| Eclipse+WTP 3.4M7 startup trouble!? [message #213441] |
Thu, 08 May 2008 07:53  |
Frits Jalvingh Messages: 19 Registered: July 2009 |
Junior Member |
I just installed Eclipse 3.4m7 and wtp 3.0 m7 by untarring the eclipse gtk
tar and unzipping the WTP files over that. This usually works without any
problem.
But now, when I start this installation, I get:
- the Eclipse splash screen
- Eclipse uses CPU for some 10 seconds, then the CPU stays idle
- The splash stays on-screen for > 10 minutes(!)
- After the 10 minutes Eclipse starts, but WTP is not installed.
The console shows:
Artifact repository out of sync.
Overwriting /home/jal/opt/e-3.4m7/plugins/org.eclipse.datatools.intro_1. 0.0.200706071.jar
Overwriting /home/jal/opt/e-3.4m7/plugins/org.eclipse.datatools.doc.user _1.0.0.200706071.jar
Overwriting /home/jal/opt/e-3.4m7/plugins/org.apache.commons.discovery_0 .2.0.v200706111329
Overwriting /home/jal/opt/e-3.4m7/plugins/org.eclipse.jem.beaninfo_2.0.0 .v200705302225.jar
Overwriting /home/jal/opt/e-3.4m7/plugins/org.eclipse.jem.ui_2.0.0.v2007 05302225.jar
Overwriting /home/jal/opt/e-3.4m7/plugins/org.eclipse.jst.common.annotat ions.ui_1.1.2.v200706120315.jar
Overwriting /home/jal/opt/e-3.4m7/plugins/org.eclipse.wst.common.infopop _1.0.2.v200706110217.jar
Overwriting /home/jal/opt/e-3.4m7/plugins/org.eclipse.wst.validation.inf opop_1.0.202.v200706110217.jar
Overwriting /home/jal/opt/e-3.4m7/plugins/org.eclipse.wst.wsi.ui.doc.use r_1.0.203.v200706120315.jar
I did notice that in M6 the new update manager caused huge startup delays
also when new software was installed (about 4 minutes for the 1st startup
when new software was installed) but that continued to use CPU all that
time AND resulted in a usable installation....
Any thoughts on this?
Frits
| Re: Eclipse+WTP 3.4M7 startup trouble!? [message #213784 is a reply to message #213449] |
Wed, 14 May 2008 03:32  |
David Williams Messages: 671 Registered: July 2009 |
On Thu, 08 May 2008 09:18:32 -0400, Larry Isaacs <Larry.Isaacs@sas.com> =
wrote:
> Frits Jalvingh wrote:
>> I did notice that in M6 the new update manager caused huge startup de=
lays
>> also when new software was installed (about 4 minutes for the 1st sta=
rtup
>> when new software was installed) but that continued to use CPU all th=
> I would have expected see "eclipse" to be between the "e-3.4m7" and
> "plugins" in those paths.
There is a couple of bugs about that top level name 'eclipse' being some=
thing other than 'eclipse',
apparently being fixed in RC1. https://bugs.eclipse.org/bugs/show_bug.cg=
i?id=3D231178
So, you should leave that as 'eclipse' for now.
And, they are making great stride in startup times, but those are known =
issues. I'd say if you still see really bad performance in RC1 to open s=
ome new bugs at that point.
Any negative experiences you have should be reported as bugs as there's =
some very "fresh" code being used in the platform and we appreciate all =
the early eyes and fingers on it as we can.
FUDForum. Page generated in 0.01570 seconds
