P8QCE_I_P)
"TPTP Charting Service"
org.eclipse.tptp.platform.samples (4.2.0.v200606131519--2PD88P8PAGAMAY)
"TPTP Platform Samples"
org.eclipse.tptp.platform.statistical.ui
(4.1.100.v200606131519--1G955G5G7A7E7M) "TPTP Statistical UI"
org.eclipse.tptp.platform.trace (4.2.3.v200701141614--2PD88Q8LCF_J_K)
"TPTP Platform Trace"
org.eclipse.tptp.trace (4.1.200.v200610310100--1G955G6B7C6A6D) "TPTP Trace"
org.eclipse.ve (1.2.1.v20060817_M-zXJUB0fxM-0vSdc) "Visual Editor"
org.eclipse.wst (1.5.4.v200704200440-X3TmzmK-W-vP-Fs) "Web Standard Tools
(WST)"
org.eclipse.xsd (2.2.2.v200702131851) "XML Schema Infoset Model (XSD)"
org.tigris.subversion.subclipse (1.2.4) "SVN Team Provider Core"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.v20060918_M) "Event Model" [Resolved]
com.ibm.icu (3.4.5.20061213) "International Components for Unicode for
Java (ICU4J)" [Active]
com.ibm.icu.source (3.4.5.20061213) "International Components for Unicode
for Java (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Active]
org.apache.axis (1.3.0.v200608161946) "Apache Axis 1.3.0" [Resolved]
org.apache.batik (1.6.0.v20060613-1220) "Apache Batik" [Resolved]
org.apache.batik.pdf (1.6.0.v20060613-1220) "Apache Batik Pdf" [Resolved]
org.apache.cactus (1.7.2.v200606181221) "Cactus Resource Plug-in"
[Resolved]
org.apache.commons_logging (1.0.4.v200608011657) "Apache commons logging
Plug-in" [Resolved]
org.apache.jakarta_log4j (1.2.8.v200607172048) "Apache Jakarta log4j
Plug-in" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0.v200608161946) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.8.0.v200606131651) "Xerces 2.8.0" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Active]
org.eclipse.ant.ui (3.2.1.r321_v20060828) "Ant UI" [Active]
org.eclipse.compare (3.2.1.M20060711) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content Mechanism"
[Active]
org.eclipse.core.expressions (3.2.2.r322_v20070109a) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.2.1.r321_v20060721) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems"
[Resolved]
org.eclipse.core.filesystem.linux.x86_64 (1.0.0.v20060603) "Core File
System for Linux" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.2.R32x_v20061218) "Core Resource
Management" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.1.R32x_v20060907)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Active]
org.eclipse.debug.core (3.2.1.v20060823) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.2.r322_v20070202) "Debug UI" [Active]
org.eclipse.draw2d (3.2.2.v20070208) "Draw2d" [Resolved]
org.eclipse.emf (2.2.0.v200702131851) "Eclipse Modeling Framework (EMF)"
[Resolved]
org.eclipse.emf.ant (2.2.0.v200702131851) "EMF Ant Tasks" [Active]
org.eclipse.emf.codegen (2.2.2.v200702131851) "EMF Template Code
Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.2.2.v200702131851) "EMF Ecore Code
Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.1.v200702131851) "EMF Ecore Code
Generation UI" [Resolved]
org.eclipse.emf.codegen.ui (2.1.0.v200702131851) "EMF Template Code
Generator UI" [Resolved]
org.eclipse.emf.common (2.2.1.v200702131851) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.2.1.v200702131851) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0.v200702131851) "CommonJ SDO" [Resolved]
org.eclipse.emf.converter (2.2.1.v200702131851) "EMF Model Convert
Support" [Active]
org.eclipse.emf.ecore (2.2.2.v200702131851) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.1.v200702131851) "EMF Ecore Change
Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.2.0.v200702131851) "EMF Ecore Change
Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.2.0.v200702131851) "EMF Ecore Edit Support"
[Resolved]
org.eclipse.emf.ecore.editor (2.2.0.v200702131851) "Sample Ecore Editor"
[Resolved]
(SDO)" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.2.0.v200702131851) "EMF Service Data
Objects (SDO) Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.2.0.v200702131851) "EMF Service Data
Objects (SDO) Editor" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.2.v200702131851) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.2.v200702131851) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.2.1.v200702131851) "EMF Edit UI" [Resolved]
org.eclipse.emf.exporter (2.2.0.v200702131851) "EMF Model Export Support"
[Resolved]
org.eclipse.emf.importer (2.2.2.v200702131851) "EMF Model Import Support"
[Active]
org.eclipse.emf.importer.ecore (2.2.0.v200702131851) "EMF Ecore Importer"
[Active]
org.eclipse.emf.importer.java (2.2.1.v200702131851) "EMF Annotated Java
Importer" [Resolved]
org.eclipse.emf.importer.rose (2.2.0.v200702131851) "EMF Rose Importer"
[Active]
org.eclipse.emf.mapping (2.2.0.v200702131851) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200702131851) "Ecore to Ecore
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200702131851) "Ecore to
Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200702131851) "Ecore to XML
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200702131851) "Ecore to XML
Mapping UI" [Resolved]
