Home » Eclipse Projects » Web Tools Project (WTP) » Help with jar files not getting exported in WAR file
| Help with jar files not getting exported in WAR file [message #212464] |
Thu, 17 April 2008 18:54  |
Originally posted by: adb.teamware.com
I have a utility project that uses a number of jar files in its lib directory.
These show up as 'Referenced libraries' in Eclipse 3.3.1.1.
The show up in the build path and a number of these are ticked in the order and
export page.
This project is set as a dependency by another web project, but I am getting
class not found exceptions when running my web app.
I've read a some of the similar posts here, but I cannot understand why this is
a problem and how to configure it correctly.
I get warnings like:
Classpath entry /Search/lib/commons-collections-3.2.jar will not be exported or
published. Runtime ClassNotFoundExceptions may result.
So, if do Quick Fix on it, it gives me the chance to 'Mark the associated raw
classpath as a publish/export dependency.'. If I do this, it moves that jar
file from 'Referenced libraries' to the 'EAR libraries' tree node.
The following is added to the <classpathentry> entry in the .classpath file
<attributes>
<attribute name="org.eclipse.jst.component.dependency" value="../"/>
</attributes>
The entry before the quick fix was
<classpathentry exported="true" kind="lib" path="lib/commons-collections-3.2.jar">
and in the build path libraries tab, the library now shows 'Public / export
dependencey : Added to parent project.' and it will be exported to WEB-INF/lib
in the WAR file.
I've spent half a day on this trying to find out how on earth I can just tell it
which libraries I want exported in the WAR file, but for the life of me cannot
find a way to do it other than the quick fix.
I can't seem to move the libraries to the EAR tab and unticking/re-ticking the
file in the export tab does not help
Where am I going wrong???
Antony
| Re: Help with jar files not getting exported in WAR file [message #212469 is a reply to message #212464] |
Thu, 17 April 2008 19:35   |
In my J2EE module dependencies for the web project, I have the dependency
project ticked. Also listed separately are the libraries shown in the utility
project EAR libraries tree, but they are not ticked, but the box is green. What
does that mean?
Antony
> directory. These show up as 'Referenced libraries' in Eclipse 3.3.1.1.
> order and export page.
> getting class not found exceptions when running my web app.
> this is a problem and how to configure it correctly.
> exported or published. Runtime ClassNotFoundExceptions may result.
> associated raw classpath as a publish/export dependency.'. If I do
> this, it moves that jar file from 'Referenced libraries' to the 'EAR
> <attributes>
> </attributes>
> export dependencey : Added to parent project.' and it will be exported
> to WEB-INF/lib in the WAR file.
> tell it which libraries I want exported in the WAR file, but for the
> life of me cannot find a way to do it other than the quick fix.
> unticking/re-ticking the file in the export tab does not help
> Antony
| Re: Help with jar files not getting exported in WAR file [message #212717 is a reply to message #212464] |
Mon, 21 April 2008 16:39   |
Originally posted by: hrobertfrost.gmail.com
Hi Antony,
As of 3.0 M4, the "J2EE Module Dependencies" tab is also displayed in
project properties for utility projects that are referenced only by dynamic
web projects. You can use this UI to add/remove the .classpath attribute.
See http://wiki.eclipse.org/ClasspathEntriesPublishExportSupport for
details.
Hope this helps,
Rob
Details on this functionality can be found:
"Antony Bowesman" <adb@teamware.com> wrote in message
news:fu8kfi$mnr$1@build.eclipse.org...
> raw classpath as a publish/export dependency.'. If I do this, it moves
> that jar file from 'Referenced libraries' to the 'EAR libraries' tree
> node.
> file
> <attributes>
> </attributes>
> export dependencey : Added to parent project.' and it will be exported to
> tell it which libraries I want exported in the WAR file, but for the life
> Antony
| Re: Help with jar files not getting exported in WAR file [message #212726 is a reply to message #212469] |
Mon, 21 April 2008 16:41   |
Hi Antony,
What you are seeing are the JARs from the utility project that will be added
to the published/exported content of that module. They are not "ticked"
(i.e. non-selectable) because their inclusion is controlled by the
..classpath attribute in the dependent project.
Hope this helps.
-Rob
news:fu8mrc$85i$1@build.eclipse.org...
> utility project EAR libraries tree, but they are not ticked, but the box
> is green. What does that mean?
> Antony
>> node.
>> file
>> <attributes>
>> </attributes>
>> Antony
| Re: Help with jar files not getting exported in WAR file [message #212750 is a reply to message #212717] |
Mon, 21 April 2008 22:12   |
Hi Rob,
> details.
In my J2EE Module Dependencies, I just get a red X with "Selected module not
associated with an Enterprise Application module."
What am I missing?
Antony
> Hope this helps,
> Rob
>> node.
>> file
>> <attributes>
>> </attributes>
>> Antony
| Re: Help with jar files not getting exported in WAR file [message #212758 is a reply to message #212750] |
Mon, 21 April 2008 22:32   |
Hi Antony,
It sounds like you are using a version of WTP prior to the change that added
J2EE Module Dependencies support for utility projects only referenced from
just dynamic web projects.
Try the current milestone of WTP 3.0.
-Rob
news:fujhi3$89k$1@build.eclipse.org...
> Hi Rob,
>> dynamic web projects. You can use this UI to add/remove the .classpath
>> attribute.
>> details.
> not associated with an Enterprise Application module."
> What am I missing?
> Antony
>> Hope this helps,
>> Rob
>>> file
>>> <attributes>
>>> </attributes>
>>> Antony
| Re: Help with jar files not getting exported in WAR file [message #212766 is a reply to message #212758] |
Mon, 21 April 2008 23:35   |
Hi Rob,
Sorry for the dumb question, but I have Eclipse Europa which shows me I have Web
Standard Tools WST 2.0.1 200709110510. Is WST the same as WTP?
Antony
| Re: Help with jar files not getting exported in WAR file [message #212892 is a reply to message #212766] |
Thu, 24 April 2008 09:51  |
No worries on the question; WST is a subset of WTP and the Europa releases
are for 2.0.x rather than 3.0 so that explains the behavior you are seeing.
You'll need to migrate to 3.0 or continue to use the QuickFix mechanism.
-Rob
news:fujmd6$rdm$1@build.eclipse.org...
> Hi Rob,
>> added J2EE Module Dependencies support for utility projects only
>> referenced from just dynamic web projects.
> have Web Standard Tools WST 2.0.1 200709110510. Is WST the same as WTP?
> Antony
Current Time: Sat May 25 21:11:47 EDT 2013
Powered by FUDForum. Page generated in 0.02159 seconds
