Home » Eclipse Projects » Web Tools Project (WTP) » WTP Axis2 client generation from WSDL broken?
WTP Axis2 client generation from WSDL broken? [message #212581] Fri, 18 April 2008 14:48 Go to next message
Eclipse User
Originally posted by: dajudge.t-online.de
Hi all,
I am trying to get the full round-trip of webservice/-client generation
working on WTP using axis2, and the webservice generation itself works
like a charm.
however, in the second step when the client code is to be generated from
the WSDL provided by axis2, the resulting code is either incomplete or
bogus - I can't tell really since I never saw a good result up to now.
to be more precise I tried a little example project of my own: for my
"MyService" webservice with a function "String wrap(String toWrap)" I
get two classes in the client project:
1. MyWebserviceCallbackHandler
2. MyWebserviceStub
Reading some tutorials makes me think there are actually some classes
missing? (Something about a SOAP12 http port?) The stub class itself
does indeed have a wrap() method, but it takes a Wrap object as
parameter and returns a WrapResponse object. This looks like a 1:1
mapping from the generated WSDL?
Calling those functions works - but of course that's far away from what
the original webservice looked like - and really cumbersome to use.
Following the tutorial from
http://www.eclipsecon.com/webtools/community/tutorials/Botto mUpAxis2WebService/bu_tutorial.html
resulted in the same problem: I didn't get the classes I was supposed to
according to the tutorial.
So finally my question: has anyone seen this before? Am I doing
something wrong?
I really appreciate your help!
Alex
Re: WTP Axis2 client generation from WSDL broken? [message #212661 is a reply to message #212581] Sat, 19 April 2008 04:26 Go to previous message
Eclipse User
Hi all,
I got into this a little more over night - and it looks to me like the
generation of the ADB style webservice client works nicely - but WTP
simply stops there and doesn't generate the wrapper classes around it
anymore that look like the original service classes on the server side.
Any ideas why this isn't happening?
Alex
Alexander Stockinger wrote:
> Hi all,
> like a charm.
> 2. MyWebserviceStub
> something wrong?
> Alex
Previous Topic:Eclipse WTP with WebSphere Portal Server
Next Topic:Error: Type name xxx does not exist when it's in fact in the project?
Current Time: Wed May 22 02:04:45 EDT 2013
Powered by FUDForum. Page generated in 0.07206 seconds