org.eclipse.emf.mapping.ui (2.2.1.v200702131851) "EMF Mapping UI"
[Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0.v200702131851) "XSD to Ecore
Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0.v200702131851) "XSD to
org.eclipse.equinox.common (3.2.0.v20060603) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (3.2.1.R32x_v20060717) "Eclipse
Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.2.1.R32x_v20060814) "Extension Registry
Support" [Active]
org.eclipse.equinox.servlet.api (1.0.0.v20060601) "Servlet API" [Resolved]
org.eclipse.gef (3.2.2.v20070208) "Graphical Editing Framework" [Resolved]
org.eclipse.help (3.2.2.R322_v20061213) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server"
[Resolved]
org.eclipse.help.base (3.2.2.R322_v20061207) "Help System Base" [Active]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.2.R322_v20061114) "Help System Webapp"
[Resolved]
org.eclipse.hyades.analysis.engine (4.2.0.v200606131519) "Symptom Model"
[Resolved]
org.eclipse.hyades.execution (4.2.4.v200701241554) "TPTP Platform
Execution Plug-In" [Active]
org.eclipse.hyades.execution.correlation (4.1.100.v200606131519) "Hyades
Runtime Correlation Engine" [Resolved]
org.eclipse.hyades.execution.trace (4.1.100.v200606131519) "Hyades
Execution Trace" [Resolved]
org.eclipse.hyades.logging.core (4.2.2.v200609010912) "Hyades Logging
Agent, Common Base Events and Logging Facility Support" [Resolved]
org.eclipse.hyades.logging.core.sample (4.1.100.v200606131519) "Sample for
Hyades Logging Agent, Common Base Events and Logging Facility Support"
[Resolved]
org.eclipse.hyades.probekit (4.2.1.v200607310100) "Hyades Probekit"
[Resolved]
org.eclipse.hyades.probekit.doc.user (4.1.100.v200606131519) "Probekit
User Documentation" [Resolved]
org.eclipse.hyades.probekit.ui (4.1.101.v200607310100) "Probe Editor"
[Resolved]
org.eclipse.hyades.resources.database (4.1.100.v200606190100) "Hyades Core
Resource Extensions" [Resolved]
org.eclipse.hyades.statistical.ui (4.2.0.v200606131519) "Statistical UI"
[Active]
org.eclipse.hyades.trace.ui (4.2.3.v200701141614) "Hyades Trace Core UI"
[Active]
org.eclipse.hyades.trace.views (4.1.200.v200611150100) "Hyades Trace Views
Plugin" [Resolved]
org.eclipse.hyades.ui (4.1.101.v200701141614) "Hyades UI" [Active]
org.eclipse.jdt (3.2.1.r321_v20060823) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.core (3.2.3.v_686_R32x) "Java Development Tools Core"
[Active]
org.eclipse.jdt.core.manipulation (1.0.1.r321_v20060721) "Java Code
Manipulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.2.r322_v20070130) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.2.r322_v20061205) "JDI Debug UI" [Active]
org.eclipse.jdt.junit (3.2.1.r321_v20060810) "Java Development Tools JUnit
support" [Resolved]
org.eclipse.jdt.junit.runtime (3.2.1.r321_v20060721) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.launching (3.2.2.r322_v20061114) "Java Development Tools
Launching Support" [Active]
Java Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.2.r322_v20070124) "Java Development Tools UI"
[Active]
org.eclipse.jem (1.2.1.v20060918_M) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.2.0.v20060918_M) "Java EMF Model BeanInfo
(Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.2.0.v20060918_M) "Java EMF Model Proxy Support"
[Resolved]
org.eclipse.jem.ui (1.2.1.v20060918_M) "Java EMF Model UI" [Active]
org.eclipse.jem.util (1.2.1.v20060918_M) "Java EMF Model Utilities"
[Active]
org.eclipse.jem.workbench (1.2.1.v20060918_M) "Java EMF Model Workbench
Support" [Active]
org.eclipse.jface (3.2.2.M20061214-1200) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data Binding"
[Resolved]
org.eclipse.jface.text (3.2.2.r322_v20070104) "JFace Text" [Resolved]
org.eclipse.jst (1.0.1.v200605040115) "J2EE Standard Tools (JST)"
[Resolved]
org.eclipse.jst.common.annotations.controller (1.1.1.v200609132124)
"Annotation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.1.1.v200609132124) "Annotation
Core Plug-in" [Resolved]
org.eclipse.jst.common.annotations.ui (1.1.1.v200609132124) "Annotations
UI Plug-in" [Resolved]
org.eclipse.jst.common.frameworks (1.1.4.v200702021430) "Integration
Plug-in" [Resolved]
org.eclipse.jst.common.project.facet.core (1.1.0.v200608141517) "Project
Facet Core (Java Support)" [Resolved]
org.eclipse.jst.ejb.doc.user (1.0.203.v200609221649) "EJB docs" [Resolved]
org.eclipse.jst.ejb.ui (1.1.1.v200609132124) "WTP EJB UI Plug-in"
[Resolved]
org.eclipse.jst.j2ee (1.1.4.v200704261800) "J2EE Component" [Active]
org.eclipse.jst.j2ee.core (1.1.53.v200704191600) "J2EE Core Component"
[Active]
org.eclipse.jst.j2ee.doc.user (1.0.203.v200609182036) "J2EE tools
documentation" [Resolved]
org.eclipse.jst.j2ee.ejb (1.1.4.v200704261800) "EJB component Plug-in"
[Resolved]
org.eclipse.jst.j2ee.ejb.annotation.model (1.1.1.v200609140551) "EJB
Annotation Model Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.1.1.v200609140551) "EJB
Emitter Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.1.1.v200609070230) "EJB
Annotations Ui Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.1.1.v200609141515)
