Home » Eclipse Projects » Web Tools Project (WTP) » Changing plugin from custom to xml file extension
Changing plugin from custom to xml file extension [message #214127] Wed, 21 May 2008 08:57
Eclipse User
Originally posted by: uh5d.rz.uni-karlsruhe.de
Hi, i wrote a plugin for a new xml based filetype called mdl2e.
The plugin introduces a own validation, syntax highlighting, and filetype.
I now want to apply the same plugin for normal *.xml files.
I tried to change file-extensions="mdl2e" in file-extensions="xml"
in the contentTypes extension point as well as in the validator,
but the new syntax highlighting and validation don't work if the file has a
*.xml extension.
Can someone tell what I have to change in my plugin.xml to get it work with
normal xml files?
<!-- MDLE2 Editor Plugin -->
<plugin
id="iswarmide"
name="Iswarmide Plug-in"
version="1.0.0"
provider-name="%Plugin.providerName"
class="iswarmide.ISwarmIDEPlugin" >
<extension point="org.eclipse.core.runtime.contentTypes">
<content-type
priority="high"
name="MDL2e Content Type"
id="mdl2esource"
base-type="org.eclipse.core.runtime.xml"
default-charset="UTF-8">
<describer
class=" org.eclipse.core.runtime.content.XMLRootElementContentDescri ber ">
<parameter
name="element"
value="mdl2esheet" />
</describer>
</content-type>
</extension>
<extension point="org.eclipse.wst.sse.core.modelHandler">
<modelHandler
default="false"
class="iswarmide.ModelHandlerForMDL2E"
associatedContentTypeId="iswarmide.mdl2esource"
id="mdl2esourcehandler">
</modelHandler>
</extension>
<extension point="org.eclipse.wst.sse.ui.adapterFactoryDescription">
<adapterFactoryDescription
class="iswarmide.AdapterFactoryProviderForMDL2E"/>
</extension>
<extension point="org.eclipse.wst.sse.ui.editorConfiguration">
<sourceViewerConfiguration
class="iswarmide.StructuredTextViewerConfigurationMDL2E"
target="iswarmide.mdl2esource"
</extension>
<extension
id="mdl2evalidator"
name="MDL2EValidator"
point="org.eclipse.wst.validation.validator">
<validator>
<filter
objectClass="org.eclipse.core.resources.IFile"
caseSensitive="false"
nameFilter="*.mdl2e">
</filter>
<contentTypeBinding contentTypeId="iswarmide.mdl2esource"/>
<helper class="org.eclipse.wst.xml.core.internal.validation.core.Helper "/>
<run
async="true"
class="iswarmide.MDL2EValidator"
enabled="true"
fullBuild="true"
incremental="true"
</validator>
</extension>
<extension point="org.eclipse.wst.sse.ui.sourcevalidation">
<validator
scope="total"
class="iswarmide.MDL2EValidatorDelegator"
id="iswarmide.mdl2evalidatordelegator">
<contentTypeIdentifier id="iswarmide.mdl2esource">
<partitionType id="org.eclipse.wst.xml.XML_DEFAULT"/>
<partitionType id="org.eclipse.wst.sse.ST_DEFAULT"/>
</contentTypeIdentifier>
</validator>
</extension>
<validator
scope="partial"
class="iswarmide.MDL2EMarkupValidator"
id="iswarmide.mdl2emarkupvalidator">
</validator>
</extension>
</plugin>
Axel
Previous Topic:XML schemes provision
Next Topic:web app does not compile on Windows
Current Time: Wed May 22 04:33:56 EDT 2013
Powered by FUDForum. Page generated in 0.01701 seconds
