Home » Eclipse Projects » Web Tools Project (WTP) » AssertionFailed exception when opening JavaScript file
AssertionFailed exception when opening JavaScript file [message #214136] Wed, 21 May 2008 09:16 Go to next message
Marcus Better is currently offline Marcus Better
when I try to open a JavaScript file, I occasionally get an error dialog saying "Multiple problems have occurred", "org.eclipse.core.runtime.AssertionFailedException", and "null argument:" in the Details box. At other times it works fine. What should I do about this?
My project is a Grails project, and I've added JavaScript support with the "Web Development Tools -> Add JavaScript support" command from project's context menu.
I'm running the Ganymede M7 package of Eclipse for Java EE on Linux x86_64, Sun JDK 6.
Log output follows.
Marcus
!ENTRY org.eclipse.ui 4 0 2008-05-21 15:07:00.360
!MESSAGE Unable to create editor ID org.eclipse.wst.javascript.ui.internal.editor.JSMultiPageEdi torPart: No editor descriptor for id org.eclipse.wst.javascript.ui.internal.editor.JSMultiPageEdi torPart
!STACK 1
org.eclipse.ui.PartInitException: No editor descriptor for id org.eclipse.wst.javascript.ui.internal.editor.JSMultiPageEdi torPart
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:598)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:266)
at org.eclipse.ui.internal.EditorManager.findEditor(EditorManag er.java:403)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2730)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2693)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2685)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2637)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2632)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2616)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2607)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:644)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:603)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:318)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:160)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 8)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 7)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:370)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:607)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at org.eclipse.jface.util.OpenStrategy$1.mouseSelectItem(OpenSt rategy.java:428)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:364)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1154)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3398)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3030)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2394)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2358)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 10)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:494)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:489)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:112)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
!SUBENTRY 1 org.eclipse.ui 4 0 2008-05-21 15:07:00.362
!MESSAGE No editor descriptor for id org.eclipse.wst.javascript.ui.internal.editor.JSMultiPageEdi torPart
!ENTRY org.eclipse.jface 4 2 2008-05-21 15:07:00.364
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:86)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:74)
at org.eclipse.ui.internal.EditorSite.<init>(EditorSite.java:46)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:464)
!ENTRY org.eclipse.ui 4 0 2008-05-21 15:07:00.631
!STACK 1
at org.eclipse.ui.internal.EditorManager.findEditor(EditorManag er.java:381)
at org.eclipse.ui.internal.WorkbenchPage.findEditor(WorkbenchPa ge.java:2027)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.isOpenI nEditor(EditorUtility.java:126)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart. linkToEditor(PackageExplorerPart.java:1011)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart. handlePostSelectionChanged(PackageExplorerPart.java:915)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart. access$1(PackageExplorerPart.java:910)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 3.selectionChanged(PackageExplorerPart.java:435)
at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:842)
at org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:840)
at org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:1153)
at org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:1178)
at org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:250)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:244)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 418)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:132)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3375)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3033)
!SUBENTRY 1 org.eclipse.ui 4 0 2008-05-21 15:07:00.631
!ENTRY org.eclipse.jface 4 2 2008-05-21 15:07:00.631
!STACK 0
Re: AssertionFailed exception when opening JavaScript file [message #214161 is a reply to message #214136] Wed, 21 May 2008 18:18 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
> Log output follows.
> Cheers,
> Marcus
> !STACK 1
It looks like you're reusing a workspace from an earlier release.
Eclipse remembers the ID of the last editor you used to open a file,
so you'd see this on files you opened in prior releases but not on
files that you never opened before. With the massive Javascript
retooling that is in the 3.0 builds, the old editor just isn't
around any more. Use the file's context menu's "Open With" submenu
to choose the new editor.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: AssertionFailed exception when opening JavaScript file [message #214177 is a reply to message #214161] Thu, 22 May 2008 03:49 Go to previous message
Correct.
Thanks!
Marcus
Previous Topic:web app does not compile on Windows
Next Topic:Using a JavaScript library in an existing project
Current Time: Sat May 18 18:36:50 EDT 2013
Powered by FUDForum. Page generated in 0.01730 seconds