"Xdoclet Annotations Plug-in" [Resolved]
org.eclipse.jst.j2ee.infopop (1.0.202.v200609150300) "J2EE tools infopops"
[Resolved]
org.eclipse.jst.j2ee.jca (1.1.4.v200704161800) "JCA Plug-in" [Resolved]
org.eclipse.jst.j2ee.jca.ui (1.1.1.v200609132124) "WTP JCA UI Plug-in"
[Resolved]
org.eclipse.jst.j2ee.navigator.ui (1.1.2.v200702021430) "J2EE Extensions
to Common Navigator" [Resolved]
org.eclipse.jst.j2ee.ui (1.1.3.v200704261800) "WTP J2EE UI Plug-in"
[Resolved]
org.eclipse.jst.j2ee.web (1.1.3.v200701242244) "Web Plug-in" [Active]
org.eclipse.jst.j2ee.webservice (1.1.4.v200704161800) "Web Service
Plug-in" [Resolved]
org.eclipse.jst.j2ee.webservice.ui (1.1.3.v200704161800) "WTP Webservice
org.eclipse.jst.j2ee.xdoclet.runtime (1.1.1.v200609140551) "XDocletRuntime
Plug-in" [Resolved]
org.eclipse.jst.jsp.core (1.1.104.v200704191900) "Structured Source JSP
Model" [Resolved]
org.eclipse.jst.jsp.ui (1.1.100.v200608142042) "SSE JSP Source Editor"
[Resolved]
org.eclipse.jst.jsp.ui.infopop (1.0.2.v200605040115) "JSP tools infopops"
[Resolved]
org.eclipse.jst.server.core (1.0.106.v20070412) "Java Server Support"
[Active]
org.eclipse.jst.server.generic.core (1.0.101.v200608301011) "Generic
Server Plugin" [Resolved]
org.eclipse.jst.server.generic.jboss (1.5.2.v200702030302) "JBoss Generic
server definitions" [Resolved]
org.eclipse.jst.server.generic.jonas (1.5.0.v200606130315) "JOnAS Generic
Server definitions" [Resolved]
org.eclipse.jst.server.generic.oc4j (1.5.0.v200606130315) "Oracle OC4J
v10.1.3 DP4 Generic Server Definition Core Plug-in" [Resolved]
org.eclipse.jst.server.generic.ui (1.0.100.v200608221634) "Generic Server
Plugin UI" [Resolved]
org.eclipse.jst.server.generic.weblogic (1.5.1.v200609141504) "Weblogic
generic server definitions" [Resolved]
org.eclipse.jst.server.installable (1.5.2.v20061018) "Installable servers"
[Resolved]
org.eclipse.jst.server.tomcat.core (1.0.104.v20070202b) "Apache Tomcat
Support" [Active]
org.eclipse.jst.server.tomcat.ui (1.0.103.v20060906) "Apache Tomcat UI
Support" [Resolved]
org.eclipse.jst.server.ui (1.0.104.v20070401b) "Java Server UI Support"
[Resolved]
org.eclipse.jst.server.ui.doc.user (1.0.203.v200609221649) "Server Tools
documentation for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.ui.infopop (1.0.2.v200605040115) "Server Tools
infopops for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.websphere.core (1.0.101.v200609140551) "WebSphere
org.eclipse.jst.servlet.ui (1.1.2.v200702021430) "WTP Servlet UI Plug-in"
[Resolved]
org.eclipse.jst.servlet.ui.infopop (1.0.201.v200606130315) "Servlet
infopop" [Resolved]
org.eclipse.jst.ws (1.0.104.v200703212342) "Web Services" [Resolved]
org.eclipse.jst.ws.axis.consumption.core (1.0.104.v200704200400) "Web
service Axis Consumption Core" [Resolved]
org.eclipse.jst.ws.axis.consumption.ui (1.0.103.v200704200400) "Webservice
Axis Consumption UI" [Resolved]
org.eclipse.jst.ws.axis.creation.ui (1.0.105.v200704200400) "Webservice
Axis Creation UI" [Resolved]
org.eclipse.jst.ws.axis.infopop (1.0.201.v200605152241) "Web services Axis
UI" [Resolved]
org.eclipse.jst.ws.axis.ui.doc.user (1.0.203.v200609221649) "Axis Web
services documentation" [Resolved]
org.eclipse.jst.ws.consumption (1.0.104.v200704182024) "Web Services
Consumption" [Resolved]
org.eclipse.jst.ws.consumption.infopop (1.0.202.v20070131) "Web services
UI" [Resolved]
org.eclipse.jst.ws.consumption.ui (1.0.105.v200704251610) "Web Services
Consumption Graphical User Interface" [Resolved]
org.eclipse.jst.ws.consumption.ui.doc.user (1.0.202.v200609221649) "Web
service consumption documentation" [Resolved]
org.eclipse.jst.ws.creation.ejb.ui (1.0.0.v200606130315) "Web Services
Creation EJB Graphical User Interface" [Resolved]
org.eclipse.jst.ws.creation.ui (1.0.105.v200704041932) "Web Services
Creation Graphical User Interface" [Resolved]
org.eclipse.jst.ws.doc.user (1.0.203.v200609221649) "Web Services UI"
[Resolved]
org.eclipse.jst.ws.infopop (1.0.201.v200605162034) "Web services UI"
[Resolved]
org.eclipse.jst.ws.uddiregistry (1.0.100.v200608221651) "Web Services
Universal Description Discovery and Integration Registry" [Resolved]
org.eclipse.jst.ws.ui (1.0.102.v200704041932) "Web Services Graphical User
org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) "Refactoring Core"
[Active]
org.eclipse.ltk.ui.refactoring (3.2.2.r322_v20070124) "Refactoring UI"
[Active]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3 Services"
[Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.2.1.v20060810-0800) "Eclipse Plug-in Development
Environment" [Resolved]
org.eclipse.pde.build (3.2.1.r321_v20060823) "Plug-in Development
Environment Build Support" [Active]
org.eclipse.pde.core (3.2.1.v20060915-0800) "Plug-in Development Core"
[Active]
org.eclipse.pde.junit.runtime (3.2.0.v20060605) "PDE JUnit Plug-in Test"
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development Environment
Runtime" [Active]
Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.1.v20060816-0800) "Plug-in Development UI"
[Resolved]
org.eclipse.platform (3.2.2.r322_v20070117b) "Eclipse Platform" [Resolved]
