Home » Eclipse Projects » Web Tools Project (WTP) » Xml document mode editor
Xml document mode editor [message #214451] Wed, 28 May 2008 16:06 Go to next message
Wishwas Mohan is currently offline Wishwas Mohan
Member
I am working on an XML editor to edit XML files in the document mode ie
edit xml files which are linked with CSS files. I have CSS files and the
xml files can be displayed in a browser (IE or firefox). Can someone
suggest existing tools for editing xml files in document (stylesheet) mode
or how such an editor can be built.
Looking forward for a reply,
Wishwas.
Re: Xml document mode editor [message #214459 is a reply to message #214451] Wed, 28 May 2008 16:21 Go to previous messageGo to next message
Eclipse User
Originally posted by: dcarver.starstandard.org
Wishwas wrote:
> Hello,
> mode or how such an editor can be built.
You may find this blog entry of interest:
http://in.relation.to/Bloggers/HowToCreateAVisualDocBookEdit orIn10Minutes
Re: Xml document mode editor [message #214466 is a reply to message #214459] Thu, 29 May 2008 02:53 Go to previous messageGo to next message
Member
Thanks for the reply David.
I have already been able to display the content in the format specified by
the CSS in Mozilla. I am looking for an editor which can actually help in
editing the xml file in the document mode. If the example in the quoted
blog is to be considered, I have been able to display the xml file in the
lower pane (Using a CSS) but I am looking for a tool/way to build a tool
which can edit the document in the lower pane.
David Carver wrote:
> Wishwas wrote:
>> Hello,
Re: Xml document mode editor [message #214514 is a reply to message #214466] Thu, 29 May 2008 09:34 Go to previous messageGo to next message
Eclipse User
> by the CSS in Mozilla. I am looking for an editor which can actually
> help in editing the xml file in the document mode. If the example in the
> quoted blog is to be considered, I have been able to display the xml
> file in the lower pane (Using a CSS) but I am looking for a tool/way to
> build a tool which can edit the document in the lower pane.
You might want to check out Oxygen XML, as I believe it does what you
are looking for.
http://www.oxygenxml.com/
Dave
Re: Xml document mode editor [message #214521 is a reply to message #214514] Thu, 29 May 2008 13:29 Go to previous messageGo to next message
Member
In terms of features , I am looking for what oxygen editor provides. But
,I am looking for something which is free/opensource.
> are looking for.
> Dave
Re: Xml document mode editor [message #214545 is a reply to message #214521] Thu, 29 May 2008 15:28 Go to previous messageGo to next message
Eclipse User
Another alternative is VEX.
http://vex.sourceforge.net/
I haven't looked it in a while and don't know how current it is.
Dave
Re: Xml document mode editor [message #214676 is a reply to message #214545] Sun, 01 June 2008 07:19 Go to previous messageGo to next message
Member
Thanks Dave!!!
Looks like this project has been frozen. I got the available plugins and
tried. I get a null pointer exception when I open Eclipse. Plz do let me
know if there any other such plugins. If there are some resources to help
build such an editor, the pointer to that also will be helpful.
> Dave
Re: Xml document mode editor [message #214684 is a reply to message #214676] Sun, 01 June 2008 07:49 Go to previous message
Member
Looks like there have been some development.
http://www.nabble.com/Error-message-when-starting-eclipse-w- VEX-plugin-to12497137.html
I am looking into it now. Wl post if nething useful is found.
Wishwas wrote:
> Thanks Dave!!!
>> Dave
Previous Topic:EJB3 generate entities
Next Topic:NPE while doing the JSF tutorial
Current Time: Fri May 24 11:36:13 EDT 2013
Powered by FUDForum. Page generated in 0.02425 seconds
