| Starting Liferay Tomcat bundle from Eclipse [message #212935] |
Fri, 25 April 2008 09:37  |
Originally posted by: atarutin.ubm-us.com
I'm trying to start Liferay Tomcat bundle from Eclipse. The bundle is a
Tomcat container and Liferay is installed as a root application. The
container seems to be starting fine but then I get timeout error and the
following message appears in the .log file:
!ENTRY org.eclipse.wst.server.core 4 0 2008-04-24 15:46:07.767
!MESSAGE Timeout waiting for Apache Tomcat v5.5 (Liferay) at localhost to
start. Server did not start after 45s.
There are no error messages in the console.
How can I diagnose the problem? Increase the timeout?
Please advise.
Thank you,
AT.
| Re: Starting Liferay Tomcat bundle from Eclipse [message #212961 is a reply to message #212946] |
Fri, 25 April 2008 15:38  |
>> to start. Server did not start after 45s.
>> Please advise.
>> Thank you,
>> AT.
> Try Window -> Preferences -> Server and increase the "Server timeout
> delay", assuming you are using WTP 2.0.x or earlier.
> Cheers,
> Larry
That definitely helped.
Thank you.
AT.
FUDForum. Page generated in 0.01618 seconds