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.linux.gtk.x86_64
(3.2.2.r322_v20070119-CXMbUe9K_WF26uA) "Eclipse Platform Plug-in Developer
org.eclipse.rcp (3.2.0.v20060605) "Eclipse RCP" [Resolved]
org.eclipse.rcp.source.linux.gtk.x86_64
(3.2.2.r322_v20070104-iwP0VLKnfFC923K) "Eclipse RCP Plug-in Developer
org.eclipse.sdk (3.2.2.r322_v20070212) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.1.r321_v20060726) "Search Support" [Resolved]
org.eclipse.swt (3.2.2.v3236b) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.gtk.linux.x86_64 (3.2.2.v3236) "Standard Widget Toolkit
for GTK 2.0" [Resolved]
org.eclipse.team.core (3.2.2.M20061114) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.2.M20061205) "CVS Team Provider Core"
[Resolved]
org.eclipse.team.cvs.ssh (3.2.1.M20061205) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.1.M20061205) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.2.M20061121) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.2.1.M200608151725) "Team Support UI" [Active]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tomcat (5.5.17) "Tomcat Wrapper" [Resolved]
org.eclipse.tptp.platform.agentcontroller (4.1.100.v200701261747) "TPTP
Agent Controller" [Resolved]
org.eclipse.tptp.platform.agentcontroller.doc.user (4.2.0.v200606131519)
"Agent Controller documentation" [Resolved]
org.eclipse.tptp.platform.analysis (4.1.100.v200606131519) "TPTP Analysis"
[Resolved]
org.eclipse.tptp.platform.analysis.codereview.java (4.2.3.v200701141614)
"Java Code Review Plug-in" [Resolved]
org.eclipse.tptp.platform.analysis.codereview.java.rules
(4.2.1.v200610230652) "Java Code Review Rules Plug-in" [Resolved]
org.eclipse.tptp.platform.analysis.core (4.2.3.v200701141614) "TPTP
Analysis Framework Core Plug-in" [Resolved]
org.eclipse.tptp.platform.analysis.core.ui (4.2.4.v200701141614) "Static
Analysis User Interface Plug-in" [Active]
org.eclipse.tptp.platform.analysis.core.ui.doc (4.2.0.v200610230652)
"Analysis run cofiguration online help" [Resolved]
org.eclipse.tptp.platform.analysis.engine (4.1.100.v200606131519) "TPTP
Analysis Engine" [Resolved]
org.eclipse.tptp.platform.collection.framework (4.1.102.v200701141614)
"TPTP Collection Framework" [Resolved]
org.eclipse.tptp.platform.core (4.1.100.v200606131519) "TPTP Platform"
[Resolved]
org.eclipse.tptp.platform.doc.user (4.1.100.v200606131519) "TPTP Platform
Project Documentation" [Resolved]
org.eclipse.tptp.platform.examples (4.2.0.v200606131519) "TPTP Platform
Examples" [Resolved]
org.eclipse.tptp.platform.execution (4.2.1.v200607310100) "TPTP Core
Platform (Provisional)" [Resolved]
org.eclipse.tptp.platform.log.views (4.2.1.v200609010912) "Hyades Log UI"
[Resolved]
org.eclipse.tptp.platform.lta (4.1.100.v200606131519) "TPTP Log and Trace
Analyzer" [Resolved]
org.eclipse.tptp.platform.models (4.2.4.v200701141614) "Hyades Models"
[Active]
org.eclipse.tptp.platform.probekit (4.1.100.v200606131519) "TPTP ProbeKit"
[Resolved]
org.eclipse.tptp.platform.probekit.launch (4.2.1.v200607310100) "Probekit
Launch Configuration" [Resolved]
org.eclipse.tptp.platform.report (4.1.100.v200606131519) "TPTP Charting
Service" [Resolved]
org.eclipse.tptp.platform.report.core (4.1.101.v200607310100) "TPTP Report
org.eclipse.tptp.platform.report.ui (4.1.100.v200606131519) "TPTP Report
UI" [Resolved]
org.eclipse.tptp.platform.samples (4.1.100.v200606131519) "TPTP Platform
Samples" [Resolved]
org.eclipse.tptp.platform.statistical.ui (4.1.100.v200606131519) "TPTP
Statistical UI" [Resolved]
org.eclipse.tptp.platform.trace (4.1.100.v200606131519) "TPTP Platform
Trace" [Resolved]
org.eclipse.tptp.trace (4.1.100.v200606131519) "TPTP Trace" [Resolved]
org.eclipse.ui (3.2.1.M20061108) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Active]
org.eclipse.ui.cheatsheets (3.2.1.R321_v20060720) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.v20060605) "Console" [Active]
org.eclipse.ui.editors (3.2.1.r321_v20060721) "Default Text Editor"
[Active]
org.eclipse.ui.externaltools (3.1.101.r321_v20060802) "External Tools"
[Active]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.2.1.M20060915-1030) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.2.R322_v20061214) "Welcome Framework" [Resolved]
org.eclipse.ui.intro.universal (3.2.1.R321_v20060905) "Universal Welcome"
[Resolved]
org.eclipse.ui.navigator (3.2.1.M20060913-0800) "Common Navigator View"
[Resolved]
org.eclipse.ui.navigator.resources (3.2.1.M20060906-0800b) "Navigator
Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21 Presentation
Plug-in" [Resolved]
org.eclipse.ui.views (3.2.1.M20060906-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.1.M20060830-0800) "Tabbed
Properties View" [Resolved]
org.eclipse.ui.workbench (3.2.2.M20070119-0800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060605-1400) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.2.2.R32x_v20070111) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.3.R32x_v20070118) "Install/Update Core"
[Active]
org.eclipse.update.core.linux (3.2.0.v20060605) "Install/Update Core for
Linux" [Resolved]
