| reusable common web project [message #214392] |
Tue, 27 May 2008 17:30 |
Brian Chase Messages: 9 Registered: July 2009 |
Junior Member |
I'm trying to find the best way to create dynamic web applications in WTP
which consist of multiple web projects. For example, we have a common
project which contains web items (JSP, taglibs, ...) along with servlets and
other java code. There is also a dynamic web project which depends on this
common project and will need to produce a .WAR with the content of both
projects.
What is the best way to configure the common web project for this? Should
it be a dynamic web project? I've looked at the java utility project
however I'm not sure if this is correct because it does not appear to handle
web content and it produces a .JAR rather than a .WAR
Thank you
Brian
FUDForum. Page generated in 0.01601 seconds