org.eclipse.update.scheduler (3.2.2.R32x_v20061214) "Automatic Updates
Scheduler" [Active]
org.eclipse.update.ui (3.2.2.R32x_v20070111) "Install/Update UI" [Resolved]
org.eclipse.ve (1.2.0.v20060518_RC1) "Visual Editor" [Resolved]
org.eclipse.ve.cde (1.2.0.v20060918_M) "Visual Editor Common Data Editor"
[Resolved]
org.eclipse.ve.doc (1.2.0.v20060824_M) "Visual Editor for Java User Guide"
[Resolved]
org.eclipse.ve.java.core (1.2.1.v20060918_M) "Visual Editor Java Core"
[Resolved]
org.eclipse.ve.jfc (1.2.1.v20060918_M) "Visual Editor for Java Foundation
Classes" [Resolved]
org.eclipse.ve.propertysheet (1.2.0.v20060824_M) "Visual Editor
PropertySheet" [Resolved]
org.eclipse.ve.swt (1.2.1.v20060918_M) "Visual Editor for Standard Widget
Toolkit" [Resolved]
org.eclipse.wst (1.0.1.v200605040144) "Web Standard Tools (WST)" [Resolved]
org.eclipse.wst.command.env (1.0.104.v200704200400) "Environment Command
Framework (headless)" [Active]
org.eclipse.wst.command.env.core (1.0.103.v200704200400) "Environment
Command Framework (core)" [Resolved]
org.eclipse.wst.command.env.doc.user (1.5.0.v20060831345) "Web services
Axis Ant task documentation" [Resolved]
org.eclipse.wst.command.env.infopop (1.0.2.v200605070230) "Web services
UI" [Resolved]
org.eclipse.wst.command.env.ui (1.0.103.v200703212342) "Environment
Command Framework (GUI)" [Resolved]
org.eclipse.wst.common.core (1.1.100.v200608220540) "WST Common Core
Plug-in" [Resolved]
org.eclipse.wst.common.emf (1.1.3.v200612061436) "EMF Utilities" [Active]
org.eclipse.wst.common.emfworkbench.integration (1.1.4.v200704111300) "EMF
Workbench Edit Plug-in" [Active]
org.eclipse.wst.common.environment (1.0.100.v200608251934) "Enviornment
Plug-in" [Resolved]
org.eclipse.wst.common.frameworks (1.1.4.v200704191600) "Common
Frameworks" [Active]
org.eclipse.wst.common.frameworks.ui (1.1.2.v200702071605) "WTP UI
Plug-in" [Resolved]
org.eclipse.wst.common.infopop (1.0.1.v200605270041) "Common WST infopops"
[Resolved]
org.eclipse.wst.common.modulecore (1.1.53.v200704161800) "Modulecore
Plug-in" [Active]
org.eclipse.wst.common.project.facet.core (1.1.1.v200608112156) "Project
Facet Core" [Active]
org.eclipse.wst.common.project.facet.ui (1.1.2.v200701192142) "Project
Facet UI" [Resolved]
org.eclipse.wst.common.snippets (1.1.1.v200609140550) "Snippets View"
[Resolved]
org.eclipse.wst.common.ui (1.1.101.v200702021750) "Eclipse Base UI
extensions" [Resolved]
org.eclipse.wst.common.ui.properties (1.0.101.v200609140551) "Common
Properties UI" [Resolved]
org.eclipse.wst.common.uriresolver (1.1.101.v200702021717) "Common URI
Resolver Framework" [Resolved]
org.eclipse.wst.css.core (1.1.1.v200609140550) "Structured Source CSS
Model" [Resolved]
org.eclipse.wst.css.ui (1.0.101.v200609140550) "SSE CSS Source Editor"
[Resolved]
org.eclipse.wst.datatools.connection.ui.doc.user (1.0.203.v200608310305)
"Data documentation" [Resolved]
org.eclipse.wst.datatools.data.ui.doc.user (1.0.203.v200608310305) "Data
tools data user interface documentation" [Resolved]
org.eclipse.wst.datatools.fe.ui.doc.user (1.0.203.v200608310305) "Data
org.eclipse.wst.datatools.server.ui.doc.user (1.0.203.v200608310305)
"Database Explorer documentation" [Resolved]
org.eclipse.wst.doc.user (1.0.203.v200608231821) "Master User Doc TOC"
[Resolved]
org.eclipse.wst.dtd.core (1.1.1.v200609210600) "Structured Source DTD
Core" [Resolved]
org.eclipse.wst.dtd.ui (1.0.102.v200702021750) "SSE DTD Source Editor"
[Resolved]
org.eclipse.wst.dtd.ui.infopop (1.0.1.v200605040131) "DTD Editor infopops"
[Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.203.v200609221649) "DTD Editor
org.eclipse.wst.html.core (1.1.2.v200612200820) "Structured Source HTML
Model" [Resolved]
org.eclipse.wst.html.standard.dtds (1.0.1.v200608220315) "Known DTDs"
[Resolved]
org.eclipse.wst.html.ui (1.0.102.v200702021750) "HTML UI Source Editor"
[Resolved]
org.eclipse.wst.html.ui.infopop (1.0.1.v200605040131) "HTML editor
infopops" [Resolved]
org.eclipse.wst.internet.cache (1.0.103.v200612070353) "Cache URI Resolver
Plug-in" [Resolved]
org.eclipse.wst.internet.monitor.core (1.0.103.v20060809) "Monitor"
[Resolved]
org.eclipse.wst.internet.monitor.ui (1.0.103.v20060809) "TCP/IP Monitor"
[Resolved]
org.eclipse.wst.internet.proxy (1.0.101.v200702021949) "Internet Proxy
Preferences" [Active]
org.eclipse.wst.internet.proxy.infopop (1.0.0.v200605070230) "Internet
Proxy Infopops" [Resolved]
org.eclipse.wst.javascript.core (1.0.1.v200609140550) "Structured Source
JavaScript Model" [Resolved]
org.eclipse.wst.javascript.ui (1.0.2.v200701250230) "SSE JavaScript Source
Editor" [Resolved]
org.eclipse.wst.javascript.ui.infopop (1.0.1.v200605040131) "Javascript
infopop" [Resolved]
org.eclipse.wst.rdb.connection.ui (1.0.107.v200703122014) "RDB
Connection.ui" [Resolved]
org.eclipse.wst.rdb.connection.ui.infopop (1.0.0.v200605040131) "New
Connection wizard infopops" [Resolved]
org.eclipse.wst.rdb.core (1.1.121.v200704131847) "RDB Core" [Resolved]
org.eclipse.wst.rdb.core.ui (1.0.109.v200703122014) "Core UI plugin"
[Resolved]
org.eclipse.wst.rdb.data.core (1.0.108.v200703122014) "Data Core Plugin"
[Resolved]
org.eclipse.wst.rdb.data.ui (1.0.111.v200703122014) "Data UI Plugin"
[Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.iseries (1.0.106.v200704191851) "DB2
UDB iSeries Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.luw (1.0.107.v200702021852) "DB2 UDB
org.eclipse.wst.rdb.dbdefinition.db2.zseries (1.0.107.v200704121755) "DB2
UDB Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.derby (1.0.104.v200610161905) "Derby
Database Definition" [Resolved]
org.eclipse.wst.rdb.dbdefinition.generic.jdbc (1.0.101.v200605040131)
"DBDefinition Generic JDBC Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.informix (1.0.104.v200610261819)
"Informix Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.mysql (1.0.101.v200610161905)
"DBDefinition Mysql Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.oracle (1.0.104.v200704102203) "Oracle
org.eclipse.wst.rdb.dbdefinition.sqlserver (1.0.105.v200610161905) "SQL
Server Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.sybase (1.0.106.v200610261819) "Sybase
org.eclipse.wst.rdb.derby (1.0.107.v200703122014) "RDB Derby Plug-in"
[Resolved]
org.eclipse.wst.rdb.derby.ui (1.0.103.v200612130213) "RDB Derby Ui
Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui (1.0.104.v200612130213) "FE UI Plug-in"
[Resolved]
org.eclipse.wst.rdb.fe.ui.actions (1.0.103.v200612130213) "FE Ui Actions
Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.infopop (1.0.0.v200605040131) "Generate DDL
org.eclipse.wst.rdb.models.dbdefinition (1.0.103.v200702062139)
"DBDefinition Model" [Resolved]
org.eclipse.wst.rdb.models.sql (1.0.104.v200612130213) "SQLModel Plug-in"
[Resolved]
org.eclipse.wst.rdb.models.sql.edit (1.0.103.v200612130213) "SQLModel Edit
Plug-in" [Resolved]
org.eclipse.wst.rdb.mysql (1.0.105.v200703122014) "RDB Mysql Plug-in"
[Resolved]
org.eclipse.wst.rdb.outputview (1.0.107.v200612130213) "Data Output
Plug-in" [Resolved]
org.eclipse.wst.rdb.outputview.infopop (1.0.0.v200605040131) "Data Output
view infopops" [Resolved]
org.eclipse.wst.rdb.server.extensions (1.0.105.v200612130213) "Server
Explorer Extensions Plug-in" [Resolved]
org.eclipse.wst.rdb.server.ui (1.0.111.v200703122014) "Server Explorer
plugin" [Resolved]
org.eclipse.wst.rdb.server.ui.infopop (1.0.0.v200605040131) "Server
Explorer view infopops" [Resolved]
org.eclipse.wst.rdb.sqleditor (1.0.107.v200703122014) "SQL Source Editor
Plugin" [Resolved]
org.eclipse.wst.rdb.sqleditor.infopop (1.0.0.v200605040131) "SQL infopops"
[Resolved]
org.eclipse.wst.rdb.sqlscrapbook (1.0.103.v200612130213) "Sqlscrapbook
Plug-in" [Resolved]
org.eclipse.wst.server.core (1.0.106.v20070401b) "Server Core" [Active]
org.eclipse.wst.server.ui (1.0.106.v20070425b) "Server UI" [Active]
org.eclipse.wst.server.ui.doc.user (1.0.203.v200609221649) "Server Tools
documentation for Web Standard Tools" [Resolved]
org.eclipse.wst.server.ui.infopop (1.0.3.v200609140551) "Server Tools
infopops for Web Standard Tools" [Resolved]
org.eclipse.wst.sqleditor.doc.user (1.0.2.v200608310308) "SQL Editor
org.eclipse.wst.sse.core (1.1.101.v200611210021) "Structured Text Model"
[Active]
org.eclipse.wst.sse.doc.user (1.0.203.v200608300230) "Structured text
editor and snippets documentation" [Resolved]
org.eclipse.wst.sse.ui (1.0.202.v200701252330) "Structured Source Editor"
[Resolved]
org.eclipse.wst.sse.ui.infopop (1.0.101.v200605040131) "SSE infopops"
[Resolved]
org.eclipse.wst.validation (1.1.4.v200704161800) "Validation Framework"
[Active]
org.eclipse.wst.validation.infopop (1.0.201.v200606130645) "WST validation
infopop plug-in" [Resolved]
org.eclipse.wst.validation.ui (1.1.2.v200612061436) "Validation Framework
UI" [Resolved]
org.eclipse.wst.web (1.1.2.v200610182223) "Simple Web Plug-in" [Active]
org.eclipse.wst.web.ui (1.1.1.v200609132124) "Simple Web UI Plug-in"
[Resolved]
org.eclipse.wst.web.ui.infopop (1.0.201.v200605070230) "Static Web
infopop" [Resolved]
org.eclipse.wst.webtools.doc.user (1.0.203.v200609221649) "Web tools
org.eclipse.wst.ws (1.0.102.v200702021949) "Web Services" [Resolved]
org.eclipse.wst.ws.explorer (1.0.105.v200704182024) "Web Services
Explorer" [Resolved]
org.eclipse.wst.ws.infopop (1.0.202.v20070131) "Web Services UI" [Resolved]
org.eclipse.wst.ws.parser (1.0.101.v200609062128) "Web Services
Description Parser" [Resolved]
org.eclipse.wst.ws.ui (1.0.103.v200704042036) "Web Services UI" [Resolved]
org.eclipse.wst.wsdl (1.0.104.v200704111356) "WSDL Model" [Resolved]
org.eclipse.wst.wsdl.ui (1.1.102.v200704192000) "WSDL UI" [Resolved]
org.eclipse.wst.wsdl.ui.doc.user (1.0.203.v200609221649) "WSDL Editor
org.eclipse.wst.wsdl.validation (1.1.102.v200704111356) "WSDL Validator"
[Resolved]
org.eclipse.wst.wsi (1.0.104.v200702021430) "WSI Conformance Tools"
[Resolved]
org.eclipse.wst.wsi.ui (1.0.101.v20060850312) "Soap Monitor" [Resolved]
org.eclipse.wst.wsi.ui.doc.user (1.0.202.v200609221649) "WS-I Validation
org.eclipse.wst.xml.core (1.1.101.v200704111417) "Structured Source XML
Model" [Active]
org.eclipse.wst.xml.ui (1.0.201.v200702021717) "XML UI Plugin" [Resolved]
org.eclipse.wst.xml.ui.infopop (1.0.1.v200605040131) "XML infopops"
[Resolved]
org.eclipse.wst.xmleditor.doc.user (1.0.203.v200609221649) "XML editor"
[Resolved]
org.eclipse.wst.xsd.core (1.1.101.v200701312359) "XSD Core Plugin"
[Resolved]
org.eclipse.wst.xsd.ui (1.1.103.v200704260345) "XML Schema Editor"
[Resolved]
org.eclipse.wst.xsdeditor.doc.user (1.0.203.v200609221649) "XML schema
editor" [Resolved]
[Resolved]
org.eclipse.xsd.ecore.exporter (2.2.1.v200702131851) "XML Schema Exporter
for EMF" [Resolved]
org.eclipse.xsd.ecore.importer (2.2.0.v200702131851) "XML Schema Importer
for EMF" [Active]
org.eclipse.xsd.edit (2.2.1.v200702131851) "XML Schema Edit Framework"
[Resolved]
org.eclipse.xsd.editor (2.2.0.v200702131851) "XML Schema Editor" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.tigris.subversion.subclipse.core (1.2.4) "SVN Team Provider Core"
[Active]
org.tigris.subversion.subclipse.doc (1.2.0) "Subclipse Documentation"
[Resolved]
org.tigris.subversion.subclipse.ui (1.2.4) "SVN Team Provider UI" [Active]
org.uddi4j (2.0.5.v200608231542) "UDDI4J 2.0.5" [Resolved]
org.wsdl4j (1.4.0.v200702061629) "WSDL4J 1.4" [Resolved]
system.bundle (3.2.2.R32x_v20070118) "OSGi System Bundle" [Active]
*** User Preferences:
#Tue May 27 13:44:40 EEST 2008
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.PackageExplo rer.ImportDeclarationFilter=true
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _EMF_ECORE=/home/jmiettin/.eclipse/org.eclipse.sdk.ide/updat es/eclipse/plugins/org.eclipse.emf.ecore_2.2.2.v200702131851 .jar\:
/project/keke2/org.eclipse.wst.validation/USER_BUILD_PREFERE NCE=enabledBuildValidatorListorg.eclipse.wst.xsd.core.intern al.validation.eclipse.XSDDelegatingValidator;org.eclipse.wst .html.internal.validation.HTMLValidator;org.eclipse.wst.wsdl .validation.internal.eclipse.WSDLDelegatingValidator;org.ecl ipse.wst.common.componentcore.internal.ModuleCoreValidator;o rg.eclipse.wst.dtd.core.internal.validation.eclipse.Validato r;org.eclipse.jst.j2ee.internal.web.validation.UIWarValidato r;org.eclipse.wst.wsi.ui.internal.WSIMessageValidator;org.ec lipse.wst.xml.core.internal.validation.eclipse.Validator;org .eclipse.jst.jsp.core.internal.validation.JSPBatchValidator;
/instance/org.eclipse.wst.sse.core/task-tag-projects-already -scanned=keke2,Servers
/instance/org.eclipse.ui.workbench/Oletus_persp=<?xml version\="1.0"
encoding\="UTF-8"?>\n<perspective editorAreaVisible\="1" fixed\="0"
version\="0.016">\n<descriptor
descriptor\="org.eclipse.jdt.ui.JavaPerspective" id\="Oletus"
label\="Oletus"/>\n<window height\="1154" width\="1930" x\="0"
y\="25"/>\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.openExternalFile"/ >\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.annotationNavigation "/>\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.navigation"/>\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo "/>\n<alwaysOnActionSet
id\="org.eclipse.ui.externaltools.ExternalToolsSet"/>\n<alwaysOnActionSet
id\="org.eclipse.ui.actionSet.keyBindings"/>\n<alwaysOnActionSet
id\="org.eclipse.ui.WorkingSetActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.update.ui.softwareUpdates"/>\n<alwaysOnActionSet
id\="org.eclipse.search.searchActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.ui.cheatsheets.actionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.debug.ui.launchActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.jdt.ui.JavaActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.jdt.ui.JavaElementCreationActionSet"/>\n <alwaysOnActionSet
id\="org.eclipse.ui.NavigateActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.debug.ui.breakpointActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.jdt.debug.ui.JDTDebugActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.jdt.junit.JUnitActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.debug.ui.profileActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.debug.ui.analysisActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.jst.ws.consumption"/>\n<alwaysOnActionSet
id\=" org.eclipse.jst.servlet.ui.internal.actions.ConvertToWebModu leTypeActionSet "/>\n<alwaysOnActionSet
id\="org.eclipse.wst.server.ui.internal.webbrowser.actionSet "/>\n<show_view_action
id\="org.eclipse.jdt.ui.PackageExplorer"/>\n<show_view_action
id\="org.eclipse.jdt.ui.TypeHierarchy"/>\n<show_view_action
id\="org.eclipse.jdt.ui.SourceView"/>\n<show_view_action
id\="org.eclipse.jdt.ui.JavadocView"/>\n<show_view_action
id\="org.eclipse.search.ui.views.SearchView"/>\n<show_view_action
id\="org.eclipse.ui.console.ConsoleView"/>\n<show_view_action
id\="org.eclipse.ui.views.ContentOutline"/>\n<show_view_action
id\="org.eclipse.ui.views.ProblemView"/>\n<show_view_action
id\="org.eclipse.ui.views.ResourceNavigator"/>\n<show_view_action
id\="org.eclipse.ui.views.TaskList"/>\n<show_view_action
id\="org.eclipse.ui.views.ProgressView"/>\n<show_view_action
id\="org.eclipse.ant.ui.views.AntView"/>\n<show_view_action
id\="org.eclipse.pde.runtime.LogView"/>\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewPackageCreationWizard"/ >\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewClassCreationWizard"/>\n <new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewInterfaceCreationWizard"/ >\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewEnumCreationWizard"/>\n <new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewAnnotationCreationWizard "/>\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewSourceFolderCreationWizard "/>\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewSnippetFileCreationWizard "/>\n<new_wizard_action
id\="org.eclipse.ui.wizards.new.folder"/>\n<new_wizard_action
id\="org.eclipse.ui.wizards.new.file"/>\n<new_wizard_action
id\="org.eclipse.ui.editors.wizards.UntitledTextFileWizard"/ >\n<new_wizard_action
id\="org.eclipse.jdt.junit.wizards.NewTestCaseCreationWizard "/>\n<perspective_action
id\="org.eclipse.jdt.ui.JavaPerspective"/>\n<perspective_action
id\="org.eclipse.debug.ui.DebugPerspective"/>\n<perspective_action
id\="org.eclipse.jdt.ui.JavaBrowsingPerspective"/>\n<view
id\="org.eclipse.ui.views.ProblemView"/>\n<view
id\="org.eclipse.jdt.ui.JavadocView"/>\n<view
id\="org.eclipse.jdt.ui.SourceView"/>\n<view
id\="org.eclipse.ui.views.ProgressView"/>\n<view
id\="org.eclipse.jdt.ui.PackageExplorer"/>\n<view
id\="org.eclipse.ui.views.ContentOutline"/>\n<layout>\n <mainWindow>\n<info
folder\="true"
part\="org.eclipse.ui.internal.ViewStack@3408ab31">\n<folder
activePageID\="org.eclipse.ui.views.ContentOutline" appearance\="2"
expanded\="2">\n<page content\="org.eclipse.ui.views.ContentOutline"
| Re: Web project does not start [message #214572 is a reply to message #214506] |
Fri, 30 May 2008 05:09   |
Larry Isaacs wrote:
> When you created the Dynamic Web Project, did you specify the Content
> Directory as "webapps/equipment" and the Java Source Directory as
> "src/main"?
> Note, after doing so, you would still need to add the "src/tests" as a
> second Java Source folder. Both of the source folders should output to
> the default output folder which would be "buildclasses". These built
> classes will get copied to the WEB-INF/classes folder during Export to a
> war file or when the project is published to a server. They do not need
> to be directed to the "webapps/equipment/WEB-INF/classes" in your
> project using an Ant build.
> Cheers,
> Larry
I changed the source directories manually by selecting the directory and
"use as a source folder". After I changed the Content Directory to
"webapps/equipment" when creating a new project I got the project to
deploy quite well. Is there a way to change this content directory
afterwards?
The thing is that it only seems to work halfway through:
The jsp-pages cannot find all the compiled java-classes and so I get a
jasper error of following sort:
org.apache.jasper.JasperException: Unable to compile class for JSP:
An error occurred at line: 19 in the generated java file
The import com.foo.bar.classy cannot be resolved
An error occurred at line: 564 in the jsp file: /jsp/MyJSP.jsp
DatatypeHelper cannot be resolved
I wonder what this means as clearly the classes are in some place where
tomcat can find them but yet the jsp's cannot?
| Re: Web project does not start [message #214587 is a reply to message #214572] |
Fri, 30 May 2008 09:15  |
Larry Isaacs Messages: 1261 Registered: July 2009 |
>> "src/main"?
>> to the default output folder which would be "buildclasses". These
>> built classes will get copied to the WEB-INF/classes folder during
>> Export to a war file or when the project is published to a server.
>> They do not need to be directed to the
>> "webapps/equipment/WEB-INF/classes" in your project using an Ant build.
>> Cheers,
>> Larry
> afterwards?
The publishing of Java classes and what is considered the "Content
Directory" folder is controlled by the
".settings/org.eclipse.wst.common.component" file in your project (use
the Navigator view to see it within Eclipse). In this file,
<wb-resource> entries of the form:
<wb-resource deploy-path="/WEB-INF/classes"
source-path="/some-java-source-folder"/>
define which Java source folders are going to have their build artifacts
included in the webapp's WEB-INF/classes. You should have one of
these for each Java source folder intended for WEB-INF/classes.
For the "Content Directory", an entry similar to the following should be
present:
<wb-resource deploy-path="/"
source-path="/path-to-folder-containing-web-content"/>
I haven't been looking, but I'm not aware of a UI way, even in WTP 3.0,
to change the "Content Directory" after the project is created.
Modifying the org.eclipse.wst.common.component file directly is the only
alternative I'm currently aware of. Note that you can add additional
entries to pickup content from multiple folders if that would make sense
in your use case. Also, I would recommend closing and reopening the
project after making manual changes to help ensure those changes are
seen in the current Eclipse session.
As a test, you can always export a war file and inspect the war to see
if everything you expect is included.
Larry
Current Time: Sat May 18 12:59:11 EDT 2013
Powered by FUDForum. Page generated in 0.01713 seconds
